POV-Ray : Newsgroups : povray.binaries.images : Coffee Mug Server Time
14 Dec 2025 16:53:59 EST (-0500)
  Coffee Mug (Message 1 to 10 of 11)
Subject: Coffee Mug
Date: 29 Jun 2022 04:40:00
Message: <web.62bc0f5dbb3ae47281f62c41607c1b34@news.povray.org>
This is a just-for-fun object. The image on the side of the mug is from a .png
image (also made with POV-Ray, of course) but the image is applied to a thin box
which is divided into lots of narrow segments that are wrapped around the mug.
Have an awesome day folks!
Kind regards,
Dave Blandston
Download 'coffeemug_fde.jpg' (148 KB)
Preview of image 'coffeemug_fde.jpg'
Subject: Re: Coffee Mug
Date: 29 Jun 2022 04:45:00
Message: <web.62bc10722430c20c81f62c41607c1b34@news.povray.org>
This shows what's happening - the thin box is only divided into a few segments.
Download 'coffeemug.jpg' (56 KB)
Preview of image 'coffeemug.jpg'
Date: 29 Jun 2022 06:45:00
Message: <web.62bc2cae2430c20c1f9dae3025979125@news.povray.org>
> Kind regards,
> Dave Blandston
Very nice work - that looks like exactly the approach as Chris Colefax's "object
bender".
http://www.oocities.org/ccolefax/index.html
But ... why didn't you just uv-map it with cylindrical mapping?
or a cylindrical warp
https://wiki.povray.org/content/Reference:Warp
Date: 29 Jun 2022 12:59:03
Message: <62bc84d7$1@news.povray.org>
Am 29.06.2022 um 12:42 schrieb Bald Eagle:
>> Kind regards,
>> Dave Blandston
> bender".
Yes, very nice indeed. But uv-mapping would need a mesh-object. With CSG
it will not work. With CSG an cylindrical image_map would display the
image at the inside of the cup too. If CSG was used, cutaway_texture may
be an option to avoid the repetition in the inside of the cup.
BTW a very nide inside of a coffee mug was posted 09/03/2002 by tincanman:
http://news.povray.org/povray.binaries.scene-files/thread/%3C3d74cad9%241%40news.povray.org%3E/?ttop=437504&toff=850
Best regards,
Michael
Date: 29 Jun 2022 16:50:19
Message: <62bcbb0b$1@news.povray.org>
>>> a thin box
>>> the mug.
>>> Kind regards,
>>> Dave Blandston
>> Colefax's "object
>> bender".
> Best regards,
> Michael
You could apply a plain simple texture to the object used to remove the
interior of the mug. That way, it'll prevent the image from showing on
the inside.
Then, there are other primitives that support UV mapping beside mesh.
You could make the mug as a sor or lathe.
Date: 29 Jun 2022 17:14:37
Message: <62bcc0bd$1@news.povray.org>
An object pigment can be used with the cylindrical warp to avoid the
image on the inside of the mug.  That's how I did my coffee mug:
https://github.com/CousinRicky/POV-CoffeeMug/blob/main/coffeemug.inc
The relevant macros are CoffeeMug_Wrap(), CoffeeMug_Pigment(), and
CoffeeMug_Texture().
Date: 29 Jun 2022 18:50:00
Message: <web.62bcd6ca2430c20c7c4cdde2607c1b34@news.povray.org>
> bender".
Yep I remember Chris Colefax's object bender but I think that what he did was
quite a bit more sophisticated, judging by his walking pencil animation. Here's
another test image that shows the imperfections of my method on objects that
aren't really thin.
The coffee mug was just a fun way to test the macro that divides objects up into
segments.
Kind regards,
Dave Blandston
Download 'curvedborderchars_.jpg' (98 KB)
Preview of image 'curvedborderchars_.jpg'
Date: 30 Jun 2022 03:01:18
Message: <62bd4a3e$1@news.povray.org>
Il 30/06/2022 00:48, Dave Blandston ha scritto:
Colefax's "object
 >> bender".
did was
animation. Here's
objects that
 > aren't really thin.
objects up into
 > segments.
 > Kind regards,
 > Dave Blandston
This image looks also promising, Dave!
The segmentation will leave these "imperfections", but perhaps you can
use a thin box for the surface, and model a separate object for the depth.
Paolo
Date: 30 Jun 2022 05:00:00
Message: <web.62bd65652430c20c7c4cdde2607c1b34@news.povray.org>
Yes that's possible and that's how the coffee cup image was made but my original
goal was to be able to wrap (almost) any object so I was disappointed when it
didn't work out quite the way I wanted. If it had worked out as hoped then my
plan was to allow other types of curves as well - sine waves for example, which
I love. I think this could have produced some interesting animations too! But as
Bald Eagle pointed out, there is a much better utility that can do that already.
I just wanted to learn by doing.
Thanks for the kind words and have a wonderful day!
Warmest regards,
Dave Blandston
Date: 30 Jun 2022 06:30:00
Message: <web.62bd7b052430c20c1f9dae3025979125@news.povray.org>
Having never actually used it, I couldn't honestly say it was "better" for any
particular purpose - and I vaguely recall someone posting images showing similar
limitations - or purposefully enhanced flaws to illustrate the mechanism of
bending.
You already have the coordinates for your text, so what if you "skinned" the
glyphs with a ribbon made of smooth triangles.   Then you could just transform
the vertices as the glyph was bent, and it would smoothly follow the outside
edges?
IIRC, you've already used trace () for some of your lettering work, so maybe
that's an option for other objects as well?
Just thinking aloud.
