I just stumbled across this while trying to regain my sanity,
and if even Ramanujan couldn't come up with anything but an approximation, than
I think the rest of us are Fuuuuuuuuuuuuuuuuuuuuuumbling around in the dark.
https://www.youtube.com/watch?v=5nW3nJhBHL0
But don't anyone think that that will stop us from making another attempt, using
new inspiration and mathematical tools!
I think the above implies that due to the interesting properties of ellipses,
that a workable solution will use numerical methods.
You watch Matt Parker to regain your sanity? I have some of his videos
languishing in my "Watch later" list because I'm afraid I'll *lose* my
sanity if I watch them.
I am not convinced that this property is directly relevant to the
problem I am trying to solve. I still think the key is in that quartic
equation I came up with, which should not require numerical methods
(beyond what's implicit in POV-Ray's built-in functions). The problem
is that I am not practiced in solving quartic equations.
P.S. I have known since 2007 that there is no exact formula for an
ellipse's circumference. I discovered that while trying to weld this
'O' to the rectangular plate using an ellipse made out of blobs.
Download 'povanized-b.png' (100 KB)
Preview of image 'povanized-b.png'
After spending most of the weekend trying to work out partial differential
equations of 2D Bernstein polynomials, and Gaussian curvature?
Sure.
After that, lifting boxes at work on Monday was relaxing :D
Watching Daniel Shiffman would throw me over the edge, because it's
comedy/tragedy of errors, but I'm learning "important" things at the same
time.... It's like elective surgery with insufficient anaesthetic.
And, take a pre-emptive Advil for this one...
https://www.youtube.com/watch?v=YueAtA_YnSY
Dumb question, but is there an online solver?
A language with the proper symbolic logic?
Cheat and get the right answer first, then use that knowledge as a light to
guide you along the path of working out the quartic.
It's always the "simple" things, isn't it?
Sir, Yes Sir !
mathworld wolfram (alpha) has such beast.
It take a bit of learning to get it do what is desired, but there is
some examples along the pages.
You can ask it to refactor, solve (even based on chosen parameters), and
far more.
We are more in algebra than geometry.
https://www.wolframalpha.com/examples/mathematics/algebra/
I think the elliptical torus with a minor radius of 0 should match the
equation of the ellipse.
That's the basic check of any solution: minor radius of 0 would simplify
the equation to an ellipse.
The difficulty is going backward: reintroduce a non-0 minor radius.
I tried to play a bit with the hope to transform the quartic equation of
circular torus into elliptical torus.
From (sqrt(x²+y²)-R)²+z²=r², replacing x²+y²=R² with (x/a)²+(y/b)²=1
And it is deception.
x^4/a^4
+ (2 x^2 y^2)/(a^2 b²)
- (2 r^2 x^2)/a²- (2 x^2)/a²
+ (2 x^2 z^2)/a²
+ y^4/b⁴
- (2 r^2 y^2)/b²- (2 y^2)/b²
+ (2 y^2 z^2)/b²
+ r⁴- 2 r²+ 1
- 2 r^2 z²+ 2 z²
+ z⁴
Because the scaling of x & y also influence the radius of the minor circle.
But it must be possible to have it with a 4th degree poly.
If F( Point ) is such polynomial, we have the following requirement
F( 0, +/- B , +/- Minor ) = 0 (point B)
F( +/- A, 0, +/- Minor ) = 0 (point A)
F( 0, +/- B +/- Minor, 0 ) = 0 (points M & N)
F( +/- A +/- Minor, 0, 0 ) = 0 (points K & L)
I guess, but cannot yet assert, that to avoid compressing the minor
circle, the z⁴, x⁴ and y⁴ must be 1.
And there might be some non-traditional power of x,y and z (aka odd) in
the non-null coefficient, which would disappear when A=B to have a
continuity with the circular torus.
Also, any point W On the central ellipse with z=+/- Minor is also F(W)=0
And if any more point is needed, there is the two minor circle at A & B
to explore more deeply than K, L, M & N.
Is that enough to try some spreadsheet solver, and how to do it ?
Download 'torusellipse.png' (91 KB)
Preview of image 'torusellipse.png'
So....
After the whole "surround a function with a tube" got explored (and still not
completely sorted out in my head), my brain decided to alert me that therein
might lay the possible solution to this problem.
I copy-pasted some code, fought with Phi again, "won", and got an elliptical
shaped torus. For a=2, b=1.5 it looked good, but the problem had always been
the eccentric tori. a=4 and b=0.75 revealed the same old problem.
I can't find the thread where you list the required specifications, but I don't
think that it's possible using a cross-sectional circle of a constant radius.
