POV-Ray : Newsgroups : povray.binaries.images : George Stephenson's Rocket Server Time
28 Sep 2024 18:44:47 EDT (-0400)
  George Stephenson's Rocket (Message 1 to 10 of 32)
Subject: George Stephenson's Rocket
Date: 11 Apr 2019 06:45:01
Message: <web.5caf1a82df342c0879690ba10@news.povray.org>
Hello everybody,
I've embarked on a new adventure, the Rocket by George Stepenson, built in 1829.
I found good drawings for a model of the Rocket on modelengineeringwebsite.com,
which is an interesting website for model building, with quite a lot of
CAD-drawings.
BTW After my hard disk crash, and consequently sinking of my Titanic, I'm
synchronizing my Povray sources every night on my Google cloud space.
Ton.
Download 'forum1.png' (1097 KB)
Preview of image 'forum1.png'
Subject: Re: George Stephenson's Rocket
Date: 11 Apr 2019 11:55:01
Message: <web.5caf623d6bc50fb53c1c78400@news.povray.org>
"Ton" <ton### [at] gmailcom> wrote:
> Hello everybody,
> CAD-drawings.
> Cheers
> Ton.
Looks very promising!
Hopefully you will model the tender too.
There is much wood - in the case you are looking for a real nice wood texture -
think about a texture originating from the excellent isowood code by Christoph
Hormann - here is the code for a texture using his functions -
#macro IW_Warp_02 (Seed, xSize, ySize, zSize)
#local SZ = (xSize+ySize)*0.5*0.1;
#local Density = 0.1;
warp {
        black_hole <xSize*0.5,0,0>, SZ
        falloff 2.5
        strength 2
        repeat <min (xSize, SZ/Density),min (ySize, SZ/Density),SZ/Density>
        turbulence <0.02,0.75,0.75>
        inverse
#local SZ = (xSize+ySize)*0.5*0.15;
warp {
        falloff 2.1
        strength 3.7
0.7*SZ/Density),0.8*SZ/Density>
        turbulence <0,0.4,0.4>
        inverse
#macro IW_Select_Warp (WarpNbr, Seed, xSize, ySize, zSize)
#macro IW_Plank_Round_CutN (Seed, xSize, ySize, zSize, Rotate, Translate, Round,
Strength, Strength2, Pigm, Fin, C_Map, WarpNbr, fn_Max_Val)
#local rd = seed (Seed);
#local fn_Max = fn_Max_Val+<0,0,0>;
#local Trsx = (rand (rd)-0.5)*Translate*xSize;
#local Trsy = (rand (rd)-0.5)*Translate*ySize;
#local Trsz = (rand (rd)-0.5)*Translate*zSize;
#local Rotx = (rand (rd)-0.5)*Rotate;
#local Roty = (rand (rd)-0.5)*Rotate;
#local fn_Wood =
function {
                Pigm
                color_map {
                        [0      rgb 0]
                        [1      rgb 1]
                translate <Trsx,Trsy,Trsz>
                rotate Rotx*x
                rotate Roty*y
#local fn_Disp =
function {
                average
                pigment_map {
                        [1      function {f_noise3d (0,0,z*1.6)*0.3}
                                color_map {
                                        [0      rgb 0]
                                        [1      rgb x]
                        [1      function {f_noise3d (0,0,-z*1.6)*0.3}
                                color_map {
                                        [0      rgb 0]
                                        [1      rgb y]
#local fnShape  = function {f_rounded_box (x,y,z, Round, xSize*0.5, ySize*0.5,
zSize*0.5+Round)}
#local fnShape2 = function {(abs (z)-zSize*0.5)}
#local fnShapeT  = function {fnShape (x+fn_Disp (x,y,z).x, y+fn_Disp
(x,y,z).y,z+fn_Disp (x,y,z).z)}
