POV-Ray : Newsgroups : povray.binaries.images : Unintended behaviour of heightfield in CSG difference? Server Time
15 Aug 2025 21:17:14 EDT (-0400)
  Unintended behaviour of heightfield in CSG difference? (Message 1 to 3 of 3)
Subject: Unintended behaviour of heightfield in CSG difference?
Date: 8 Oct 2019 20:55:01
Message: <web.5d9d2f8caa18e8744eec112d0@news.povray.org>
So, I was trying out creating a part using an edited blueprint image, and I
needed to use the water_level keyword to remove that bit of base plane.
Then I nearly lost my mind trying to figure out why things "weren't working"
when I tried to difference out a cylinder for nice clean hole - and the cylinder
was VISIBLE - but only on one side... :O
Well, apparently the water_level "deleted" section doesn't get deleted - it just
isn't visible.   But when the cylinder gets differenced from it, that surface
becomes visible, even if the cylinder doesn't have a texture, and the whole CSG
gets an overall texture.
That complicates things more than you'd think, because I do a lot of scaling in
the heightfield definition, and now I have to do that in a separate CSG
operation to difference away a box, or intersect one, etc.
What do we think?   Is this a "bug"?
Has anyone ever seen this before?
Download 'hf part w difference.png' (422 KB)
Preview of image 'hf part w difference.png'
Subject: Re: Unintended behaviour of heightfield in CSG difference?
Date: 9 Oct 2019 02:46:18
Message: <5d9d823a$1@news.povray.org>
Op 09/10/2019 om 02:53 schreef Bald Eagle:
I seem to hear a bell tolling in the far distance, muffled by thick mist
banks... ;-)
Maybe it is best not to use water_level in this particular case and do a
CSG difference, intersection, or clipping instead. Have you tried that?
and what is the result?
Date: 9 Oct 2019 11:17:26
Message: <5d9dfa06@news.povray.org>
Instead of water_level, use an intersection with a box. That way, your
height_field will get a true back side and behave correctly when you
perform some other CSG operations.
