hi,
"And" <49341109@ntnu.edu.tw> wrote:
> "jr" <cre### [at] gmailcom> wrote:
> > [*] without 3d goggle + data-glove interface I'd struggle anyway. :-)
> If you want to learn I can teach you. ...
wow, thank you very much for the offer. while I won't tire of seeing images of
rendered "real world organisms" posted here, I have rarely felt wanting to
create such scenes. I'm more interested in creating abstract space(s).
wrt to the previous tree - I now think the "atmosphere" is very Haruki Murakami.
> ... It can "populate" objects in a 2d array. ... adjust the distribution ...
> I feel this is a good function, but I cannot tried many tree type because I use
> the free version.
the result bears out the feeling. :-) are there no open source tools doing a
similar job?
regards, jr.
> hi,
Maybe I can take a look at his novel.
> > the free version.
> similar job?
> regards, jr.
I don't know. I'm familiar with pov ray.
On 18-1-2019 15:27, And wrote:
> //#declare trunk_13=
> #declare PR_DIFFUSE=pigment {color rgb <0.056,0.058,0.036> transmit 0/100 }
> #declare F1=finish{
> diffuse 1
> oren_nayar 1.117
[snip]
oren_nayar? I suppose that is a macro you wrote yourself based on this
reflectance model? It does not seem to be mentioned in the POV-Ray docs...
> > #declare F1=finish{
> > diffuse 1
> > oren_nayar 1.117
> [snip]
> Thomas
new feature of 3.7.? The newest uberpov has this feature, too.
>>> #declare F1=finish{
>>> diffuse 1
>>> oren_nayar 1.117
>> [snip]
>> Thomas
Not in 3.7, nor in 3.8 alpha. So, must be UberPOV.
> Thomas
No, a while back I recall clipka experimenting with using different reflection
models
Mostly since I spent some time trying to understand what went into it.
http://news.povray.org/povray.binaries.images/thread/%3Cweb.57cb6721f854a3db5e7df57c0@news.povray.org%3E/
So, it is/was actual POV-Ray:
http://news.povray.org/povray.beta-test/thread/%3C57040752@news.povray.org%3E/
> ...it is/was actual POV-Ray:
I just read (or re-read?) that older post; fascinating.
So I tried using the oren_nayer feature in one of the recent 3.8 alphas, but
it's not recognized. I guess it never made it into 3.8's development? Pity that;
the feature sounds quite interesting.
"Kenneth" <kdw### [at] gmailcom> wrote:
> So I tried using the oren_nayer feature in one of the recent 3.8 alphas...
I meant oren_nayar
Am 19.01.2019 um 18:13 schrieb Kenneth:
The problem was that the `albedo` mode of operation is poorly defined
for oren-nayar and the other one (I think it was minnaert, would have to
look it up), and I haven't made up my mind yet how to solve this.
?! I think the problem for oren nayar model is solved in previous:
with the total reflection light counted.
And the appearance of the rendered image with oren-nayar surface convinces me...
