POV-Ray : Newsgroups : povray.binaries.images : 3D Text with Sphere_sweeps Server Time
6 May 2026 05:11:10 EDT (-0400)
  3D Text with Sphere_sweeps (Message 1 to 10 of 19)
Subject: 3D Text with Sphere_sweeps
Date: 18 Jun 2022 05:05:00
Message: <web.62ad94fdac40b3a1cf03b124607c1b34@news.povray.org>
In case anyone is interested, here's an easy way to make 3D text using
sphere_sweeps. To get the data points, I made a bit-map image of the letter "L"
and drew several dots along the path of the character. It was a little tedious
to type the <x, y> coordinates of the dots. I suppose it's bad form to use the
third vector component for something unrelated to the first two but it's very
convenient.
In the example picture, the pink "L" in the upper left corner is the original.
The TrueType font is called "Pinyon Script." The blue "L" in the middle is the
sphere_sweep character. Using the orthographic camera causes spots to appear.
The sphere_sweep character is overlaid with the original in the upper right
corner. The bottom shows the sphere_sweep character with a normal camera.
This was a first attempt and I didn't put much effort into placing the dots
along the original letter but it turned out pretty well anyway. Adjusting the
diameter multipliers was pretty easy.
Have a great day everyone!
Kind regards,
Dave Blandston
The code is so short I'll just include it here:
#local NPoints = 32;
#local Coordinate = array [NPoints] { //<x, y, diameter multiplier>
   <516, 451, 1>,
   <513, 457, 1>,
   <475, 485, 1>,
   <422, 497, 1.8>,
   <360, 495, 1.8>,
   <264, 475, 1>,
   <175, 451, 2>,
   <93,  454, 2>,
   <75,  473, 1>,
   <94,  489, 1>,
   <194, 490, 1>,
   <277, 452, 2>,
   <390, 328, 4>,
   <532, 135, 1.5>,
   <579, 93,  1.5>,
   <631, 65,  1>,
   <678, 56,  1>,
   <719, 69,  2>,
   <728, 104, 2>,
   <683, 179, 2>,
   <596, 255, 1>,
   <500, 307, 1>,
   <415, 334, 1>,
   <329, 336, 1>,
   <260, 313, 2>,
   <228, 272, 2>,
   <223, 236, 3>,
   <234, 201, 2>,
   <261, 167, 1>,
   <300, 144, 1>,
   <339, 137, 1>,
   <349, 138, 1>
} //array
#local MinX = 9999;
#local MaxX = 0;
#local MinY = 9999;
#local MaxY = 0;
#for (I, 0, NPoints - 1)
   #if (Coordinate [I].x < MinX) #local MinX = Coordinate [I].x; #end
   #if (Coordinate [I].x > MaxX) #local MaxX = Coordinate [I].x; #end
   #if (Coordinate [I].y < MinY) #local MinY = Coordinate [I].y; #end
   #if (Coordinate [I].y > MaxY) #local MaxY = Coordinate [I].y; #end
#end //#for
#local MaxY = MaxY - MinY;
#local S = 1 / MaxY;
   #local Coordinate [I] = Coordinate [I] - <MinX, MinY, 0>;
   #local Coordinate [I] = <Coordinate [I].x, MaxY - Coordinate [I].y,
Coordinate [I].z> * <S, S, 1>;
#end //#for
#local BaseRadius = .011;
#local ThreeDText = object {
   sphere_sweep {
      b_spline
      NPoints
         <Coordinate [I].x, Coordinate [I].y, 0>, BaseRadius * Coordinate [I].z
      #end //#for
   } //sphere_sweep
} //object
Download 'test.jpg' (48 KB)
Preview of image 'test.jpg'
Subject: Re: 3D Text with Sphere_sweeps
Date: 19 Jun 2022 02:22:20
Message: <62aec09c$1@news.povray.org>
Op 18/06/2022 om 11:03 schreef Dave Blandston:
> convenient.
Fascinating. That went pretty well indeed.
Date: 19 Jun 2022 04:35:00
Message: <web.62aedf9c18b1901cd6bf93276cde94f1@news.povray.org>
hi,
> convenient.
interested, yes (and fascinated, too :-)), and thanks for including code.  the
top-right "overlaid" is very impressive, with only 32 data points.
regards, jr.
Date: 20 Jun 2022 05:50:00
Message: <web.62b0418218b1901ccf03b124607c1b34@news.povray.org>
OK, I finished the word I wanted to make and it turned out fairly well. It's
certainly not perfect but close enough, and I'm pleased with the appearance.
Using a cursive font complicated things a little but forced me to improve the
code. I'll post the improved code in the povray.text.scene-files section.
This picture shows the original TrueType font on the top, the rounded font with
only emission for lighting in the middle, and the rounded font with regular
lighting on the bottom.
Have a wonderful day folks!
