POV-Ray : Newsgroups : povray.binaries.images : TEE Edelweiss Server Time
24 Apr 2024 16:45:07 EDT (-0400)
  TEE Edelweiss (Message 45 to 54 of 68)
Subject: Re: TEE Edelweiss
Date: 29 Jan 2020 03:50:00
Message: <web.5e31470450afc79f804551e0@news.povray.org>
> Op 29/01/2020 om 01:31 schreef Ton:
> > And here is the whole train.
> Well done sir!
> Just one question: The "joint" (what's its name?) between the two first
> wagons seems to be twice the size of the other ones. On purpose? Or just
> a matter of perspective?
> Thomas
Thanks Thomas, they're called "inter wagon canvas". It's rubber, probably to
streamline the train. The first one, from the motorwagon, is 8.5 wide, the other
two are 4.5. It's a bit difficult to get a good complete overview, so
perspective is playing up a bit.
Ton.
Date: 29 Jan 2020 06:35:30
Message: <5e316e02$1@news.povray.org>
Ton wrote on 29/01/2020 01:31:
Very very good!
Paolo
Date: 29 Jan 2020 11:39:15
Message: <5e31b533$1@news.povray.org>
>> Well done sir!
>> Thomas
> Cheers
> Ton.
Streamlining is a factor, but it's mostly to allow the passage from one
wagon to another without being buffeted by the wind. A question of
comfort and convenience for the passengers.
Date: 30 Jan 2020 05:10:01
Message: <web.5e32ab2150afc79f28c55bc90@news.povray.org>
hi,
"proper" modelling again, superb.  perspective?  just treat us to an animation
of it going past the camera!  :-)
regards, jr.
Date: 31 Jan 2020 15:46:48
Message: <5e349238$1@news.povray.org>
Hi(gh)!
On 29.01.20 01:30, Ton wrote:
> It has been a while, but with Christmas and 2020 and a small holiday there was
> not much time for Povray.
> But the train is finished, now I have to put it somewhere, might be my next
> project.
What about putting the train in its genuine geographic environment? I'm
currently re-coding Melody's smooth mesh generator to make it run at an
acceptable speed (90 minutes rather than 200 days for 3601 by 3601
vertices...), after that, I will start generating 1 square degree Earth
surface slices (mesh2 terrain reliefs following Earth's curvature) from
ASTER GeoTIFFs, so you might want to place railway tracks on it... on
which line did the Edelweiss run?
Let's do POVEarth!
See you in Khyberspace (the Afghan section of POVEarth)!
Yadgar
Date: 1 Feb 2020 17:15:00
Message: <web.5e35f85850afc79f804551e0@news.povray.org>
=?UTF-8?Q?J=c3=b6rg_=22Yadgar=22_Bleimann?= <yaz### [at] gmxde> wrote:
> Hi(gh)!
> > project.
> Let's do POVEarth!
> Yadgar
Hi Yadgar, interesting plan. I have at the moment something completely different
for my train in my mind.
Is your mesh2 detailed enough for this close?
Netherlands shouldn't be too difficult (flat!), but France and Switzerland open
some possibilities.
Ton.
Date: 1 Feb 2020 18:05:00
Message: <web.5e36040e50afc79f4eec112d0@news.povray.org>
> some possibilities.
> Cheers
> Ton.
That sounds to be maybe 25 miles on a side.
https://gis.stackexchange.com/questions/8495/converting-longitude-and-latitude-coordinates-to-square-miles
or maybe it's 70:
https://sciencing.com/convert-degrees-latitude-miles-5744407.html
anyway, there's definitely enough detail in certain map areas to do just what
you need:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5ce356f7d68a971b4eec112d0%40news.povray.org%3E/
Date: 1 Feb 2020 23:25:16
Message: <5e364f2c$1@news.povray.org>
Am 1/28/20 7:31 PM, also sprach Ton:
It looks very nice.  Shouldn't it have some kind of catenary pantograph?
Weird that none of the pictures show any kind of top electrical
connection.  Was it a diesel?
(Thanks.  I started looking at the TEE Edelweiss wikipedia page, and got
rabbitholed into Gotthard Base Tunnel and other Rail2000 projects. :) )
dik
Rendered 49,882,521,600 of 49,882,521,600 pixels (100%)
Date: 2 Feb 2020 05:12:38
Message: <5e36a096$1@news.povray.org>
Hi(gh)!
What do you plan to do?
3601 by 3601 data points per square degree result in about 30 metres per
data point (at the equator and along meridians, otherwise less).
...but I'll have to block out the sea from flooding the many depressions
by cutting prisms from the ocean globe!
> some possibilities.
La Montanara for the camera lens, as I prefer to say...
See you in Khyberspace!
Yadgar
> Cheers
> Ton.
Date: 6 Feb 2020 02:10:00
Message: <web.5e3bbba950afc79f804551e0@news.povray.org>
I'll keep that a surprise. If it fails, or doesn't work out, I don't have to
apologize!
Maybe after I might have a look at some nice Alp-mountain or ridge.
Ton.
