POV-Ray : Newsgroups : povray.binaries.images : Object Labels Server Time
15 Jun 2024 21:20:48 EDT (-0400)
  Object Labels (Message 1 to 10 of 26)
Subject: Object Labels
Date: 18 Jan 2020 22:50:00
Message: <web.5e23d1b255a34c109da690110@news.povray.org>
right=up.eye
eye=right.up
up=eye.right
#declare campos = <0,80,-250>;
#declare cameye = vnormalize(<20,12,0>-campos);
#declare camup = <0,1,0>;
#declare camright = vnormalize(vcross(camup,cameye));
#declare camup = vnormalize(vcross(cameye,camright));
#declare FontSize = _clamp(1.7,0.1,2);
#declare camang = 40;
  location campos
  right camright
  up camup *(image_height/image_width)
  direction cameye*(image_height/image_width)
  angle camang
#macro label(Text,objv,r,col)
#local vl = vlength(objv-campos)/88;
#local pnt = camup*((r*.95)+vl*FontSize)+objv;
#local eye = vnormalize(pnt-campos);
object {
  text {
    ttf "Arial.ttf" Text 2 0
    texture {  pigment { rgb col }  finish { ambient 1 diffuse 0 } }
  translate x*(strlen(Text)*-0.28)
  scale <vl*FontSize,vl*FontSize,vl*FontSize>
popmatrix(vnormalize(vcross(camup,eye)),vnormalize(vcross(eye,vcross(camup,eye))),eye,pnt)
  no_shadow
label("HELLO 162",<60,24,80>,48,<0.0196, 0.0196, 0.2156>)
label("Here are 492",y* 29.9,24*.8,<0.30196, 0.0196, 0.2156>)
so u can likely tweak to get the result
Download 'labels9.png' (213 KB)
Preview of image 'labels9.png'
Subject: Re: Object Labels
Date: 18 Jan 2020 23:25:01
Message: <web.5e23d89428c763ef9da690110@news.povray.org>
reminder, popmatrix() is Matrix_Trans(A, B, C, D) in POV.
transforms.inc
translations are easier when u stick to same name funcs.
limited RAM upstairs.
Date: 18 Jan 2020 23:50:00
Message: <web.5e23df6528c763ef9da690110@news.povray.org>
oh right, now I remember. for bottom text, consider font height.
#macro label(Text,objv,r,col,top)
#if (top)
#local pnt = camup*(r*1.05)+objv;
#else
#local pnt = -camup*(vl*FontSize+r)+objv;
object {
  text {
  translate x*(strlen(Text)*-0.25)
  no_shadow
Download 'golfdimples10.png' (87 KB)
Preview of image 'golfdimples10.png'
Date: 19 Jan 2020 00:05:01
Message: <web.5e23e2ca28c763ef9da690110@news.povray.org>
and finally, start with
#declare camup = <-1,1,0>;
text is transformed, and its normal points at camera.
Download 'golfdimples11.png' (95 KB)
Preview of image 'golfdimples11.png'
Date: 19 Jan 2020 01:20:00
Message: <web.5e23f45928c763ef9da690110@news.povray.org>
remove redundant,
add scale to text centering. done.
right=up.eye
eye=right.up
up=eye.right
  location campos
  right camright
  angle camang
#include "transforms.inc"
#if (top)
#else
object {
  text {
  translate x*(strlen(Text)*-0.15*FontSize)
  scale vl*FontSize
  Matrix_Trans(vnormalize(vcross(camup,eye)),camup,eye,pnt)
  no_shadow
label("HELLO 162",<60,24,80>,48,<0.0196, 0.0196, 0.2156>,1)
label("Here are 492",y* 29.9,24*.8,<0.30196, 0.0196, 0.2156>,0)
Date: 19 Jan 2020 05:15:01
Message: <web.5e242b2b28c763ef9da690110@news.povray.org>
As for 3D point to screen xy, you'll need a few things.
POV's Perspective Matrix
InvertMatrix function
CameraMatrix 4x4
inv cam to world matrix, subv(pnt-campos)
pop world matrix
if (point[2] > 0) pop perspective matrix
which returns xy;
That's your camera.
> 0 because u dont have eyes in the back of your head.
if < 0, do nothing, move-on to the next pnt/star/object.
Date: 19 Jan 2020 06:35:00
Message: <web.5e243e3328c763ef9da690110@news.povray.org>
if you're fairly quick, u have one more question looming ---
unresolved constant of "88" -
represents a perspective cancel.
how much bigger to stay the same size at a distance?
 ... so that's your home work, resolve the last constant.
Date: 19 Jan 2020 07:20:00
Message: <web.5e24486728c763ef9da690110@news.povray.org>
time's up. pencil's down, a trick question doesn't require math.
88 = ground 0.
a constant.
distance at which u see object of size 1 at size 1.
perspective is all about divide by Z.
but that may not be POV, which may include near far points and doodads.
close enough tho.
Date: 19 Jan 2020 08:15:01
Message: <web.5e24553528c763ef9da690110@news.povray.org>
self adjusting to stay the same size at another FOV
fl = 1/tan(radians(fov/Aspect/2));
// fl * centerx = actual focal length
vlen / 88 becomes ...
vlen / (fl * 23.6)
or simply vlen / fl;
that was the bonus answer nobody got.
Date: 19 Jan 2020 12:25:33
Message: <5e24910d@news.povray.org>
> #if (top)
> #else
> #end
> object {
>    text {
>    scale vl*FontSize
>    no_shadow
> #end
Thank for this macro. It seems to be working perfectly.
My firt try with **label()**
Kurtz le pirate
Compagnie de la Banquise
Download 'norma_triangle2.jpg' (43 KB)
Preview of image 'norma_triangle2.jpg'
