POV-Ray : Newsgroups : povray.binaries.images : Stone with Veins Server Time
12 Dec 2025 01:15:59 EST (-0500)
  Stone with Veins (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Stone with Veins
Date: 28 Dec 2021 05:00:00
Message: <web.61cadfacc205c2d42636f1af607c1b34@news.povray.org>
> If
> Dave agrees I would like somehow to integrate that in Granite 21, when I
> can get to it.
> Is there a reason why you chose to use hex colours?
Please feel free to use the code in whatever way you wish!
There's no reason to keep the hex colors. The reason I used them is because I
use the color picker tool in Paint.net to sample colors from pictures and it's
much easier and quicker to copy and paste a single hexadecimal color code from
Paint.net to POV-Ray instead of three separate RGB values. If one set of colors
is used for the stone and a second set of colors is used for the veins then
there could be quite a number of copy-and-pastes.
Have an awesome day!
Kind regards,
Dave Blandston
Date: 28 Dec 2021 11:45:00
Message: <web.61cb3ddfc205c2d44cef624e6e066e29@news.povray.org>
> ...The reason I used them is because I
> use the color picker tool in Paint.net to sample colors from pictures,,,
Ah, a fellow Paint.net user ;-) I'm currently running Windows 10; my previous
go-to app for graphics work was an *old* version of Photoshop (which ran under
Windows XP and even 7 with some fiddling), so it is taking me awhile to learn
workarounds for some of PS's more advanced features.
> I made a brief attempt to add iridescence. With some fine-tuning it might
> work...
Your result is really beautiful, and those veins look...real! That's a great
technique you've come up with; I plan to look at your code, thanks for posting
it.
Date: 28 Dec 2021 15:35:00
Message: <web.61cb73edc205c2d42636f1af607c1b34@news.povray.org>
I bought the last version of Photo Shop before it became subscription-only and
it's invaluable of course but I prefer the speed and simplicity of Paint.net
whenever possible, which I find is most of the time.
> it.
Thanks for the generous compliment, just be warned: trial-and-error is
necessary. The final result depends on how the texture layers randomly stack up.
The current code is not at all sophisticated in it's ability to be controlled in
a predictable manner. However, POV-Ray is a wonderful thing and that can
certainly be accomplished!
One more thing that might be worth exploring is the selection of color(s) that
make up the transparent portion of each layer. Currently, the transparent
portions are set to Black or White (via the variable "WhiteLevel"). Using a
value greater than one or less than zero is also interesting.
There are lots of possibilities to explore. I discovered that layered textures
don't work quite the way I thought they did, they work better than I thought.
Thank you once again POV-Ray programmers!
Kind regards,
Dave Blandston
Date: 30 Dec 2021 08:40:32
Message: <61cdb6d0@news.povray.org>
So here we go.
I took my Granite_21 array for Dakota Red and extracted colour pairs. I
also changed the reflection block because I guess the original
reflection is way too strong. I used the reflection as given in
Granite_21. A couple of further, inconsequential, changes et voilà.
This is the finish block I used:
   finish {
     diffuse albedo 0.5 brilliance 1.5
     specular albedo 0.9 roughness 0.0025
     fresnel on
     reflection {0.1  fresnel on}
     conserve_energy
I used 10 layers and scaled the final texture on the object. I could
also have used much more layers (e.g. 100) and scale the texture
somewhat less, with a similar result but a bit more confused imo.
Again, this is a great piece of work, Dave! I need to dig deeper now. ;-)
Download 'db_granite_test2_1.jpg' (85 KB)
Preview of image 'db_granite_test2_1.jpg'
Date: 31 Dec 2021 00:50:00
Message: <web.61ce98d1c205c2d42636f1af607c1b34@news.povray.org>
You would be shocked at what a mess I've made of the lighting and texturing in
the scene that this came from so yes the finish would need a lot of fixing. I've
always had trouble with that part of POV-Ray...
Ten layers is much more reasonable than a hundred and your excellent results
prove it. I admit that a hundred layers is a bit of overkill. (Sometimes I tend
to be a bit of a perfectionist. I don't quite have OCD, but I do have CDO which
is similar, but with the letters in alphabetical order like they're supposed to
be.)
I've been using this sample image as a Granite_21 reference point:
https://news.povray.org/povray.binaries.images/attachment/%3C6089814e%40news.povray.org%3E/dakotagrains_sn_test.jpg
This one represents near perfection in my opinion (the color samples I used came
from that picture, by the way). But I agree, both methods produce great results
and I'm more excited than ever regarding Granite_21. Thanks for sharing your
preliminary results!
Kind regards,
Dave Blandston
Date: 31 Dec 2021 10:41:14
Message: <61cf249a@news.povray.org>
Op 31-12-2021 om 06:44 schreef Dave Blandston:
I agree. Sometimes finish can be straightforward, but especially with
reflections, there are tricky things to take care of.
> be.)
In fact, I can imagine cases where a hundred layers would be be alright.
The attached image shows, side by side, the granite as rendered with
your code (and 100 layers) at left, and as rendered with Granite_21, at
right. Both methods imo are valid, depending on what you want to
achieve. I focussed much more on the creation of individual grains
(which clearly has its drawback and limitations) while I think your
method is almost more intuitive/natural looking. In any case, I like it
quite a lot.
Best wishes for the New Year, take care! Extended to all Povers!
Download 'db_granite_test2_4-5.jpg' (239 KB)
Preview of image 'db_granite_test2_4-5.jpg'
Date: 31 Dec 2021 11:25:42
Message: <61cf2f06@news.povray.org>
My finish suggestion was not entirely correct. Better to use the
following (as a material, btw):
#local S = .2;
#declare StoneColor =
material {
   interior {ior 1.6}
     StoneColor
     finish {
       specular albedo 0.9*0.5 roughness 0.0025  //roughness 0.005 =
less proeminent
       fresnel on
       reflection {0.01 0.1  fresnel on}
       conserve_energy
     normal {granite .025 scale <S, S, S>}
Date: 31 Dec 2021 14:20:00
Message: <web.61cf5796c205c2d42636f1af607c1b34@news.povray.org>
> quite a lot.
Applying your material made a big improvement in the area of realism. Thanks for
sharing it!
And Happy New Year to everyone!
Best regards,
Dave Blandston
Date: 31 Dec 2021 14:40:50
Message: <61cf5cc2@news.povray.org>
>> texturing in
>> fixing. I've
>> results
>> (Sometimes I tend
>> CDO which
>> supposed to
>> be.)
>> used came
>> great results
>> sharing your
> quite a lot.
The left one hints of a big piece while the one on the right fits better
foe a small one.
Date: 31 Dec 2021 16:05:00
Message: <web.61cf6fb4c205c2d42636f1af607c1b34@news.povray.org>
> foe a small one.
Interesting point.
