POV-Ray : Newsgroups : povray.binaries.images : Crackle again Server Time
27 Sep 2024 09:29:31 EDT (-0400)
  Crackle again (Message 1 to 10 of 17)
Subject: Crackle again
Date: 23 Nov 2022 07:40:00
Message: <web.637e143ebe1b321fb96893c06f35e431@news.povray.org>
Hi everyone
I was reading through the recent thread on the crackle pattern, and I too was
unaware of the 'solid' modifier. And I too have often craved a 'custom'
crackle-like effect that could permit cell color to be controlled by a function
or pigment.
After some thought, I basically came to the same conclusions as Bald Eagle -
i.e. that it can't be done with user-defined functions, because the position
information is lost in the closest-distance calculation.
However, I think I've found another way. It's not particularly elegant, and it
only works in 2D, but it parses relatively leniently and renders fast. The idea
is to make a set of object pigment functions, one per cell, tracing against
cones to produce non-overlapping meshes. The object pigments can be given an
interior value based on their seed point position, zero outside, and then
combined using max() into one big function that can then itself go into a
pigment.
The attached example uses 250 seed points in a 20x20 square, the cells colored
using a wood pattern. It should be straightforward to layer the simple distance
function version of the same point array to provide mortar (although I haven't
tried this yet).
Bill
Download 'cracklebobs.png' (66 KB)
Preview of image 'cracklebobs.png'
Subject: Re: Crackle again
Date: 23 Nov 2022 08:35:00
Message: <web.637e2164c37f1de0b96893c06f35e431@news.povray.org>
> Hi everyone
Code for the curious:
#declare BrightFn = function { pigment {
 wood color_map { [0 rgb 0] [1 rgb 1] } rotate x*90 scale 6
#declare N = 250;
#declare Sd = seed(0);
#declare D = 10;
#declare Points = array[N];
#declare Cones = array[N];
#for (I, 0, N-1)
 #declare Points[I] = <rand(Sd)*20-10, 0, rand(Sd)*20-10>;
 #declare Cones[I] = cone { Points[I]-y*D, 10, Points[I], 0 }
#declare OtherCones = array[N];
#for (I, 0, N-1)
 #declare OtherCones[I] = union {
  #for (J, 0, N-1)
   #if (J != I) object { Cones[J] } #end
  plane { y, -D } // to catch misses
#declare NS = 250;
#declare DA = 360/NS;
#declare MeshCells = array[N];
#for (I, 0, N-1)
 #declare MeshCells[I] = mesh {
  #for (IA, 0, NS-1)
   #declare V1 = vrotate(<1,-1,0>, y*DA*IA);
   #declare V2 = vrotate(<1,-1,0>, y*DA*(IA+1));
   #declare P1 = trace(OtherCones[I], Points[I], V1);
   #declare P2 = trace(OtherCones[I], Points[I], V2);
   triangle { Points[I], P1, P2 }
   triangle { P1, <P1.x, -D, P1.z>, <P2.x, -D, P2.z> }
   triangle { P1, <P2.x, -D, P2.z>, P2 }
   triangle { Points[I]-y*D, <P2.x, -D, P2.z>, <P1.x, -D, P1.z> }
  inside_vector y
#declare Fns = array[N];
#for (I, 0, N-1)
 #declare Fns[I] = function {
   object {
    MeshCells[I]
    rgb 0, rgb BrightFn(Points[I].x, -D+1e-4, Points[I].z).x
#declare WholeFn = function {
 max(
  #for (I, 0, N-1)
   Fns[I](x, -D+1e-4, z).x
   #if (I < N-1) , #end
box {
 <-10, -0.01, -10>, <10, 0, 10>
 pigment { function { WholeFn(x, y, z) } color_map { [0 rgb 0] [1 rgb 1] } }
 finish { diffuse 0.8 ambient 0 }
Date: 23 Nov 2022 13:20:00
Message: <web.637e641ec37f1de01f9dae3025979125@news.povray.org>
Oh - an object pigment pattern.  Brilliant.
