POV-Ray : Newsgroups : povray.binaries.images : Object Labels Server Time
8 Apr 2026 01:09:47 EDT (-0400)
  Object Labels (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Object Labels
Date: 19 Jan 2020 06:35:00
Message: <web.5e243e3328c763ef9da690110@news.povray.org>
if you're fairly quick, u have one more question looming ---
unresolved constant of "88" -
represents a perspective cancel.
how much bigger to stay the same size at a distance?
 ... so that's your home work, resolve the last constant.
Date: 19 Jan 2020 07:20:00
Message: <web.5e24486728c763ef9da690110@news.povray.org>
time's up. pencil's down, a trick question doesn't require math.
88 = ground 0.
a constant.
distance at which u see object of size 1 at size 1.
perspective is all about divide by Z.
but that may not be POV, which may include near far points and doodads.
close enough tho.
Date: 19 Jan 2020 08:15:01
Message: <web.5e24553528c763ef9da690110@news.povray.org>
self adjusting to stay the same size at another FOV
fl = 1/tan(radians(fov/Aspect/2));
// fl * centerx = actual focal length
vlen / 88 becomes ...
vlen / (fl * 23.6)
or simply vlen / fl;
that was the bonus answer nobody got.
Date: 19 Jan 2020 12:25:33
Message: <5e24910d@news.povray.org>
On 19/01/2020 07:16, Melody wrote:
> #macro label(Text,objv,r,col,top)
> #local vl = vlength(objv-campos)/88;
> #if (top)
> #local pnt = camup*(r*1.05)+objv;
> #else
> #local pnt = -camup*(vl*FontSize+r)+objv;
> #end
> #local eye = vnormalize(pnt-campos);
> object {
>    text {
>      ttf "Arial.ttf" Text 2 0
>      texture {  pigment { rgb col }  finish { ambient 1 diffuse 0 } }
>    translate x*(strlen(Text)*-0.15*FontSize)
>    scale vl*FontSize
>    Matrix_Trans(vnormalize(vcross(camup,eye)),camup,eye,pnt)
>    no_shadow
> #end
Thank for this macro. It seems to be working perfectly.
My firt try with **label()**
Kurtz le pirate
Compagnie de la Banquise
Download 'norma_triangle2.jpg' (43 KB)
Preview of image 'norma_triangle2.jpg'
Date: 19 Jan 2020 12:30:00
Message: <5e249218$1@news.povray.org>
>> #if (top)
>> #else
>> #end
>> object {
>> #end
one question at : #local vl = vlength(objv-CamPos)/88;
88 ???
Kurtz le pirate
Date: 19 Jan 2020 18:35:01
Message: <web.5e24e6ec28c763ef9da690110@news.povray.org>
> Thanks :)
> Kurtz le pirate
Nice sharp font! Is that pov3.7?
Mine never looked that good.
Is that a high camera angle?
Perspective makes them tilt.
something else to understand about text - possibly correct.
Date: 19 Jan 2020 19:00:00
Message: <web.5e24ec7b28c763ef9da690110@news.povray.org>
so Kurtz is "fairly quick." : )
> 88 ???
> Kurtz le pirate
Self adjusting to stay the same size at another FOV, AKA camang -
fl = 1/tan(radians(camang/Aspect/2));
vlen / (fl * 23.6)
or simply vlen / fl; and resize smaller to begin with.
Date: 19 Jan 2020 19:15:00
Message: <web.5e24f08828c763ef9da690110@news.povray.org>
Aspect = Width/Heigth > 1
Date: 19 Jan 2020 21:25:00
Message: <web.5e250eab28c763ef9da690110@news.povray.org>
Don't need Aspect, just adjusts for visible height angle.
Text centering failed for different FontSize - fixed.
Screen size same for a camang change. Now its done?
There's always something more?
right=up.eye
eye=right.up
up=eye.right
#declare campos = <0,80,-250>;
#declare cameye = vnormalize(<20,12,0>-campos);
#declare camup = <-1,1,0>;
#declare camright = vnormalize(vcross(camup,cameye));
#declare camup = vnormalize(vcross(cameye,camright));
#declare FontSize = 1;
#declare camang = 30;
  location campos
  right camright
  up camup *(image_height/image_width)
  direction cameye*(image_height/image_width)
  angle camang
#include "transforms.inc"
#local fl = 1/tan(radians(camang/2));
#local vl = vlength(objv-campos)/(fl*20);
#if (top)
#else
object {
  text {
    ttf "Arial.ttf" Text 1 0
  translate -x*((strlen(Text)/2) * FontSize / (2*FontSize))
  scale vl*FontSize
  no_shadow
label("HELLO 162",<60,24,80>,48,<0.0196, 0.0196, 0.2156>,1)
label("Here are 492",y* 29.9,24*.8,<0.0196, 0.0196, 0.2156>,0)
well there are now much smaller remaining constants, 20 and 1.05.
Download 'golfdimples10a.png' (108 KB)
Preview of image 'golfdimples10a.png'
Date: 19 Jan 2020 22:20:01
Message: <web.5e251bc228c763ef9da690110@news.povray.org>
20 is just another a size factor u want to see,
and leave it at that.
