POV-Ray : Newsgroups : povray.binaries.images : Cornescu spiral Server Time
12 Sep 2025 20:29:23 EDT (-0400)
  Cornescu spiral (Message 1 to 4 of 4)
Subject: Cornescu spiral
Date: 22 Jul 2024 21:10:00
Message: <web.669f0287e214ac8f1f9dae3025979125@news.povray.org>
Just picked up a copy of _Optics_ by Bruno Rossi (1957) and as I was flipping
through it, the graph(s) of the Cornescu spiral caught my eye.
Took me a bit to find an appropriate algorithm for the Fresnel Integrals to port
to SDL, and how to graph them.
https://en.wikipedia.org/wiki/Euler_spiral
I could probably spend a bit more time getting a better formula for the pigment
as a function of arc-length . . .
(C'mon Povvers - make and post more cool stuff!)
Download 'cornescu.png' (69 KB)
Preview of image 'cornescu.png'
Subject: Re: Cornescu spiral
Date: 23 Jul 2024 00:59:27
Message: <669f38af$1@news.povray.org>
Interesting... And maybe a line width too ?
Could you share the code ?
YB
Date: 23 Jul 2024 06:40:00
Message: <web.669f8804dae111c01f9dae3025979125@news.povray.org>
Yes, I already have some modulation of the line width so that I have some
differentiation of the inner spiral region.
Also, I read somewhere that the convergence points were +/- sqrt(pi/2)/2
but that doesn't seem to be the case here.
No idea how to compute what the actual coordinates are - that's probably a
Matlab / Mathematica sort of thing to solve the infinite integrals.
Now the cool thing to do with this is start using it to play with some of the
practical applications.   IIRC, some physical phenomena correlate to the curve
by plotting (X^2) against it.
// +d +p +q9 +am3 +a0.1 +ac0.9 +r6
#version 3.8;
global_settings {
 assumed_gamma 1.0
#default {finish {emission 1}}
#declare E = 0.00001;
 location <0, 0, -1.5>
 up y
 look_at <0, 0, 0>
//sky_sphere {pigment {rgb 1}}
light_source {<100, 100, -500> rgb 1}
 #declare eps = 1e-15;
 #declare xa = function (_X) {abs (_X)}
 #declare px = function (_X) {pi * xa (_X)}
 #declare  T = function (_X) {0.5 * px (_X) * xa (_X)}
 #declare t2 = function (_X) {T(_X) * T(_X)}
#macro FCS (X)
 // Computes Fresnel Integrals C(x) and S(x)
 // Input: real x Output: C, S function values
 // (c) Shanjie Zhang & Jianming Jin
 // Computation of Special Functions
 // Wiley, 1996
 // Modified July 17 2012
 // Ported to SDL July 22 2024
 // by Bill "Bald Eagle" Walker
 #if (xa (X) = 0)
  #local c = 0;
  #local s = 0;
 #elseif (xa (X) < 2.5)
  #local r = xa (X);
  #local c = r;
  #for (k, 1, 50)
   #local r = -0.5 * r * (4*k-3)/ k / (2*k-1)/(4*k+1)*t2(X);
   #local c = c + r;
   #if (abs(r) < abs(c)*eps)
    #break // exit for loop
  #end // end for
  #local s = xa(X) * T(X)/3;
  #local r = s;
  #for (k, 1, 50)
   #local r = -0.5 * r * (4*k-1)/ k / (2*k+1)/(4*k+3)*t2(X);
   #local s = s + r;
   #if (abs(r) < abs(s)*eps)
    #if (X < 0)
     #local c = -c;
     #local s = -s;
    #break // exit macro
  #end // end for
 #elseif (xa (X) < 4.5)
  #local m = int (42 + 1.75*T(X));
  #local su = 0;
  #local c= 0;
  #local s = 0;
  #local f1 = 0;
  #local f0 = 1e-100;
  #for (k, m, 0, -1)
   #local f = (2*k+3)*f0/T(X)-f1;
   #if (k = int (k/2)*2)
    #local c = c+f;
   #else
    #local s = s+f;
   #local su = su + (2*k+1)*f*f;
   #local f1 = f0;
   #local f0 = f;
  #local q = sqrt (su);
  #local c = c*xa(X) / q;
  #local s = s*xa(X) / q;
 #else
  #local r = 1;
  #local f = 1;
  #for (k, 1, 20)
   #local r = -0.25*r*(4*k-1)*(4*k-3)/t2(X);
   #local f = f + r;
  #local r = 1/(px(X)*xa(X));
  #local g = r;
  #for (k, 1, 12)
   #local r = -0.25*r*(4*k+1)*(4*k-1)/t2(X);
   #local g = g + r;
  #local t0 = T(X) - int (T(X)/tau)*tau;
  #local c = 0.5 + (f*sin(t0)-g*cos(t0))/px(X);
  #local s = 0.5 - (f*cos(t0)+g*sin(t0))/px(X);
 #if (X < 0)
  #local c = -c;
  #local s = -s;
 #local Result = <c, s>;
 Result
#end // end macro FCS
#declare Line = 0.0015;
#local E = 0.000001;
#local Range = 10;
#local Index = 0;
#local Pos =
union {
 #for (N, 0, Range, 0.01)
  #local Line2 = Line * (1-N/Range);
  #local CS = FCS (N);
  #local C = CS.x;
  #local S = CS.y;
  #local Current = <C, S, 0>;
  #local Color = <1-N/Range, abs (0.5-N/Range), N/Range>;
  sphere {Current Line2 pigment {rgb Color}}
  #if (Index > 0)
   cylinder {Last, Current, Line2 pigment {rgb Color}}
  #local Last = Current;
  #local Index = Index+1;
 //pigment {rgb y}
#local Neg = object {Pos scale -1*<1, 1, 1>}
object {Pos}
object {Neg}
#declare CP = sqrt (pi/2)/2;
#declare ConvergencePoint = <CP, CP, 0>;
//sphere { ConvergencePoint Line*3 pigment {rgb x}}
//sphere {-ConvergencePoint Line*3 pigment {rgb x}}
Date: 23 Jul 2024 18:10:00
Message: <web.66a02a16dae111c01f9dae3025979125@news.povray.org>
Looks like the value is simply 1/2 for this spiral.