I am, however, having problems rendering this.   Could you provide a camera and
look-at position, or a complete version of the scene?
- BW
Date: 23 Nov 2022 14:35:00
Message: <web.637e759ec37f1de096ac14b489db30a9@news.povray.org>
Try this:
#version 3.7;
global_settings { assumed_gamma 1.0 }
    location 20*y
    look_at 0*y
default {
    finish {
        diffuse 0
        emission color rgb <1, 1, 1>
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 23 Nov 2022 14:50:00
Message: <web.637e791ac37f1de0b96893c06f35e431@news.povray.org>
> and look-at position, or a complete version of the scene?
Sure, sorry! I don't know why I didn't just post the whole thing :)
This is what I used:
 location <0, 30, 0>
 up y
 right x*4/3
 angle 50
 look_at <0, 0, 0>
light_source { <500, 400, -300> rgb 1 }
background { rgb <0.8, 0.9, 1> }
Date: 23 Nov 2022 19:10:00
Message: <web.637eb561c37f1de01f9dae3025979125@news.povray.org>
Very cool!
I upped the count to 500 and used the bozo pattern, scale 1 and a 10-value color
map.
This is definitely what we've been after - very nicely done.  :)
I've only just gotten back in, and haven't worked it out in enough detail to
understand exactly how all the parts work.   I tried it with the "POVRAY" point
set, got it to work, dabbled a bit more, and broke it again...
I'm wondering if there are other ways to control the colors of the cells - by
height?  by area?
Very interested in your mortar idea.
Also wondering if the Delaunay triangulation can be done as well.  Rendering the
dual would be a cool effect.
Great work, Bill - this was a very clever solution.
Download 'billpragnellvoronoiconemesh.png' (92 KB)
Preview of image 'billpragnellvoronoiconemesh.png'
Date: 24 Nov 2022 05:50:00
Message: <web.637f4aa5c37f1de022cd71f26f35e431@news.povray.org>
> point set, got it to work, dabbled a bit more, and broke it again...
Everything used to generate the cells gets stored in arrays - try rendering
individual meshes to get a feel for the objects that go into the pigments.
What made me think of this method was a comment someone made in the other thread
that a field of cones could be used to generate a 2D voronoi field. My code uses
a 'depth' of 10, with 45-degree cones - the slice used by the function is just
above this y=-10 floor so tweaking might cause it to miss the objects.
The other thing I'm unsure about is how many arguments the max() function can
accept - this is probably the practical upper limit on the cell count.
> height?  by area?
In that snippet, the BrightFn is what I use to generate the cell value 0-1; a
pigment was the obvious choice, but you might be able to do something with the
stored meshes to generate a suitable function for area... basically anything
that could feasibly be encoded in a function.
I was referring to the custom 'standard' crackle that you demonstrated in your
post, using the min distance from a seed point to generate the color value. The
documentation even mentions using a solid crackle with a regular crackle layered
over it to generate mortar for the solid cells.
> the dual would be a cool effect.
No idea - this is a bit of a hack! I imagine triangulation could be done with an
SDL macro, and then the triangles could be colored however you want... but I
have no experience implementing Delaunay triangulation so I'm not sure.
It was fun to think through! Now if only we could have iteration in user-defined
functions... :)
Bill
Date: 24 Nov 2022 09:15:00
Message: <web.637f7befc37f1de01f9dae3025979125@news.povray.org>
Nope.  I the one I posted was 500, and I successfully ran one with 1500, which
was SLOW.
But also, even if there is an upper limit, just make an aggregating function
that takes the max () of other, max() functions with fewer arguments than the
limit.
"My post" ... I make a lot of them, and I don't think I've posted any with
POV-Ray's native crackle pattern.
> The
Interesting.   I'll have to look at that - way back in 2013, I used this method
for making mortar for my Secret Passage scene.