Kind regards,
Dave Blandston
Download 'comparison.jpg' (119 KB)
Preview of image 'comparison.jpg'
Date: 20 Jun 2022 19:20:00
Message: <web.62b1000918b1901c22d125f7607c1b34@news.povray.org>
There's a lot of room for improvement...
Download 'untitled.jpg' (128 KB)
Preview of image 'untitled.jpg'
Date: 21 Jun 2022 14:47:18
Message: <62b21236$1@news.povray.org>
How so ?
What we see in those circled areas is exactly as expected.
To smooth out those areas out, you'd probably need to convert the whole
thing into an iso_surface and apply some blobing.
Date: 21 Jun 2022 16:05:00
Message: <web.62b223b718b1901ccf03b124607c1b34@news.povray.org>
Alain Martel <kua### [at] videotronca> wrote:
> How so ?
Yes that's what I'm thinking of trying. Bald Eagle has made some amazing code
that does the smoothing. It's a small detail but I think it would make the
letters look better.
Date: 21 Jun 2022 18:25:00
Message: <web.62b2444b18b1901c1f9dae3025979125@news.povray.org>
> > How so ?
I just translated Inigo Quilez's Shadertoy code into SDL.  I'm sure he got the
basics of that from OpenGL
"jr" wrote:
> that's an interesting page, some of the other posts I scanned cursorily looked
> worth returning to.  thanks.
> (sticking my neck out) I think we'd need WFP to become interested, make 'povr'
> export/make visible the TTF data it (as pointed out) already has, in the parser;
> pass in a text{} and get back metrics, that sort of thing.
Well, I would say that as "purists", we tend to dismiss 3rd party/"other"
software, but I would strongly encourage everyone to explore what's out there
and _make use of_ those software packages and programming languages and use them
as inspiration for functions, macros, and other things that are in SDL.
If I was going to pursue this project, I'd probably start out by contacting
Inigo Quilez or Martijn Steinrucker (Art of Code on YouTube) and asking about
how to write functions to make the required sphere sweep segments.  I'd also
find somewhere to post on the ShaderToy forums to see if anyone has written code
to translate TTF into renderable ShaderToy code.
Look for TTF importing/decoding libraries in languages that you understand.
Perhaps Freya Holmer has done some work on this in relation to ... her ...
presentations on Bezier curves.
Casting about on the internet in places you don't often go can broaden your
horizons, give you new idea and inspiration, and you can _communicate with
people about POV-Ray_ which may spark their interest in some way.
I'm confident that a lot of the necessary steps can be done in SDL, but perhaps
there's a simple command-line thing that will spit out the bezier spline control
points of the segments that make up the glyphs in a font.  Then you could use
that to generate a text file for use in POV-Ray.
I'd say first get it to work, then if you want, you can do the programming
needed to gather it all into an SDL-only scene file.
But rule #1 is usually "See if this has been done before" and use other people's
code - it will save a ton of time, mistakes, and debugging frustration.
The other point/aside I wanted to make, is that if there was a way to make a
signed distance function for the whole glyph, then you could probably just code
them at an undersized diameter, and then "inflate" them to get the rounding
automatically, but I think that would be a very very long shot, and probably not
something that would lend itself to automation.
Date: 23 Jun 2022 13:01:18
Message: <XnsAEBFC17E328D2seed7@news.povray.org>
in news:web.62b1000918b1901c22d125f7607c1b34@news.povray.org Dave
Have you considered blob-sweeps? You could use the .z in the vector for
the strength of the blob.
https://ingoogni.nl
Date: 23 Jun 2022 17:30:00
Message: <web.62b4d93618b1901cb80481b2607c1b34@news.povray.org>
This looks like a solution. If the b_spline function could be converted to SDL
in such a manner that it would generate points and corresponding diameters at
specific intervals (the distance between points would have to remain constant
regardless of the curvature) then a blob element could be placed at each point
and the diameter could be converted to a blob strength.
This works perfectly when the two character strokes that are intersecting each
other differ greatly in diameter but when their diameters are similar then a
little bump results so some tweaking would be necessary.
Thanks for the suggestion Ingo! Even if the b_spline math turns out to be beyond
my capabilities, I think you have provided a solution. More testing would be
necessary to make sure that tight turns don't cause blob elements to connect
that shouldn't connect.
Here's the test code that generated the sample image:
#local BlobStrength = array [2] {.8, .4}
#local DeltaTheta = .1;
blob {
   threshold 20
   #for (I, 0, 1)
      #for (Theta, 0, 360 - DeltaTheta, DeltaTheta)
         sphere {<cos (radians (Theta)) * 6 + 4 * (I * 2 - 1), sin (radians
(Theta)) * 6, 0>, BlobStrength [I], 1}
      #end //#for
   #end //#for
} //blob
Download 'blob.jpg' (83 KB)
Preview of image 'blob.jpg'
