POV-Ray : Newsgroups : povray.binaries.images : nest plants Server Time
5 Oct 2024 01:18:18 EDT (-0400)
  nest plants (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: nest plants
Date: 14 Nov 2023 06:52:29
Message: <65535f7d$1@news.povray.org>
On 11/14/23 06:29, Mike Miller wrote:
> Review rendering of plants around nest. Turned off fog to get a better look at
> things. The billboarded plants are behaving and rendering nicely. HDRI
> background, radiosity, 1 area light, and 40,000+ plants. Rendered in just over 3
> hours....long enough to watch the Buffalo Bills loss. :)
> Miller
Looking good.
I see some extra bright plants at larger distances. Are those
intentional or just happening for some reason?
Bill P.
Date: 14 Nov 2023 07:10:00
Message: <web.65536333d32cb1a8f22cdb33dabc9342@news.povray.org>
> > Miller
> Looking good.
> Bill P.
The tan/yellow areas in the hillside?...that's HDRI BG. I'll need to tweak that
to get a better transition from 3D hills to background hills.
Thanks,
Mike.
Date: 14 Nov 2023 08:23:26
Message: <655374ce$1@news.povray.org>
Using exr ?  There is a bug where the HDRI has values which exceed a
half float(a). IIRC. Values end up as HUGE_VAL and you get artifacts
that basically won't go away with normal -ish tweaking.
Bill P.
(a) - POV_Ray's current exr support only works with half float (16 bit)
exr files and many .exr files found today on the internet use the full
32 bit float format and those, sometimes, have values > 16 bits float max.
Date: 14 Nov 2023 10:15:00
Message: <web.65538e9fd32cb1a88952a6e4edfc8715@news.povray.org>
> Miller
The foliage is looking great, really nice coverage.
Date: 14 Nov 2023 13:30:00
Message: <web.6553bbced32cb1a8f9e40ba69334df62@news.povray.org>
Oh this is going to be awesome!
Date: 14 Nov 2023 16:05:00
Message: <web.6553dfc2d32cb1a8f22cdb33dabc9342@news.povray.org>
> Bill P.
Now that you mention this, I've been getting some weird and sporadic lighting
'blow-outs' depending on what objects I have hidden when using a 32 bit HDRI
background. I will drop it to 16 bit and report back.
Thanks,
Mike.
Date: 20 Nov 2023 14:52:52
Message: <655bb914$1@news.povray.org>
> Miller
A very vivid image!
Paolo
Date: 24 Nov 2023 18:58:31
Message: <656138a7$1@news.povray.org>
> Miller
I guess I gotta ask the basic question.
What do you mean by 'billboarded' plants? I thought I understood
something about them but in the end, I don't know what that term means.
Can you explain?
Thanks.
Date: 24 Nov 2023 19:10:00
Message: <web.65613b27d32cb1a81f9dae3025979125@news.povray.org>
> Can you explain?
You don't actually model the thing in 3D.
You take an image map and texture a flat shape with it, then point it toward the
camera.  Just like a billboard.
It's an illusion that save on modeling and 3D rendering (if it works well)
- BW
Date: 2 Dec 2023 15:34:19
Message: <656b94cb$1@news.povray.org>
>> Can you explain?
> - BW
Thanks (belatedly)
I thought that was it but some of the billboard samples I've seen seem
to be full renders, and I'm very brain muffled and very confused these days.
It's a technique I need to get into, I think, if I want to get some big
forests in my mead rendered out.
Josh
