![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Howdy folks,
I'm sure there's a very good reason that "transmit all" works the way that it
does with .png transparency, but it seems like it would be a lot more useful if
the file transparency would just carry over to the image map. Is there some
magical way to do that?
Here's a short demo file. (The image "ABBA.png" has an opaque round center and a
fully transparent border. Any .png file with transparency will do.)
Have a great day everyone!
#version 3.7;
global_settings {assumed_gamma 2.2}
orthographic
location <0, 0, -1>
right image_width / image_height * x
direction <0, 0, 1>
look_at <0, 0, 0>
} //camera
background {Orange}
#local ImagePigment = pigment {image_map {png "ABBA.png" gamma 2.2 map_type 0
once transmit all .7}}
#local ImageResolution = max_extent (ImagePigment);
object {
box {<0, 0, 0> <1, 1, .01>}
texture {pigment {ImagePigment} finish {emission .9} scale <1, 1.0000001, 1>}
translate <-.5, -.5, 0>
scale <1, ImageResolution.y / ImageResolution.x, 1>
} //object
Download 'untitled.jpg' (138 KB)
Preview of image 'untitled.jpg'
![untitled.jpg](/povray.binaries.images/attachment/%3Cweb.63ac0323f59cfc766631b53a9334df62%40news.povray.org%3E/untitled.jpg?ttop=443824&toff=200&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Try taking a look here, and see if this doesn't address the issue:
Specifically, the "use_alpha" keyword.
https://wiki.povray.org/content/Reference:Image_Pattern
Merry Christmas,
- BW
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Le 2022-12-28 à 03:49, Dave Blandston a écrit :
> Howdy folks,
First, in this case, you don't need to use transmit all.
transmit all intent is to give transparency to an image that have NO
alpha channel. It makes a picture with NO transparency transparent.
Try the same, but without transmit all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Merry Christmas,
> - BW
Merry Christmas to you as well, sir!
This note in the documentation might explain what's going on with version 3.7:
New as of version 3.8, using filter all and transmit all on an image file with
an alpha channel is now supported properly (requires #version 3.8 or higher).
Maybe it's time to upgrade to version 3.8...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Unfortunately, that generates an error message "Keyword 'transmit' cannot be
used with non color-mapped image."
I'm currently using a workaround, which is to apply the transparency with a
paint program. Since this is for an animation though, it means preparing many
images with varying transparency instead of one image that "transmit" can be
applied to.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> applied to.
color mapped images are image with a palette, not true/direct color.
For example, gif is always palette mapped, whereas jpeg is not.
Png is variable: it could have a palette or not.
("indexed": there is a palette; grayscale & truecolor: no palette)
This has nothing to do with transparency channel;
Gif can have it, png too, but I have never seen jpeg with it.
Alain suggested to not use "transmit all" for that picture, but to have
the transparency directly from the picture. (without any modifier)
You would edit first the transparency in your favorite editor and voilà.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Using a paint program to adjust the transparency is what I'm currently doing to
achieve the result that I want but it's not a perfect solution because of the
number of images involved. I'm using the "transmit all" feature to animate some
elements of a website mockup animation that fade in and fade out, such as
buttons and pop-ups and such. Images that don't require different levels of
transparency work great and I can use "transmit all," and only one copy of the
image needs to be made. But images that require part of the image to be fully
transparent exhibit the problem in the image posted above, so I can't use
"transmit all" and I have to make many copies of the image with the varying
levels of transparency which is very tedious. That's why I was curious if there
was a better way so I just thought I'd ask. I should have a sample animation
ready to post soon that will make this more clear. It's a fun project.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi Dave
Have you considered using ImageMagick to adjust the transparency levels
in your images?
https://imagemagick.org
ImageMagick provides command line tools that can be used in shell scripts
to automate such time consuming tasks.
https://imagemagick.org/script/magick-script.php
Perhaps this post is relevant for solving your problem:
"Setting an image to 50% transparency"
https://legacy.imagemagick.org/discourse-server/viewtopic.php?t=31549
Tor Olav
http://subcube.com
https://github.com/t-o-k
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmail com> wrote:
> Hi Dave
> in your images?
> Tor Olav
> http://subcube.com
This looks like a really useful program. I see the copyright is 1999 but I seem
to recall a program with the same or similar name from even earlier than that,
which was a DOS command-line program that operated on images. I used it quite a
bit to convert graphics formats. I wonder if this is an evolution of that DOS
program. Thanks for pointing it out.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Hi Dave
> > in your images?
ImageMagick has been popular for a long time.
There's some history here:
https://en.wikipedia.org/wiki/ImageMagick
Tor Olav
http://subcube.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
