POV-Ray : Newsgroups : povray.binaries.images : POV-Ray still alive? Server Time
23 Aug 2025 17:57:14 EDT (-0400)
  POV-Ray still alive? (Message 1 to 10 of 12)
Subject: POV-Ray still alive?
Date: 24 Feb 2022 18:35:00
Message: <web.62181422d4ef64a1b2f6df7924d82e4@news.povray.org>
Hi there. Long time no see. As far I can see, development has stalled since aug
2021. Can someone update me briefly ? Is Christoph (Lipka) still with us ?
Regards
Bruno.
Subject: Re: POV-Ray still alive?
Date: 26 Feb 2022 04:31:09
Message: <6219f35d$1@news.povray.org>
> Regards
> Bruno.
I see POV-Ray as 'alive' so long as people use it and are creating new
code for 'this and that'.
As for official v3.7/v3.8/v4.0 support and development, I see what you
see. It's been quiet since mid 2021.
Aside: I found myself using your elliptic_torus code again last fall! :-)
Bill P.
Date: 26 Feb 2022 05:40:00
Message: <web.621a02e445c430be7283012224d82e4@news.povray.org>
> > Regards
> > Bruno.
> Hi,
> Bill P.
Thanks for the update! But what about Christoph? Glad you use some of my code,
though I absolutely do not remember what it is about !!! Lol!
I was wondering about POV's health and about Christoph because I recently find
myself with some fee time. I decided to get back to POVing, just like that. And
I saw the situation.
HOWEVER, and despite that situation, the dictionary container gave me the idea
that it could be possible to imagine using them for classes, instances and some
fundamental Object Oriented features. I think that if it happens to be feasible
and if it happens to be usable without syntactic over-complexity or
non-readabiliy, I could be open the object-orientedness for POV-Sdl. It could
help for complex scenes, animation, whatever an object-oriented language is
handy (or necessary).
So, I had it a try.
AND I reached something quite fine (though it is just a Proof Of Concept until
now)...
I could implement :
    classes,
    instances,
    properties,
    methods,
    inheritance,
    overloading for contructors and methods,
    named parameters,
    new(), super(), instanceof() operators,
    type-ckecking,
    templates,
    and a few other minor OO features.
Do you think it could be interesting for the POV community ? For fun, I named it
PROOF (Pov Ray Object Oriented Features).
Bruno
Date: 26 Feb 2022 06:15:00
Message: <web.621a0ab745c430be7283012224d82e4@news.povray.org>
> > > Regards
> > > Bruno.
> > Hi,
> > Bill P.
> So, I had it a try.
> now)...
> I could implement :
>     classes,
>     instances,
>     properties,
>     methods,
>     inheritance,
>     named parameters,
>     type-ckecking,
>     templates,
> Bruno
I googled for the elliptical-torus thing. I rewinded back to 2006 !!!! It is
soooooo long ago ! But it is a decent piece of code. I hope it is still
meaningful.
Bruno
Date: 26 Feb 2022 12:02:45
Message: <621a5d35$1@news.povray.org>
>> Hi there. [snip]
> [snip]
What!?  Where?
Date: 27 Feb 2022 04:05:12
Message: <621b3ec8$1@news.povray.org>
He's not been recently active is all I know.
> So, I had it a try.
> now)...
> I could implement :
>      classes,
>      instances,
>      properties,
>      methods,
>      inheritance,
>      named parameters,
>      type-ckecking,
>      templates,
I like the acronym. :-)
Certainly of interest, especially, as a way to flesh out ideas for a
potential v4.0 SDL concepts/syntax.
Ingo and jr in particular have been pushing ideas using the dictionary
feature of v3.8/v4.0 over the pass 3-4 years. I also picked up TOK's
newer dictionary based array statistics code as a stand alone
arraystatistics.inc in my povr fork.
Practically, you might come up against issues.
Being based atop current parsers, performance a concern. As 'proof' of
concept code this will matter less.
To be sure you are aware. In 2018 and early 2019 Christoph was
significantly changing the internals of the - then v3.8 - parser. At
that point all development stalled for roughly 2 years starting in early
2019 until Christoph resumed working on POV-Ray for some months in 2021.
On his return in 2021 he broke development into a v3.8 release path
where he backed out code he considered to be too new for a near term
v3.8 release. This included backing up the parser code to an earlier
v3.8 state. The newest parser code still exists in the master branch
which is now more or less aimed at v4.0. Both parser versions are -
today - SDL / language feature equivalent (excepting a few fringe cases).
However, last I knew, there were remaining parser issues in both
implementations. IIRC there is at least one dictionary issue still in
v3.8 fixed in v4.0.
