hi,
Alain Martel <kua### [at] videotronca> wrote:
> > Alas, I lost the code after a USB stick corruption. ...
> Lesson :
> Backup !
> NEVER EVER leave your code and ANY important file in only one location.
> Backup !
> Several partitions on a single drive is still only a single location.
> Backup !
just to say, I agree with Alain, 100%, right down to the exclamation marks.
and will add that, ime, the "human" fallibility has to be allowed for,
therefore, always automate the back up. (mine run in the small hours, every
night)
regards, jr.
> >>>>>> Your cloud do have some great properties. Although it is unexpected
simple(the
> >>>>>> pov-code). The fluffy appearance is what I want. And the coverage is
moderate.
> >>>>>> But in fact the real geometry shows the top and bottom are truncated by the
> >>>>>> boundary(800m~1200m). I will think how to solve this in the future, but if
you
> >>>>>> have idea I think it will be nice.
> >>>>> You may use a planar pattern to hide that. Just scale and translate it
> >>>>> properly, and add a map or use an alternate wave type to control how it
> >>>>> need to fade near the container's edges.
> >>>> How do you combine these two(The original and the planar pattern)? I can't
spend
> >>>> time to try it right now, but I wish to look your code (even a simple example).
> >>> I think the planar (or equivalent) pattern can be used as an additional density
> >>> function (that will multiply with the main one). I did use this for some other
> >>> clouscapes atempts.
> >> Multiply is a straightforward idea that combine these functions. I have doubts
> >> about it because it seem change the original pattern (unnatural) ....but I
> >> hardly ever try it. You said that you have used it. Is the effect fine?
> > I once could get this, and IIRC, the truncation was mitigated with such a
> > function. Alas, I lost the code after a USB stick corruption. But the principle
> > seems OK, provided the parameters are properly tweaked (tricky).
> > B.
> Lesson :
> Backup !
> Backup !
> Backup !
Believe me, I know very well about backup!! In this case, I was on vacation and
the code was on a usb. I used someone else's PC.
