POV-Ray : Newsgroups : povray.binaries.programming : MPI patch for povray 3.5c : Re: MPI patch for povray 3.5c Server Time: 20 Mar 2010 22:12:18 GMT
Date: 29 Nov 2005 11:35:01
Matthias <matthias_fueller [at] webde> wrote:
> Hi folks,
> based on PVMPOV, we have created a MPI patch for povray 3.5c It works
> quite well and has been tested on Linux (SuSE 7.3&8.0), Solaris 8.0 and
> Irix.
> It works with the new automake/autoconf system of povray 3.5, so just
> unpack the archive to your povray directory and run './configure',
> 'make' and 'make install', nothing new for you guys ;-)
> It has statistics, options and other stuff, so try it out!!
> Requirements are povray3.5c and LAM/MPI 6.5.x
> What do you think about it??
> If you like it, I hope it can be added to the tools section on the
> povray homepage...
> Matthias
For those who are interested in parallel versions of Povray - I found an
easy way to do this with any version of Povray. :) Read this article:
http://u.pereslavl.ru/~vadim/MCSharp/docs/povray/index.php
Best regards,
Vadim B. Guzev
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