Because that's what we're doing with the tube method. And this doesn't give
inner and outer curves that are themselves ellipses.
https://www.frassek.org/3d-mathe/funktionsgraph-als-rohr-r%C3%B6hre/
https://image.jimcdn.com/app/cms/image/transf/dimension=1920x400:format=gif/path/scee86bccd27a6ab2/image/i16edd265f402b
f7c/version/1580469937/image.gif
We can get signed distance functions,
https://iquilezles.org/articles/distfunctions2d/
https://www.shadertoy.com/view/4sS3zz
and we know that we can calculate the tangent and normal vectors to the central
ellipse.
What I'm thinking right now is that we can ditch trying to create the whole
surface and focus on the 3 ellipses - the central, and the inner and outer. If
the inner and outer aren't the same distance away from the central curve along
the normal vector, then I'd say that this demonstrates that a solution isn't
possible, given the parameters.
I think I ran into this issue with Mike Horvath wanting ellipsoid shells -
simply scaling an ellipsoid doesn't give a constant-distance shell from the
original ellipsoid. But those ARE ellipsoids themselves. And calculating a
constant-distance shell would give objects that WEREN'T ellipsoids.
I'mm betting that those level sets of the signed distance function of an ellipse
- aren't ellipses.
So I think that some of the constraints are mutually exclusive.
Download 'tubememe.jpg' (71 KB)
Preview of image 'tubememe.jpg'
Referenced in that code is this article with some comprehensive treatment of the
quartic equation.
https://iquilezles.org/articles/ellipsedist/
> ... I'd say that this demonstrates that a solution isn't
However; depending on if the design parameters can be modified and still provide
an acceptable solution to the intended goal:
Perhaps an elliptical "torus" that is in reality a Dupin cyclide would be just
the thing:
https://en.wikipedia.org/wiki/Dupin_cyclide#Elliptic_cyclides
- BW
> the thing:
> - BW
So, for whatever reason, my brain revisited this, and I wanted a quick
evaluation of if my intuition about using a cyclide in place of an actual torus
would work.
enjoy.
A section of a Dupin cyclide (specifically a ring cyclide) can play the
Below is the detailed geometric reasoning.
Why an elliptically‑centered circular torus is impossible
A standard torus is defined as the surface generated by revolving a circle of
rR>r. Its defining property is:
The tube centerline is a perfect circle of radius RRR.
A circle of radius rrr cannot remain perpendicular to an elliptical trajectory
while maintaining constant distance from the ellipse.
As the tube center attempts to follow the ellipse, the required orientation
twists inconsistently.
The surface self‑intersects unless the cross‑section distorts.
A constant‑radius normal field cannot exist along a plane ellipse.
Thus:
A torus with constant circular cross‑section and an elliptical major
radius cannot be embedded in R3\mathbb{R}^3R3 without distortion.
This is a classical result from differential geometry: a tube of constant radius
can only be swept around a curve whose curvature κ(s)\kappa(s)κ(s)
satisfies
r<1maxκ(s)r < \frac{1}{\max \kappa(s)}r<maxκ(s)1
and whose normal vector rotates consistently. A planar ellipse does not satisfy
this for a fixed radius circle.
How a Dupin cyclide solves this
Its cross sections by suitable families of spheres are circles, and the
curvature lines are circles.
That means:
The surface bends around in a general way not limited to being the
parallel‑offset of a single circle.
The curvature lines are Villarceau circles and orthogonal circular families,
giving a structure very similar to a torus but with more flexibility.
Why a cyclide can work:
A general ring cyclide is obtained from a torus by inversion in a sphere:
Cyclide=Inversion(Torus)\text{Cyclide} = \text{Inversion} ( \text{Torus}
)Cyclide=Inversion(Torus)
Inversion preserves:
circles → circles,
spheres → spheres,
constant‑curvature structure in a generalized way.
But inversion does not preserve distances, so the resulting surface can bend and
elliptical‑centerline torus.
Thus a Dupin cyclide:
has circular curvature lines (like a torus),
maintains circular cross‑sections in a transformed sense,
can be fitted to curves (directrices) that are not circles.
A partial ring cyclide can provide:
an elongated toroidal shape,
smooth curvature without singularities,
circular fiber curves (Villarceau circles),
This is used in:
CAD modeling systems,
sweep surfaces,
transition surfaces (Fillets/Blends),
quadric‑based modeling applications.
Practical interpretation:
If you want:
a circular tube,
bending around an ellipse,
without changing the tube radius,
then a cyclide patch is the mathematically correct surface.
structures. A selected region of a cyclide can approximate a torus stretched
around an ellipse, because the inversion mapping allows shapes impossible in
Euclidean rigid sweeps.
Summary
cyclides in geometric modeling.
If you want, I can:
derive the exact cyclide equation needed for a specific ellipse,
construct Villarceau circle fibrations along that cyclide,
generate POV‑Ray macros for a cyclide section that approximates a torus
swept along an ellipse,
create a PDF with diagrams and derivations,
provide a .pov scene with curvature‑coloring and isosurface rendering.
Would you like the full construction?
