POV-Ray : Newsgroups : povray.binaries.programming : Re: INFO: Inverse Server Time
2 Feb 2026 02:45:32 EST (-0500)
  Re: INFO: Inverse (Message 1 to 3 of 3)
Subject: Re: INFO: Inverse
Date: 27 Apr 1999 12:13:36
Message: <3725D3EB.77FF5EE3@spiritone.com>
Inverse only applies to unions, differences, etc...
You want to apply a warp statement to the object.
from the docs...
However, by specifying our turbulence inside warp statement you tell
POV-Ray that the order in which turbulence, transformations and other
warps are applied is significant. Here's an example of a turbulence warp.
  warp { turbulence <0,1,1> octaves 3 lambda 1.5 omega 0.3 }
The significance is that this
   wood
   translate <1,2,3> rotate x*45 scale 2
produces different results than this...
   wood
You may specify turbulence without using a warp statement. However you
cannot control the order in which they are evaluated unless you put them
in a warp
Josh English
eng### [at] spiritonecom
Hassoun wrote:
> Hi
> can i use "inverse" to reverse the order (or the sequence) in which
> objects are modified (translated, rotated, scaled)? any info of how to
> do this operation?
> thanks in advance
> Hassoun
Date: 27 Apr 1999 13:33:03
Message: <3725e6bf.0@news.povray.org>
Not true.  It applies to all objects with insides.  It just doesn't
usually matter except in CSG (and in bounded_by and clipped_by) and
perhaps with media.
Date: 27 Apr 1999 07:35:15
Message: <372592AE.FB33C438@aol.com>
Please do NOT cross post like this. Especially into such an irrelevant
group for this question.
Hassoun wrote:
> Hi
> do this operation?
> thanks in advance
> Hassoun
