POV-Ray : Newsgroups : povray.binaries.images : A rocky surface Server Time
18 Nov 2025 02:34:07 EST (-0500)
  A rocky surface (Message 1 to 10 of 12)
Subject: A rocky surface
Date: 9 Nov 2021 19:01:05
Message: <web.6185d34b8db3b86acb705ca46e741498@news.povray.org>
Here's something I was working on a while back. Zoom to 100% to see all the
details.
The height field's map was generated using a cellular automaton in GLSL. For a
real-time demonstration, see this: https://www.shadertoy.com/view/ftSSDy (Your
system will need to be able to support pixel shaders.)
In order to be able to save a proper height map, the shader code was ported to a
Windows GLSL app that supports higher bit output and arbitrary resolutions.
To get deep shadows, a proximity pattern was generated by subtracting a blurred
copy of the height map from the original using a function. The scene was
rendered with basic radiosity and low aa settings.
The whole idea behind this was to make height maps that are suitable for
bedrock, and possibly crystalline surfaces.
Sam
Download 'growing-weathing-rocks-render2m_25s.jpg' (786 KB)
Preview of image 'growing-weathing-rocks-render2m_25s.jpg'
Subject: Re: A rocky surface
Date: 10 Nov 2021 02:24:57
Message: <618b73c9@news.povray.org>
Op 06/11/2021 om 01:58 schreef Samuel B.:
> Hi,
> details.
> Sam
Impressive indeed. It /looks/ like a seamless image, is that so? Would
it be possible to introduce some random size variation in terms of
bigger chunks of rocks contrasted to smaller ones? The present
impression is of a rather uniform size, overall, which is telltale for a
non-natural origin. However, well-done indeed.
Date: 10 Nov 2021 17:25:00
Message: <web.618c469db5460525cb705ca46e741498@news.povray.org>
> > Hi,
> > details.
Thanks, Thomas.
Good eye. The input height map is indeed seamless, but the entire result is not,
since a 1/3 scaled-down copy was layered over the original.
Yeah, the feature sizes are very regular, unfortunately. This is a problem
caused by the CA I used, but also my choice to scale down the layered copy
instead of scaling up. The CA itself can probably be adjusted to produce larger
features, to a point. But the only real way to make something like this work
would be to make a full-on 3d simulation, not 2.5d like this. But I haven't yet
found a good library to evaluate 3d textures, and the only other way I know
(doing it with traditional arrays [on the CPU instead of GPU]) is just too slow.
I could technically do it, but watching the result in real time would not be
possible since I would also have to perform raymarching using the CPU, thus
bogging everything down.
Sam
Date: 12 Nov 2021 15:55:00
Message: <web.618ed39eb5460525eb56e5a5b7ae6630@news.povray.org>
"Samuel B." <stb### [at] hotmailcom> wrote:
> Hi,
> details.
> Sam
Impressive as usual Sam,
First I thought you used a povray pigment for an isosurface,
so I decided to replicate it with crackle solid form z
offset 5 metric 100000 (averaged, scaled and turbulated of
course), but I didn't get it up to now...
Stay healthy,
Norbert
Date: 12 Nov 2021 17:46:34
Message: <618eeeca$1@news.povray.org>
Il 06/11/2021 01:58, Samuel B. ha scritto:
 > Hi,
 > all the details.
 > GLSL. For a real-time demonstration, see this:
 > https://www.shadertoy.com/view/ftSSDy (Your system will need to be
 > ported to a Windows GLSL app that supports higher bit output and
 > a blurred copy of the height map from the original using a function.
 > The scene was rendered with basic radiosity and low aa settings.
 > for bedrock, and possibly crystalline surfaces.
 > Sam
Really beauty, as always, Sam!
Paolo
Date: 12 Nov 2021 18:25:00
Message: <web.618ef717b5460525cb705ca46e741498@news.povray.org>
> > Hi,
> > details. (...)
Hi Norbert,
I can't remember what offset does, and I have no idea what a metric value of
100k would look like. What was the result like?
I've always liked your images, btw. Natural subjects have always been the
hardest to create.
Sam
Message: <web.618ef779b5460525cb705ca46e741498@news.povray.org>
>  > Hi,
>  > all the details. (...)
Thanks, Paolo! I thought I'd post the result, even if it doesn't make its way
into a scene someday.
Sam
Date: 19 Nov 2021 13:55:00
Message: <web.6197f274b54605256eb44466112415a2@news.povray.org>
> Hi,
> details.
> Sam
oh, you already deal with GLSL...
Date: 20 Nov 2021 10:45:00
Message: <web.61991743b54605251f9dae3025979125@news.povray.org>
"nemesis" <nam### [at] gmailcom> wrote:
> I think you povray folks would like something like this:
> https://twitter.com/zozuar/status/1461524656532471811
That is some CRAZY stuff right there...  :O
Converting that to an isosurface is likely entirely possible, and would give me
a huge headache.
Also, what you're basically saying is that Detroit, MI is a fractal computer
simulation...
Yes - Sam is responsible in large part for turning me on to the magic of
ShaderToy.  Super fun and educational.  :)
Date: 21 Nov 2021 23:15:00
Message: <web.619b1823b5460525279eb8f7112415a2@news.povray.org>
> a huge headache.
> simulation...
we're living in the future, guys. Modeling scenes entirely in VR is pretty
mind-blowing too.
