POV-Ray : Newsgroups : povray.binaries.programming : call megapov in Matlab, but where is the pic generated from megapov? : Re: call megapov in Matlab, but where is the pic generated from megapov? Server Time
11 Nov 2026 19:14:14 EST (-0500)
Date: 12 Jul 2012 03:36:45
Message: <4ffe7e8d@news.povray.org>
Enzo, the answer to your question is contained on your post two times!>
> !"C:\Program Files\POV-Ray for Windows v3.6\bin\MEGAPOV"
> +I"E:\Dropbox\POV ray\2012.07.10\Tree Model_only
> Leafs_no_shadow08.pov" +O"E:\Dropbox\POV ray\2012.07.10\a.bmp"
> +L"C:\Program Files\POV-Ray for Windows v3.6\include" +W800 +H600
   Here the command line contains the output file name, explicitly set to
"E:\Dropbox\POV ray\2012.07.10\a.bmp".
> Output Options Image resolution 800 by 600 (rows 1 to 600, columns 1
> to 800). Output file: E:\Dropbox\POV ray\2012.07.10/\Dropbox\POV
> ray\2012.07.10\a.bmp,
   And here again, the renderer tells you about it on the messages window...
> I thought that might the problem "Graphic display......Off ", but how
> can i turn on it?
   No, that was not the problem, but anyhow you can turn display on
adding +d on your command line.
Jaime