#declare Pigment_1 =
pigment{ crackle solid turbulence 0.35 scale 0.45
         color_map{
          [0.00 color rgb<1, 1, 1>*0]
          [0.08 color rgb<1, 1, 1>*0]
          [0.40 color rgb<1, 0.55, 0>]
          [1.00 color rgb<1, 1, 0.8>]
         } // end of color_map
} // end of pigment -----------------
#declare Roughness = 2;
//  Flagstone Texture
#declare Texture_1 =
texture {crackle form <-1, 1, 0> metric 2 offset 0.1 cubic_wave turbulence 0
scale 12
         texture_map {
  [0.00 pigment {Clear}]
  [0.01 pigment {Clear}]
  [0.01 crackle solid form <-1, 1, 0> metric 2 offset 0
   texture_map {
   [0.00 T_Stone5  normal {granite scale Roughness}]
   [0.20 T_Stone5  normal {granite scale Roughness}]
   [0.20 T_Stone14 normal {agate scale Roughness}]
   [0.40 T_Stone14 normal {agate scale Roughness}]
   [0.40 T_Stone20 normal {bumps scale Roughness}]
   [0.60 T_Stone20 normal {bumps scale Roughness}]
   [0.60 T_Stone33 normal {ripples scale Roughness}]
   [0.80 T_Stone33 normal {ripples scale Roughness}]
   [0.80 T_Stone43 normal {waves scale Roughness}]
   [1.00 T_Stone43 normal {waves scale Roughness}]
   }]  //  end of inner texture map
          } // end of outer texture_map
 } // end of texture
Yeah - me neither, but I thought maybe you'd have another stroke of genius   :)
Also wondering if, with your existing knowledge of how your code works, if there
was a way to "draw lines" with cylinders around the borders of the cells.
Something to do with the mesh vertices perhaps....
Date: 24 Nov 2022 09:50:00
Message: <web.637f839fc37f1de022cd71f26f35e431@news.povray.org>
> > your post, using the min distance from a seed point to generate the color
> > value.
Sorry; the previous crackle thread from a couple of days ago, with the custom
version you showed that just colors a point based on distance to the closest
seed point.
This one:
http://news.povray.org/povray.binaries.images/message/%3Cweb.6376dd8c302862a41f9dae3025979125%40news.povray.org%3E
> > The documentation even mentions using a solid crackle with a regular crackle
> > layered over it to generate mortar for the solid cells.
> method for making mortar for my Secret Passage scene.
See 3.4.7.2.3 in the online reference help ('Crackle Pattern'). It's only a
brief mention. From your example though, it looks like you're comfortable with
this technique already.
> there was a way to "draw lines" with cylinders around the borders of the
> cells. Something to do with the mesh vertices perhaps....
Hmm that's a thought. It would consist of a large quantity of spheres and/or
cylinders placed around each mesh base, all as a single object pattern. It would
be much slower than using another function texture layer, but it would give an
constant thickness of mortar, which the texture method might not... I'll have to
try this out when I get the chance!
Bill
Date: 24 Nov 2022 11:00:00
Message: <web.637f94a9c37f1de01f9dae3025979125@news.povray.org>
> seed point.
Ah.  "Colors" meaning simple scalar grayscale shading.
I think what they mean is the reverse?
"There is no provision for mortar, but mortar may be created by layering or
texture-mapping a standard crackle texture with a solid one."
It's been a while since I've messed with that, and their language there is a
little - vague.
I was actually thinking not as an object pattern, but as the native lattice of
cylinders.  Make a scene with small spheres as the center points, and make the
Voronoi with cylinder{} objects.
AND, if that's possible - then why not do the Voronoi with prism {} objects.
Then they can all be collected into an array and textured however one wants -
even manually, one at a time.
But there is obviously much to played with here.   How does it look if instead
of using cones, we use spheres, ellipsoids, superellipsoids, pyramids, etc?
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes3_0000e.htm
http://www.f-lohmueller.de/pov_tut/all_shapes/shapes350e.htm
While researching this, I have also seen people use other distance metrics, such
as the "Manhattan distance" or "taxicab distance", etc.
