POV-Ray : Newsgroups : povray.binaries.images : Moire patterns when trying to create isosurface sphere Server Time
19 May 2024 11:05:01 EDT (-0400)
  Moire patterns when trying to create isosurface sphere (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Moire patterns when trying to create isosurface sphere
Date: 6 Jan 2019 17:55:01
Message: <web.5c32873946f01a81cd98345b0@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> ...And I was wondering where those moire patterns
> were coming from-- thinking that the planet was just a simple sphere object, not
> an isosurface.)
Just took a look at COMPATT's previous post about this. Duh.
Date: 7 Jan 2019 02:40:03
Message: <5c330253$1@news.povray.org>
On 6-1-2019 19:43, jr wrote:
> hi,
>> "jr" <cre### [at] gmailcom> wrote:
>>> with 'polarity on'
>> What's that? I must have missed a new feature(?) somehow...
> looks like you did.  :-)  the last paragraph in section "3.5.1.1.6 Isosurface"
> in the 3.8 docs reads:
> By default, the inside of an isosurface is defined as the set of all points
> inside the contained_by shape where the function values are below the threshold.
> New in version 3.8 this can be changed via the polarity keyword. Specifying a
> positive setting or on will instead cause function values above the threshold to
> be considered inside. Specifying a negative setting or off will give the default
> behavior.
Interesting. I missed that too. Going to play right now as I am working
on an isosurface...
Date: 7 Jan 2019 02:50:01
Message: <5c3304a9$1@news.povray.org>
> on an isosurface...
Hmmm... right. Not what I expected. Polarity may be only relevant if the
contained_by shape is close to the isosurface one, i.e. spheres,
cylinders, cubes. Otherwise, I don't understand its usefulness. Polarity
on just renders the contained_by shape, whatever its (positive) value.
Did I miss something? Probably.
Date: 7 Jan 2019 05:45:39
Message: <5c332dd3$1@news.povray.org>
Am 07.01.2019 um 08:49 schrieb Thomas de Groot:
>> working on an isosurface...
The magnitude of the `polarity` paramezer is irrelevant, only the sign
matters (or, more precisely, whether the parameter is positive; zero has
the same effect as a negative value).
`polarity 1` should have the same effect as flipping the signs of both
the function and the threshold.
If your isosurface is fully inside the `contained_by` shpe, then it is
perfectly normal that `polarity 1` will cause you to see only the
`contained_by` shape, because everything outside the `contained_by`
shape is always considered "outside" (*), while inside that shape the
"inside" and "outside" are now the other way round.
To just flip "inside" and "outside" (including the space outside the
`contained_by` shape, you should use the `inverse` keyword instead.
The `polarity` keyword is primarily intended to complement the
`potential` pattern feature, which would behave inconsistently between
blobs and isosurfaces unless positive polarity mode is used for the latter.
Date: 7 Jan 2019 06:54:11
Message: <5c333de3$1@news.povray.org>
>> the contained_by shape is close to the isosurface one, i.e. spheres,
>> Polarity on just renders the contained_by shape, whatever its
>> (positive) value.
OK, I guess I understand. I then wonder if the polarity use by Jr to
solve COMPATT's problem is correct. My uneducated guess would be 'no'. ;-)
Date: 7 Jan 2019 06:55:01
Message: <web.5c333d6246f01a8148892b50@news.povray.org>
hi,
> > Hmmm... right. Not what I expected. ...
so why is the parameter a float, when (just) a boolean would seem to be a better
fit?  future expansion?
regards, jr.
Date: 7 Jan 2019 07:20:01
Message: <web.5c3343a446f01a8148892b50@news.povray.org>
hi,
correct, hence "I'm sure it isn't "the correct way" of doing, but.." result.
btw, is your computer's clock off by (about) 2 minutes?
regards, jr.
Date: 7 Jan 2019 07:50:00
Message: <web.5c334a6946f01a8148892b50@news.povray.org>
hi,
> > an isosurface.)
the clue was in the title!  :-)  (more of a grin ;-))
regards, jr.
Date: 7 Jan 2019 11:22:10
Message: <5c337cb2$1@news.povray.org>
Am 07.01.2019 um 12:53 schrieb jr:
No; I just think the parameter should be `polarity SIGN` rather than
`positive_polarity BOOL`; but POV-Ray doesn't have a `SIGN` type, so I
went for the next best thing, which is the sign of a `FLOAT`. So in a
sense the "most official" syntax is `polarity +1` or `polarity -1`.
Since this has the side effect that `polarity on` /will/ also inevitably
work, I opted to make `polarity off` work as well (meaning `polarity 0`
would have to act like `polarity -1`).
Allowing for arbitrary magnitude was also pretty much a no-brainer,
because it simplifies the implementation, while having the side effect
that it is easier to use in cases where the polarity might be derived
from some computed value.
Date: 7 Jan 2019 12:20:03
Message: <web.5c33898c46f01a8148892b50@news.povray.org>
hi,
ah, thank you.
regards, jr.
