POV-Ray : Newsgroups : povray.binaries.images : Synthetic data sets for image analysis Server Time
23 Mar 2026 09:43:57 EDT (-0400)
  Synthetic data sets for image analysis (Message 1 to 6 of 6)
Subject: Synthetic data sets for image analysis
Date: 27 Jan 2019 01:45:00
Message: <web.5c4d52ac5c0b0917ce2d55280@news.povray.org>
Hi everyone,
I came up a few days ago with some (maybe?) unconventional way to use POV-Ray
for my job and would like to introduce it here in case it would be of any
interest to someone else.
I was looking for data sets of images to test machine learning algorithms and
couldn't find any one that fit my needs. Then I started thinking of how I could
generate automatically my own data sets. Of course, speaking of synthesis
picture, I immediately thought of POV-Ray, and it worked perfectly for me.
The problem here is not that much the generation of the image itself, but the
generation of its mask. For example, in the example pictures below, the target
is the cube, so I needed to generate automatically the image of the cube *and*
its duplicate where every pixels matching the cube are black and all the others
are white. I found that I could achieve this using the two textures below, one
for the target, and one for everything else.
#declare _texMaskTarget = texture {
  pigment { color Black }
  finish { ambient 0 }
#declare _texMaskNonTarget = texture {
  pigment { color White }
  finish { ambient 1 diffuse 100 }
Crafting the scene to my needs, adding randomness on the desired variable
components of the scene, using the clock variable as the seed for the random
generator, wrapping that in a Python script which generates and executes an INI
file including the directive Declare=Mask=0 to switch between the normal texture
and the mask texture, and I had a very handy tool to generate in minutes a data
set of hundred of samples crafted to match perfectly any needed test case.
If anyone has a better idea than my trick with the textures to generate the mask
I would be glad to hear it.
For those interested, everything is available on GitHub here:
https://github.com/BayashiPascal/SDSIA
Download 'sdsia.jpg' (83 KB)
Preview of image 'sdsia.jpg'
Subject: Re: Synthetic data sets for image analysis
Date: 27 Jan 2019 13:13:36
Message: <5c4df4d0$1@news.povray.org>
Le 19-01-27 à 01:43, BayashiPascal a écrit :
> Hi everyone,
You can also use the quality setting.
If you set the pigment of the box to rgb 0, the pigment of everything
else to rgb 1, and use +q0 on the command line, you'll get the same
result. The advantage is that it should be faster as no light are used.
When using +q0 the following happen :
ALL light are ignored.
EVERYTHING is rendered assuming full ambient only.
Diffuse is ignored.
There are no shadow.
Radiosity is disabled.
Reflections are ignored.
The quality setting can be set via an ini file or on the command line.
Date: 28 Jan 2019 08:45:01
Message: <web.5c4f066e4332cefdce2d55280@news.povray.org>
Indeed !
From 1m16s to 53s on the example data set of the repository. Thank you very much
Alain ! :-)
> Diffuse is ignored.
Date: 19 Feb 2019 00:30:00
Message: <5c6b9458$1@news.povray.org>
>> Hi everyone,
>> POV-Ray
>> algorithms and
>> how I could
>> me.
>> but the
>> the target
>> cube *and*
>> the others
>> below, one
>> random
>> executes an INI
>> normal texture
>> minutes a data
>> case.
>> generate the mask
> Diffuse is ignored.
I wonder if this would work for video game shadow sprites too.
Mike
Date: 4 Mar 2019 02:18:10
Message: <5c7cd132$1@news.povray.org>
On 27/01/2019 06:43, BayashiPascal wrote:
> Hi everyone,
This looks fascinating - what a good way to use POVray!
Saw a great demo of Microsoft's Custom Vision AI services the other day.
More more info here:
https://www.customvision.ai/
Date: 4 Mar 2019 07:30:00
Message: <web.5c7d19954332cefd24366d850@news.povray.org>
Thank you Reuben !
Yes any big company in computer science launches its own version of this kind of
service nowadays. But that's really as easy and efficient as they pretend...
Pascal
> > Hi everyone,
