Happy New Year all - here's a sample of my latest iteration!
I decided that the galleries-only approach wasn't sufficiently varied when
scaled up to more complex structures, so I've added a new dimension: buildings!
And this turns out to be a whole other axis of bugs and possible improvements :)
The modular nature of the existing code means I can use the same floors indoor
as out - you can see the sides of the floor cells along the walls. In a similar
way, the building walls and rooftop sides are all placed depending on their
nearest neighbours, so in theory the building internals are sensible too
(although I haven't poked a camera indoors to check yet). The main issue yet to
be resolved is that many balconies end up orphaned with only a blank wall (I
didn't want to put doors into every balcony wall, because then there are too
many). I think I need some way to walk connected floors and make sure there's at
least one door into each area.
The current order of play is:
1) Place building cells according to building-container geometry
2) Place rooftop cells on top of building cells
3) Place gallery cells according to gallery-container geometry
4) Place staircases according to gallery cells
5) Build geometry for the grid, using the increasingly complex condition-monster
to place sides to the various types of cell.
This image parsed in 9 seconds and rendered in 7 minutes. I spent some more time
optimizing the geometry before starting work on the buildings, so everything is
now built from predeclared meshes copied into place, making large grids more
feasible.
Bill
Download 'autobuild7.jpg' (196 KB)
Preview of image 'autobuild7.jpg'
Subject: Re: Floors, rails, stairs, roofs and buildings
Date: 3 Jan 2022 12:01:14
Message: <61d32bda$1@news.povray.org>
when
buildings!
improvements :)
It starts to get even more intriguing...
Paolo
That's... magical! I can't even begin to understand how complex your code must
be, to get such a 'coherent' and integrated result. Great work.
It reminds me of an iceberg-- with most of the berg 'under the water'.
