POV-Ray : Newsgroups : povray.binaries.images : Elliptical torus Server Time
15 Mar 2026 10:18:30 EDT (-0400)
  Elliptical torus (Message 12 to 21 of 41)
Subject: Re: Elliptical torus
Date: 4 May 2020 16:15:01
Message: <web.5eb07701a032ea3dfb0b41570@news.povray.org>
Helps to provide the diagram...
Download 'implicitellipticaltorus.png' (130 KB)
Preview of image 'implicitellipticaltorus.png'
Date: 4 May 2020 16:50:06
Message: <web.5eb07f87a032ea3dfb0b41570@news.povray.org>
So, I looped over x, y, and z and sent the evaluated function result to the
debug stream.   Massive delay from sending 8000 points to the text stream
later...
 and I get values in the hundreds, less, less, less, and maybe a min of 0 or so.
I then plotted points with a value of 10 or less with spheres.
There's definitely an elliptical shape in there somewhere....
Download 'implicitellipticaltorus.png' (119 KB)
Date: 4 May 2020 17:25:06
Message: <web.5eb08780a032ea3dfb0b41570@news.povray.org>
Oh look:
If I clean up my sloppy code and cease engaging in flagrant dumbassery.....
Download 'implicitellipticaltorus.png' (148 KB)
Date: 4 May 2020 20:10:00
Message: <web.5eb0ae7ca032ea3dfb0b41570@news.povray.org>
And wow - wouldn't you know - when you actually do the math correctly, it comes
out dead-on.
f_elliptical_torus in the proper x-z plane
Download 'implicitellipticaltorus.png' (93 KB)
Date: 5 May 2020 07:23:39
Message: <5eb14cbb$1@news.povray.org>
> out dead-on.
Cool! :-)
I'm going make another attempt at an inbuilt function for this. If
you've tweaked something in the code from the previous few posts, please
let me know.
More ReL (Real Life) than RaL (Ray Life) today - so likely later this
week before I get to it.
Bill P.
Date: 5 May 2020 13:35:01
Message: <web.5eb1a390a032ea3dfb0b41570@news.povray.org>
> let me know.
Nope - Just been playing around with it a bit to make sure the outer and inner
shapes are truly elliptical (they are).
I know we have a vlength() - but it can't be used in functions (vector
argument).
Maybe if there was a way to just do a Vlength (x,y,z) to get around that...
I was also thinking that non-circular cross sections would be something nice to
have - something like the form factors for the helix functions.  I have one
function that I'll try to work out for that, but other functions similar to the
superellipsoid, "squircle", and rounded box seem like they would have utility
for povvers as well.
Conversely, It would be great to have a "torus" that was spherical or
ellipsoidal - but could follow the shape of some other function or spline.
With regard to dot notations and vectors - what is the "native form" for a
pigment pattern?  Is it an "rgb" vector where each component simply has the same
value unless modified by a color_map?
And is it therefore slower to use .gray or .hf?
So much ReL.  Juggling Arduino, work, home, and COVID ridiculousness.
No worries - take your time.  :)
Date: 5 May 2020 20:20:01
Message: <web.5eb2022ba032ea3dfb0b41570@news.povray.org>
I made excellent progress in translating the function of main interest to into a
pattern and an isosurface.   I think in order to make it function as a
cross-sectional term, it needs to "translate its frame of reference to the
origin", and so I might need to convert the atan2 function to a polynomial.
But I might be wrong about that.
Essentially, I need to calculate the _angle_ that I'm at around the cross
section using x and y....
So I'd need to do something like this, only in SDL.
https://stackoverflow.com/questions/11930594/calculate-atan2-without-std-functions-or-c99
float normalized_atan2( float y, float x )
    static const uint32_t sign_mask = 0x80000000;
    static const float b = 0.596227f;
    // Extract the sign bits
    uint32_t ux_s  = sign_mask & (uint32_t &)x;
    uint32_t uy_s  = sign_mask & (uint32_t &)y;
    // Determine the quadrant offset
    float q = (float)( ( ~ux_s & uy_s ) >> 29 | ux_s >> 30 );
    // Calculate the arctangent in the first quadrant
    float bxy_a = ::fabs( b * x * y );
    float num = bxy_a + y * y;
    float atan_1q =  num / ( x * x + bxy_a + num );
    // Translate it to the proper quadrant
    uint32_t uatan_2q = (ux_s ^ uy_s) | (uint32_t &)atan_1q;
    return q + (float &)uatan_2q;
Date: 5 May 2020 20:45:00
Message: <web.5eb207fba032ea3dfb0b41570@news.povray.org>
Scratch that initial misconception.
Which means that I need to unravel the dot product between two vectors.
The first vector being the normalized blue segment in the drawing.
The second vector being the normalized radial vector in the vertical plane of
the blue vector.
Got some cool screw-ups, and have some visual confirmation that I can get a nice
non-circular/elliptic shape to the R of the torus.
Maybe I'll get it before tomorrow afternoon.
Date: 5 May 2020 23:10:01
Message: <web.5eb22a1aa032ea3dfb0b41570@news.povray.org>
Grrr.
Tried like 5 different ways, and wrote functions for cos, vlength, norm, dot,
and angle.
I just get the same results - modification of the R, not the r.
Maybe it will come to me with more sleep.
The rear row are single instances of the shapes - like the spherical pattern,
instead of multiple level sets of the isosurfaces like the onion.
Anyway, here's a preview to show the direction I'm heading.
Download 'ngonisosurface.png' (175 KB)
Preview of image 'ngonisosurface.png'
Date: 8 May 2020 07:36:47
Message: <5eb5444f$1@news.povray.org>
You got it. Yes, it's slower to use .gray or .hf if, say, .red will do.
However, often not by enough you can really tell given the volatility of
today's CPU performance.
We also have the issue POV-Ray's .gray, .grey and .hf functions not
being quite the norm. Somewhere there are posts from Christoph - and
maybe Cousin Ricky - on this IIRC. I have notes somewhere...
I've been staying away from .gray, .grey and .hf and output to grey file
formats for a while.
I think so long as all rgb values match exactly the difference in
POV-Ray's conversion to a gray value doesn't matter - but that statement
should be thoroughly tested before being set in stone.
Bill P.
