![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi everyone,
Could someone help me understand what's happening in the image attached please ?
I have a camera on the +x axis looking at the origin and a box rotating around
the x axis.
With the default camera (WithRight=0), I obtain what I'm expecting. The +z axis
is toward the right of the image and the box rotates clockwise.
Now if I specify explicitly the right vector of the camera to be like in the
first image toward the +z axis (WithRight=1), the +z axis is now toward the
left of the image, and the box rotates counter clocwise, but +x still points
toward the camera. I would expect to have the same image as (WithRight=0).
Also, if I set the right vector to -z (WithRight=2), I obtain the same image as
with +z, which is puzzling me, as I would expect it to invert the handedness of
the axes.
Reading the documentation:
http://wiki.povray.org/content/Reference:Camera#Up_and_Right_Vectors
doesn't help me understanding what I'm getting wrong. Could someone help me ?
I paste the code below if you want to try it.
#version 3.7;
background { color rgb 1.0 }
#declare WithRight=0;
#declare cameraPos = 3.0 * x;
#declare cameraLookAt = 0;
location cameraPos
look_at cameraLookAt
#if (WithRight = 1)
right z * 1.5
#if (WithRight = 2)
right -z * 1.5
light_source {
100.0
color rgb 1
#declare Target = box {
<-0.5,-0.5,-0.5>
<0.5,1,0.5>
color rgb 0.5
object {
Target
rotate x
translate -z
object {
Target
rotate x * 10.0
object {
Target
rotate x * 20.0
translate +z
union {
cylinder { 0, x, 0.01 texture {pigment {color x}}}
cylinder { 0, y, 0.01 texture {pigment {color y}}}
cylinder { 0, z, 0.01 texture {pigment {color z}}}
translate x
no_shadow
Download 'axisrot.jpg' (103 KB)
Preview of image 'axisrot.jpg'
![axisrot.jpg](/povray.binaries.images/attachment/%3Cweb.5fd5c20ee1ddd2e62ce8b2430%40news.povray.org%3E/axisrot.jpg?ttop=443824&toff=400&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 13/12/2020 om 08:26 schreef BayashiPascal:
> Hi everyone,
> the x axis.
> the axes.
> #version 3.7;
> camera {
> location cameraPos
> #if (WithRight = 1)
> right z * 1.5
> #end
> #if (WithRight = 2)
> right -z * 1.5
> #end
> light_source {
> 100.0
> color rgb 1
> <-0.5,-0.5,-0.5>
> <0.5,1,0.5>
> texture {
> pigment {
> color rgb 0.5
> object {
> Target
> rotate x
> translate -z
> object {
> Target
> rotate x * 10.0
> object {
> Target
> rotate x * 20.0
> translate +z
> union {
> translate x
> no_shadow
It seems that you have not explicitly added a 'direction' vector. By
default, it is <0,0,1> where the camera location is pointing along the
z-axis by default. However, as your camera is pointing towards -x, the
default direction may have put you in trouble. Try: direction <-1,0,0>
When using non-standard camera settings, do not rely (too much) on the
default values!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks a million Thomas!
Specifying the 'direction' vector as you suggested solved my problem. I was
thinking it's automatically calculated based on the 'location' and 'look_at'
vectors.
Thanks again :-)
(in case you wonder what I'm doing with such non standard settings: I'm working
on a project where the Pov-Ray script is automatically generated by another
program which calculates, among other things, the camera's attitude)
Pascal
> > Hi everyone,
> > the x axis.
> > the axes.
> > #version 3.7;
> > camera {
> > location cameraPos
> > #if (WithRight = 1)
> > right z * 1.5
> > #end
> > #if (WithRight = 2)
> > right -z * 1.5
> > #end
> > light_source {
> > 100.0
> > color rgb 1
> > <-0.5,-0.5,-0.5>
> > <0.5,1,0.5>
> > texture {
> > pigment {
> > color rgb 0.5
> > object {
> > Target
> > rotate x
> > translate -z
> > object {
> > Target
> > rotate x * 10.0
> > object {
> > Target
> > rotate x * 20.0
> > translate +z
> > union {
> > translate x
> > no_shadow
> default values!
> Thomas
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 13/12/2020 om 09:58 schreef BayashiPascal:
> vectors.
> Thanks again :-)
> Regards,
> Pascal
You are welcome.
I have become attentive to the 'handedness' of external cameras vs
POV-Ray (left-handed classic), with the use of Moray (right-handed, but
different) and Silo (right-handed classic).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The absence of a unique standard is really a pain when one needs to work with
several systems at the same time. I currently have to deal with a mix of
Pov-Ray, Blender, Open3D, RealSense and Universal Robot. It's a mess :-)
Maybe one day in the far future they will all agree on one standard, but I don't
hope to enjoy that moment in my lifetime!
> > vectors.
> > Thanks again :-)
> > Regards,
> > Pascal
> You are welcome.
> Thomas
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
