POV-Ray : Newsgroups : povray.binaries.images : Interesting radial pattern Server Time
17 Dec 2025 22:44:10 EST (-0500)
  Interesting radial pattern (Message 1 to 4 of 4)
Subject: Interesting radial pattern
Date: 4 Sep 2023 18:20:00
Message: <web.64f657b1e70e474b1f9dae3025979125@news.povray.org>
I was off coding some experimental patterns, and came across this one by
accident.
This looke dlike one of those things that one would probably look for, and maybe
ought be in the distribution.
#version 3.8;
global_settings {assumed_gamma 1.0}
default {finish {diffuse 1}}
//#include "functions.inc"
 location <0, 0, -20>
 up y
 look_at <0, 0, 0>
light_source {<0,  0, -50> rgb 1.0}
sky_sphere {pigment {rgb 1}}
#declare fmod = function (T) {select (T, 1-mod(abs(T),1), mod(abs(T),1))}
#declare AngFreq = 7;
#declare Ang = function {atan2 (x, y)/(tau/AngFreq)}
#declare Ang2 = function {fmod (Ang(x, y, z))}
#declare Rad = function {sqrt (x*x+y*y)}
#declare Mixed = function {Rad (x,y,z) * Ang2(x,y,z)}
plane {z, 0 pigment {function {Mixed(x, y, z)} } }
Download 'coolradialpattern1.png' (172 KB)
Preview of image 'coolradialpattern1.png'
Subject: Re: Interesting radial pattern
Date: 12 Sep 2023 10:50:00
Message: <web.65007a6d53ff64f663eb3dfdaa81652d@news.povray.org>
> accident.
> #version 3.8;
> camera {
>  up y
>  look_at <0, 0, 0>
if you can explain why it seems that way?
Date: 12 Sep 2023 21:40:00
Message: <web.650111e653ff64f61f9dae3025979125@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> > accident.
> > This looked like one of those things that one would probably look for, and maybe
Why the pattern looks that way, or why it seems like it should be in the
distribution?
I would have to spend more time experimenting with the equations to explain why
the pattern is formed the way it is, but I felt it would be a useful pattern for
filling in grids - square grids, hexagonal grids, etc.
Likely if the pattern were modified and animated, one could perhaps get some
interesting visual effects.
It would be great to find a pre-existing library of such composite functions,
and then we could see if any more closely fit your needs for the tree-ring
pattern.
- BW
Date: 13 Sep 2023 08:51:44
Message: <6501b060$1@news.povray.org>
> accident.
Neat! :-) Changing AngFreq from 7 to 9 and making use of the povr fork's
raw_wave keyword.
plane {z, 0
         function {Mixed(x, y, z) } raw_wave
         color_map {
             [0       rgb 0 ]
             [AngFreq rgb 1 ]
Bill P.
Download 'be.png' (73 KB)
Preview of image 'be.png'
