POV-Ray : Newsgroups : povray.binaries.images : Cutty Sark Server Time
1 Apr 2026 10:53:12 EDT (-0400)
  Cutty Sark (Message 30 to 39 of 59)
Subject: Re: Cutty Sark
Date: 3 Nov 2025 10:30:00
Message: <web.6908ca4b392cce91475fba6a6cde94f1@news.povray.org>
hi,
"Ton" <ton### [at] gmailcom> wrote:
> It has been a while, but chains and ropes are a lot of work.
> I think I've finished the bow and bowsprit.
> Now on with the deck houses.
> Cheers
three cheers :-)  (and thanks)
regards, jr.
Date: 6 Nov 2025 14:30:00
Message: <web.690cf64d392cce9128a0f88730225ff5@news.povray.org>
You have a completely different approach than I do.
When I build something, then first the rough things, so that I can see where the
journey is going, details come afterwards.
You, on the other hand, seem to take on one thing down to the last detail, and
only when it's finished, then something else comes.
This is not a judgement, just an interesting insight.
Ma
Date: 7 Nov 2025 00:30:00
Message: <web.690d8384392cce9138e9762c7597fb06@news.povray.org>
> Ma
Well, we're all different, which is a good thing.
You create fine things as well, in your way.
My experience is that when I come back after a while, I have to get into it
again.
Now the bow is finished, and it can start collecting dust.
Ton.
Date: 26 Nov 2025 21:30:00
Message: <web.6927b755392cce9138e9762c7597fb06@news.povray.org>
Slowly moving forward.
The three hatches are done, and the folk onboard can go to the loo.
Now on to the poop-deck.
Ton.
Download 'forum_011.jpg' (53 KB)
Preview of image 'forum_011.jpg'
Date: 4 Dec 2025 10:15:00
Message: <web.6931a48e392cce916925ea730225ff5@news.povray.org>
> Cheers
> Ton.
Great, always gets a little more finished :)
I'm also building a ship, but a spaceship.
I can't get any further with it, not enought time.
Maybe I should post pictures regularly like you, to push myself forward.
Ma
Date: 5 Dec 2025 00:40:00
Message: <web.69326efc392cce9138e9762c7597fb06@news.povray.org>
> Ma
Thanks Mates, one step at a time...
Why don't you post images of your work in progress? It is a motivation.
Ton
Date: 13 Dec 2025 22:15:00
Message: <web.693e2aa8392cce9138e9762c7597fb06@news.povray.org>
The poop deck is coming along nicely.
Ton
Download 'forum_012.jpg' (77 KB)
Preview of image 'forum_012.jpg'
Date: 15 Dec 2025 06:40:00
Message: <web.693ff28c392cce91475fba6a6cde94f1@news.povray.org>
hi,
indeed :-).  is there much work to be done before you can "plant" the masts ?
regards, jr.
Date: 24 Dec 2025 17:55:00
Message: <web.694c6f33392cce9138e9762c7597fb06@news.povray.org>
Hi all,
here is a in-between to show the progress of the poop deck.
Thanks jr. There is still a lot to do before the masts get placed.
The bell and compass on the poop deck, the rudder wheel, the railing along the
stern.
The two deck houses, with the lifeboats on top.
Several deck winches, fife rails....
It will be a while.
This is the last update this year.
A merry Christmas everybody and all the best wishes for 2026!
Ton
Download 'forum_013.jpg' (142 KB)
Preview of image 'forum_013.jpg'
Date: 24 Dec 2025 22:35:00
Message: <web.694cb0b0392cce911f9dae3025979125@news.povray.org>
> stern.
I modeled a naval bell to honor clipka's father.
It's yours if you'd like to use it.
I have a compass rosette kicking around somewhere as well.
If that helps you get that much farther.
Great work as always. :)
Merry Christmas.
#version 3.8;
global_settings {assumed_gamma 1.0 }
 location <0, 2, -8>
 up y
 look_at <0, 0, 0>
light_source {<1, 2, -5> rgb 1 shadowless}
sky_sphere {pigment {rgb 1}}
#declare bellSpline = array [12] {
     < 3.4688, 0.0001>,
     < 3.4688, 0.0002>,
     < 3.0938, 0.4375>,
     < 2.9375, 0.6250>,
     < 2.4844, 1.3438>,
     < 2.1719, 2.6094>,
     < 2.0469, 4.4688>,
     < 1.9063, 4.6875>,
     < 1.7500, 4.8750>,
     < 1.0313, 5.0938>,
     < 0.0001, 5.1563>,
     < 0.0001, 5.1564>
// braided rope handle
#declare Lines = 5;
#declare Pitch = 2;
#declare Degree = (1/360);
#declare Rad = 0.002;  // sphere radius
#declare Dia = Rad * 2;
#declare Cycles = 1;
#declare Freq = 1;
#declare R1 = 0.05; // radius of large spiral
#declare A = 0.01; //radius of small spiral
//#declare B = 1.5;
#declare H = 0.002; //large spiral pitch smaller = tighter
#declare W = 8; // pitch of small spiral - how many cycles around one loop
#declare C = 0.01; // amplitude of undulation 1
#declare U = 0.1;  // undulation 2
#declare STEPS = 0.002*10;
#declare Strand1 = union {
 #for (i, -(Cycles/2)*360, (Cycles/2)*360, STEPS)
  #declare R = R1+(C*sin(U*i));   // adds undulation to cylindrical braid
  #local Angle = Degree * i;
  #local j = i + 45;     /// rotates green strand 45 deg from red
  #local Helix1_X = (R+A*cos(W*i))*cos(i);
  #local Helix1_Z = (R+A*cos(W*i))*sin(i);
  sphere {<0, 0, 0> Rad translate <Helix1_X, (H*i), Helix1_Z>} //weave
 #end // end for i
} // end union
#declare Strand2 = union {
  #local Helix2_X = (R+A*cos(W*j))*sin(j);
  #local Helix2_Z = (R+A*cos(W*j))*cos(j);
  sphere {<0, 0, 0> Rad translate <Helix2_X, (H*i), Helix2_Z>} //weave
 #end // end for i
} // end union
#declare AllStrands = union {
 #for (k, 1, W, 2)
  object {Strand1 rotate y*k*(360/W)}
  object {Strand2 rotate y*k*(360/W)}
 #end // end for k
#declare Handle = object {AllStrands texture {pigment {rgb 1} normal {bumps
0.01}} scale 2};
#declare arraySize = dimension_size (bellSpline, 1)-1;
#declare Rad = 0.1;
#declare Xmax = 0;
#declare Ymax = 0;
#declare Bell1 =
union {
 cylinder {<0, 0, 0>, <0, (5.0938/2)+1, 0> 0.125}
 sphere {0, 0.25}
 torus {0.125, 0.125/4 rotate x*90 translate -y*0.25}
 object {Handle translate -y*1}
 sor {
     arraySize+1,
  #for (B, 0, arraySize)
  #local NewSpline = bellSpline [B]/2;
  //#debug concat ("B = ", str (B, 3, 1), "| Point = ", vstr (2, bellSpline [B],
",", 5, 1), "\n")
  #declare Xmax = max (Xmax, NewSpline.x);
  #declare Ymax = max (Ymax, NewSpline.y);
  NewSpline,
     open
     sturm
 //texture { T_Gold_1B }
 //texture { mtex }
 pigment {rgb <1, 1, 0>}
object {Bell1}