My personal povr branch is based on the newer (v4.0) version of the
parser code which 'was' in v3.8 when I forked off the povr work. I
'believe' all the v4.0 parser 'bugs' of which I am aware have been
addressed in the povr branch. In aspects the parser in povr has evolved
into another 'internal' parser implementation - though again the SDL
feature set is substantially v3.8/v4.0 equivalent today.
New v4.0 SDL concepts/syntax and radical changes to the parser are not a
presently a focus for me as I play with POV-Ray. I end up in the parser
code when something needs to be understood / fixed - or it's otherwise
in my way.
Aside: Our existing scene description language (SDL) - as a language -
supports certain object oriented 'concepts' today. Our implementation
doesn't back them in a consistent way and so people tend to avoid the
approach. The situation due internal coding choices and, often as not,
bugs.
For example, something like the following is supposed to work in POV-Ray
today with fog, but it doesn't(1). The internal structure and code is
all there - but for bugs.
(1) - You can write similar parser clean code, but in the rendering
details it very often isn't working.
Using the povr fog example (povr's fog and related keywords somewhat
different) and today's SDL:
#declare Fog01 = fog {
     type 1
     distance 9.5
     color Grey70
#declare Fog01_wTurb = fog {
     Fog01
     it_scale <1.6,0.16,1.6>
     it_depth 2.1
     it_octaves 5
     it_omega 0.35
     it_lambda 1.25
#declare Fog01_neg_it_depth = fog {
     Fog01_wTurb
     it_depth -2.1
#declare Fog01_blend_gamma = fog {
     Fog01_wTurb
     blend_gamma 2
#declare Fog01_inverse = fog {
     Fog01_wTurb
     inverse
#declare Fog01_range = fog {
     Fog01_wTurb
     range 7, 20
     blend_gamma 2
#declare Fog03_rotate = fog {
     Fog01_inverse
     type 3
     rotate z*45
Bill P.
Date: 27 Feb 2022 04:07:39
Message: <621b3f5b$1@news.povray.org>
>>> Hi there. [snip]
>> [snip]
> What!?  Where?
:-) This isn't what you want, though it was created during an earlier
attempt at what you want.
(This code torus via sphere_sweep, and a blob ~equivalent sphere sweep)
Bill P.
Date: 27 Feb 2022 04:35:00
Message: <web.621b459045c430be7283012224d82e4@news.povray.org>
> > So, I had it a try.
> > now)...
> > I could implement :
> >      classes,
> >      instances,
> >      properties,
> >      methods,
> >      inheritance,
> >      named parameters,
> >      type-ckecking,
> >      templates,
> v3.8 fixed in v4.0.
> in my way.
> bugs.
>      type 1
>      distance 9.5
>      color Grey70
>      Fog01
>      it_depth 2.1
>      it_octaves 5
>      it_omega 0.35
>      it_lambda 1.25
>      Fog01_wTurb
>      it_depth -2.1
>      Fog01_wTurb
>      blend_gamma 2
>      Fog01_wTurb
>      inverse
>      Fog01_wTurb
>      range 7, 20
>      blend_gamma 2
>      Fog01_inverse
>      type 3
>      rotate z*45
> Bill P.
Thanks for the update! I'll have a closer look to your povr fork (on github?).
But I still would like news from Christoph...
Let me talk a bit more about PROOF (object oriented layer over POV-Ray Sdl) in
'programming' thread.
PS : In the first place, I named it SLOPE : Syntactic Layer Over Povray and
Extensions...).
Bruno
Date: 28 Feb 2022 04:19:43
Message: <621c93af$1@news.povray.org>
It is locally under git code control, but thus far, it's been published
a few times a year here as a small tarball - a code contribution to
'POV-Ray.' I'm working toward another tarball in March. The povr branch
is unix/linux/osx only and ever drifting away from POV-Ray proper in
functionality and behavior.
I mentioned it because the source code contains many hundreds of fixes
and changes which can be applied to the POV-Ray code base in some
fashion - including the parser(s). If you do get hung up on a parser
bug, you might find a fix or work around for it already in the most
recent tarball of povr code. I also try and publish information about
common problems and fixes found while playing with povr here on the
newsgroups or on github.
If you are after mainstream users, I think you should stick with POV-Ray
proper. Any official resumption in development won't come from me.
Be cognizant too the dictionary feature is new to v3.8, which has not
been officially released. This means V3.8 is not the version most active
users run. For example, anyone on a common linux distribution installing
via a standard POV-Ray package is getting v3.7.
Bill P.
Date: 28 Feb 2022 12:15:24
Message: <621d032c$1@news.povray.org>
Hi(gh)!
As long until a Russian mid-range nuclear missile vaporizes Cologne...
I don't think POV-Ray would survive World War III!
See you in Khyberspace!
Yadgar