#local fnShape2T = function {fnShape2(x+fn_Disp (x,y,z).x, y+fn_Disp
#declare fnBumpsT  = function {fn_Wood (x+fn_Disp (x,y,z).x, y+fn_Disp
(x,y,z).y,z+fn_Disp (x,y,z).z).grey}
#declare P_IW_10 =
        wood
        octaves 6
        lambda 2.5
        turbulence <0.06,0.06,0.75>
        scale      <0.02,0.02,0.3>
#declare Fin_W_02 =
finish {
        ambient 0.1*0
        diffuse 0.95
        brilliance 1.4
        specular 0.4
        roughness 0.02
#declare GammaFact = 1;
#declare ColorDiff = <0,0,0>;
#macro ColorCorrect (Color, Gamma, ColDiff)
rgb <pow (Color.red+ColDiff.red,Gamma),pow (Color.green+ColDiff.green,Gamma),pow
(Color.blue+ColDiff.blue,Gamma)>
#declare CM_IW_02 =
color_map {
        [0      ColorCorrect (<0.949,0.792,0.514>, GammaFact, ColorDiff)]
        [0.3    ColorCorrect (<0.855,0.651,0.376>, GammaFact, ColorDiff)]
        [0.6    ColorCorrect (<0.831,0.596,0.275>, GammaFact, ColorDiff)]
        [0.9    ColorCorrect (<0.620,0.447,0.204>, GammaFact, ColorDiff)]
IW_Plank_Round_CutN  (17, 0.3, 1.6, 8, 2, 0, 0.018, 0.0035, 0.005, pigment
{P_IW_10 scale 1.6} , Fin_W_02, CM_IW_02, 2, 0.3)
#local T_WoodA =
                function {fnBumpsT (x,y,z)}
                color_map {CM_IW_02}
        normal {function {fnBumpsT (x,y,z)}, -1 accuracy 0.004}
        finish {Fin_W_02}
Norbert
Date: 12 Apr 2019 03:15:06
Message: <web.5cb03aca6bc50fb5a50bb1200@news.povray.org>
> Norbert
Hello Norbert
yes, I'm aware of the isowood code. Renders good wood.
The model in the Railway Museum in York has the Rocket painted yellow, and
that's what I had in mind to render (to povray?) my model.
But of course I can use non-painted wood, and see how it looks. Povray will take
a lot longer though!
Ton
Date: 17 Apr 2019 07:45:01
Message: <web.5cb711036bc50fb575b136980@news.povray.org>
Here is an update on the Rocket. I've added the front bearing and its leaf
spring.
Ton.
Download 'forum2.png' (1276 KB)
Preview of image 'forum2.png'
Date: 23 Apr 2019 07:05:01
Message: <web.5cbef0586bc50fb523174ebc0@news.povray.org>
Another small step to completion, the boiler has been added, plus the steam
control valve. Only speed could be regulated, no brakes!
Ton.
Download 'forum3.png' (1144 KB)
Preview of image 'forum3.png'
Date: 24 Apr 2019 06:50:37
Message: <5cc03f7d$1@news.povray.org>
Ton wrote on 23/04/2019 13:00:
> Cheers
> Ton.
It looks promising!
Paolo
Date: 25 Apr 2019 09:40:00
Message: <web.5cc1b7c76bc50fb5624876100@news.povray.org>
> Cheers
> Ton.
If .. the brown part and yellow part of the rocket is too bright
Date: 29 Apr 2019 20:00:01
Message: <web.5cc78f706bc50fb542d8ebd00@news.povray.org>
Made some progress with my model. Added the steam dome and safety valve on top
of the boiler. Plus the smoke stack is in place.
I've also been playing with the textures and lighting. That seems like a never
ending process. It can always be improved.
Ton.
Download 'forum4.png' (1188 KB)
Preview of image 'forum4.png'
Date: 2 May 2019 02:55:15
Message: <5cca9453$1@news.povray.org>
What a beauty! I never realised somehow that the boiler was oval-shaped.
I assumed it was circular like the more recent steam locs.
Date: 2 May 2019 06:20:00
Message: <web.5ccac3d96bc50fb542d8ebd00@news.povray.org>
Bedankt for the compliment.
Is it oval? It's supposed to be a circle, a round circle.
Ton
