"Bald Eagle" <cre### [at] netscapenet> wrote:
> Hi And,
> These are interesting pattern experiments, and I'm looking forward to seeing
> what you come up with.
> I find it interesting to see the pattern that you have here, as I didn't
> understand how the effect was being generated from a circular base pattern.
> I coded your pattern into a scene, and for some reason, did not get the same
> result. Perhaps you could post the full code of a working scene.
> Also, if you could describe the exact type of pattern that you are looking to
> make, it would be easier to help you develop something through a logical
> elaboration of a base pattern function.
> I started with an atan2 (x, y) function, as that will give you a radial pattern
> to start with.
> #version 3.8;
> global_settings {assumed_gamma 1.0}
> default {finish {diffuse 1}}
> #include "functions.inc"
> camera {
> location <0, 0, -10>
> right x*image_width/image_height
> up y
> look_at <0, 0, 0>
> light_source {<0, 1, -50> rgb 1.0}
> sky_sphere {pigment {rgb 1}}
> #declare C = function {0.5 - sqrt (x*x+y*y) + 0.1}
> #declare W1 = function {f_bumps (x/C(x, y, z), y/C(x, y, z), z)}
> #declare Freq = 20;
> #declare Ang = function {atan2 (x, y)/(tau/Freq)}
> #declare W2 = function {f_bumps (Ang (x, y, z), Ang (x, y, z), z)}
> #declare Wood1 =
> color_map {
> [0.00 srgb <249, 210, 173>/255]
> //[0.25 srgb <249, 210, 173>/255]
> [0.25 srgb <252, 156, 173>/255]
> //[0.50 srgb <252, 156, 173>/255]
> [0.50 srgb <206, 126, 72>/255]
> //[0.75 srgb <206, 126, 72>/255]
> [0.75 srgb <113, 51, 24>/255]
> //[1.00 srgb <113, 51, 24>/255]
> plane {z, 0 pigment {function {W1(x, y, z)} color_map {Wood1}} }
> //plane {z, 0 pigment {function {W2(x, y, z)} color_map {Wood1}} }
> Attached is what I get when I try to use the functions posted here.
Very beautiful image.
I use
camera{
location <0, 0, 10.4>
look_at <0.0, 0.0, 0.0>
right -x*image_width/image_height
sky <0,0,1>
angle 48
as my camera.
I must read your reply more. But it is mid-night here. See you tomorrow.
I feel it is similar with your pattern and mine. I post another image I rendered
today. The output of mine is "f_freq_control_test".
I'm looking for patterns which have random characteristic(like bump), but I need
apply it to associate 0~360 degree(angular), because that is a not completed yet
challenge for me.
Some other topic of different feature is what my concern, too. For example,
proximity pattern which I saw on POV-Ray newsgroup sometimes is another one.
I want to find several methods to combine them (bump, angular bump, streaks,...
with proximity pattern,...) to form a more complex pattern.
In fact, I know your W2 function have a seam... I have tried your (W2) method
when I started coding the macro for my wood generator program last year. So I
exchange it by a array value - function that time.
Download 'bump horizontal slice _diagram1.png' (338 KB)
Preview of image 'bump horizontal slice _diagram1.png'
Alain Martel <kua### [at] videotronca> wrote:
> > Because my mathematics is not so good, so I need spend so many years to think
> > these composite(I just try something I prepare for other concept).
> > The result yesterday is surprising me.
> That's not surprising for me. That's a formula for an ellipse that you
> got there for f_external_field.
I know, it is not strange of its appearance. I surly know (x/a)^2 + (y/b)^2 = 1
is the equation of ellipse. I just thinking about these trying of the
combination of it and f_bump. I was not so familiar with these combinations in
the past.
> challenge for me.
OK, I ran a few more experiments and came up with the attached.
#declare Rad = function {sqrt (x*x+y*y)}
#declare S = 0.5;
#declare W5 = function {Ang (x, y, z) * sin (Rad(x,y,z)*tau/RadFreq)*f_noise3d
(x/S, y/S, z)}
I hope that's more like what you want.
Yeah - I've noticed a radial asymmetry and a seam as well - I'll try to think
about a way to not have any discontinuities.
- BE
Download 'radialfunctions.png' (199 KB)
Preview of image 'radialfunctions.png'
> > challenge for me.
> #declare S = 0.5;
> (x/S, y/S, z)}
> - BE
I'm thinking and trying yours. In fact, that is interesting, too. But the seam
is still there. I have known that if you angular direct, (your Ang(x,y) ), you
unavoidable get the seam, or you mirror the pattern, but if so, you will produce
a symmetric pattern, not a randomize pattern.
I have found (just this thread I post) some combination to generate
angular-association or radial-association pattern to naturally avoid the seam,
they just don't have that seam. If you notice? I divide the (x, y) by its vector
length (your Rad(x,y,z) here) to f_bumps input, or just input a function which
used your Rad(x,y,0) to z. It is simple, I just never noticed the method before.
