if you're fairly quick, u have one more question looming ---
unresolved constant of "88" -
represents a perspective cancel.
how much bigger to stay the same size at a distance?
... so that's your home work, resolve the last constant.
time's up. pencil's down, a trick question doesn't require math.
88 = ground 0.
a constant.
distance at which u see object of size 1 at size 1.
perspective is all about divide by Z.
but that may not be POV, which may include near far points and doodads.
close enough tho.
self adjusting to stay the same size at another FOV
fl = 1/tan(radians(fov/Aspect/2));
// fl * centerx = actual focal length
vlen / 88 becomes ...
vlen / (fl * 23.6)
or simply vlen / fl;
that was the bonus answer nobody got.
On 19/01/2020 07:16, Melody wrote:
> #macro label(Text,objv,r,col,top)
> #local vl = vlength(objv-campos)/88;
> #if (top)
> #local pnt = camup*(r*1.05)+objv;
> #else
> #local pnt = -camup*(vl*FontSize+r)+objv;
> #end
> #local eye = vnormalize(pnt-campos);
> object {
> text {
> ttf "Arial.ttf" Text 2 0
> texture { pigment { rgb col } finish { ambient 1 diffuse 0 } }
> translate x*(strlen(Text)*-0.15*FontSize)
> scale vl*FontSize
> Matrix_Trans(vnormalize(vcross(camup,eye)),camup,eye,pnt)
> no_shadow
> #end
Thank for this macro. It seems to be working perfectly.
My firt try with **label()**
Kurtz le pirate
Compagnie de la Banquise
Download 'norma_triangle2.jpg' (43 KB)
Preview of image 'norma_triangle2.jpg'
>> #if (top)
>> #else
>> #end
>> object {
>> #end
one question at : #local vl = vlength(objv-CamPos)/88;
88 ???
Kurtz le pirate
> Thanks :)
> Kurtz le pirate
Nice sharp font! Is that pov3.7?
Mine never looked that good.
Is that a high camera angle?
Perspective makes them tilt.
something else to understand about text - possibly correct.
so Kurtz is "fairly quick." : )
> 88 ???
> Kurtz le pirate
Self adjusting to stay the same size at another FOV, AKA camang -
fl = 1/tan(radians(camang/Aspect/2));
vlen / (fl * 23.6)
or simply vlen / fl; and resize smaller to begin with.
Aspect = Width/Heigth > 1
Don't need Aspect, just adjusts for visible height angle.
Text centering failed for different FontSize - fixed.
Screen size same for a camang change. Now its done?
There's always something more?
right=up.eye
eye=right.up
up=eye.right
#declare campos = <0,80,-250>;
#declare cameye = vnormalize(<20,12,0>-campos);
#declare camup = <-1,1,0>;
#declare camright = vnormalize(vcross(camup,cameye));
#declare camup = vnormalize(vcross(cameye,camright));
#declare FontSize = 1;
#declare camang = 30;
location campos
right camright
up camup *(image_height/image_width)
direction cameye*(image_height/image_width)
angle camang
#include "transforms.inc"
#local fl = 1/tan(radians(camang/2));
#local vl = vlength(objv-campos)/(fl*20);
#if (top)
#else
object {
text {
ttf "Arial.ttf" Text 1 0
translate -x*((strlen(Text)/2) * FontSize / (2*FontSize))
scale vl*FontSize
no_shadow
label("HELLO 162",<60,24,80>,48,<0.0196, 0.0196, 0.2156>,1)
label("Here are 492",y* 29.9,24*.8,<0.0196, 0.0196, 0.2156>,0)
well there are now much smaller remaining constants, 20 and 1.05.
Download 'golfdimples10a.png' (108 KB)
Preview of image 'golfdimples10a.png'
20 is just another a size factor u want to see,
and leave it at that.
