POV-Ray : Newsgroups : povray.binaries.images : Small abstract Server Time
18 Nov 2025 11:14:38 EST (-0500)
  Small abstract (Message 1 to 10 of 14)
Subject: Small abstract
Date: 19 May 2019 05:55:00
Message: <web.5ce1265c730aefac3c1c78400@news.povray.org>
Hello to everyone,
here is a abstract with a small source.
It's not perfect, but nice enough to show -
#version 3.7;
global_settings {
        assumed_gamma 2.2
        max_trace_level 5
        noise_generator 2
#include "stdinc.inc"
        location <0,1,-7.7>
        look_at <0,-5.6,0>
        angle 30*image_width/image_height
        right image_width/image_height*x
        rotate z*30
#declare p2 = function {pattern {crackle metric 1 translate x*37}}
#declare FN = function (x,y,z) {(sin (p2 (x,0,z)*4*pi)+1)*(1-p2 (x,0,z))}
#declare base_pat =
        #local Curve    = 0.125;
        #local Omega    = 0.5;
        #local Lambda   = 2.5;
        #local Octaves  = 8;
        pigment_pattern {
                average
                pigment_map {
                        #local octave = 0;
                        #while (octave < Octaves)
                                [pow (Omega, octave)
                                        pigment_pattern {
                                                function {FN (x,y,z)}
                                                scale pow (Lambda, -octave)
                                                color_map {
                                                        [0      srgb 1]
                                                        [1      srgb 0]
                                        poly_wave 1/Curve
                                #local octave = octave+1;
        poly_wave Curve
        color_map {
                [0      srgb 1]
                [1      srgb 0]
#declare fac = -0.1;
#declare diff = 0;
#declare Color = <79,171,182>/255;
plane {
        y, -0.0001
                 pigment_pattern {base_pat}
                 pigment_map {
                         [0              srgb 0]
                         [fac+0.36-diff  srgb 0]
                         [fac+0.36+diff  srgb Color+<0,40,-40>/255]
                         [fac+0.42-diff  srgb Color+<0,40,-40>/255]
                         [fac+0.42+diff  srgb 0]
                         [fac+0.56-diff  srgb 0]
                         [fac+0.56+diff  srgb Color+<0,-40,40>/255]
                         [fac+0.62-diff  srgb Color+<0,-40,40>/255]
                         [fac+0.62+diff  srgb 0]
                         [1              srgb 0]
                normal {granite 0.02 scale 0.001}
                finish {brilliance 4 diffuse 0 ambient 0 emission 0.7}
box {
        <-20,0.0001,-20>, <20,1,20>
        hollow
        material {
                pigment {color srgbt 1}
                interior {
                 media {
                  emission srgb 2
                                density {
                                 density_map {
                                         [0              srgb 0]
                                         [fac+0.36+diff  srgb
                                         [fac+0.42-diff  srgb
                                         [fac+0.56+diff  srgb
                                         [fac+0.62-diff  srgb
                                         [1              srgb 0]
                                method 2
                                intervals 1
                                samples 1600
Norbert
Subject: Re: Small abstract
Date: 19 May 2019 06:00:00
Message: <web.5ce1287c5e75640e3c1c78400@news.povray.org>
and here the image...
Download 'media_abstract.jpg' (741 KB)
Preview of image 'media_abstract.jpg'
Date: 19 May 2019 06:52:49
Message: <5ce13581$1@news.povray.org>
This is very beautiful indeed. Can be anything, from a cityscape to a
microchip, and everything in between.
Thank you!
Date: 19 May 2019 07:05:00
Message: <web.5ce138245e75640e939601860@news.povray.org>
It sure is nice enough to show.
Well done.
Ton.
Date: 19 May 2019 07:10:30
Message: <5ce139a6$1@news.povray.org>
Question: shouldn't 'method 2' not be 'method 3' in the media?
Date: 20 May 2019 05:00:56
Message: <5ce26cc8$1@news.povray.org>
Norbert Kern wrote on 19/05/2019 11:58:
Ethereal and relaxing.
Paolo
Date: 20 May 2019 15:30:01
Message: <web.5ce300095e75640e3c1c78400@news.povray.org>
> Thank you!
> Thomas
I like the variability of the crackle pattern too - it can contain everything...
Norbert
Message: <web.5ce300315e75640e3c1c78400@news.povray.org>
> Well done.
> Cheers
> Ton.
Thank you very much
Norbert
Date: 20 May 2019 15:35:01
Message: <web.5ce300ad5e75640e3c1c78400@news.povray.org>
> Thomas
I tried method 3, but it was slower, not better - but I made the test in an
early stage...
Norbert
Message: <web.5ce301005e75640e3c1c78400@news.povray.org>
> Paolo
That's a very kind comment - thank's for that
Norbert
