POV-Ray : Newsgroups : povray.binaries.images : Moire patterns when trying to create isosurface sphere Server Time
2 Jun 2024 00:54:52 EDT (-0400)
  Moire patterns when trying to create isosurface sphere (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Moire patterns when trying to create isosurface sphere
Date: 5 Jan 2019 15:25:00
Message: <web.5c31118446f01a8148892b50@news.povray.org>
"Dave Blandston" <nomail@nomail> wrote:
> Glad you found a solution!
cheers Dave.  too late, it seems, to be of use to COMPATT.
regards, jr.
Date: 6 Jan 2019 13:10:00
Message: <web.5c32438746f01a81cd98345b0@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> with 'polarity on'
What's that? I must have missed a new feature(?) somehow...
Date: 6 Jan 2019 13:45:00
Message: <web.5c324c5646f01a8148892b50@news.povray.org>
hi,
> > with 'polarity on'
looks like you did.  :-)  the last paragraph in section "3.5.1.1.6 Isosurface"
in the 3.8 docs reads:
By default, the inside of an isosurface is defined as the set of all points
inside the contained_by shape where the function values are below the threshold.
New in version 3.8 this can be changed via the polarity keyword. Specifying a
positive setting or on will instead cause function values above the threshold to
be considered inside. Specifying a negative setting or off will give the default
behavior.
regards, jr.
Date: 6 Jan 2019 17:50:00
Message: <web.5c3284ff46f01a81cd98345b0@news.povray.org>
> hi,
> > > with 'polarity on'
> in the 3.8 docs reads: ...
Thanks! Yep, it's new to me. (And I was wondering where those moire patterns
were coming from-- thinking that the planet was just a simple sphere object, not
an isosurface.)
Date: 6 Jan 2019 17:55:01
Message: <web.5c32873946f01a81cd98345b0@news.povray.org>
> ...And I was wondering where those moire patterns
> an isosurface.)
Just took a look at COMPATT's previous post about this. Duh.
Date: 7 Jan 2019 02:40:03
Message: <5c330253$1@news.povray.org>
On 6-1-2019 19:43, jr wrote:
> hi,
>>> with 'polarity on'
> behavior.
Interesting. I missed that too. Going to play right now as I am working
on an isosurface...
Date: 7 Jan 2019 02:50:01
Message: <5c3304a9$1@news.povray.org>
> on an isosurface...
Hmmm... right. Not what I expected. Polarity may be only relevant if the
contained_by shape is close to the isosurface one, i.e. spheres,
cylinders, cubes. Otherwise, I don't understand its usefulness. Polarity
on just renders the contained_by shape, whatever its (positive) value.
Did I miss something? Probably.
Date: 7 Jan 2019 05:45:39
Message: <5c332dd3$1@news.povray.org>
Am 07.01.2019 um 08:49 schrieb Thomas de Groot:
>> working on an isosurface...
The magnitude of the `polarity` paramezer is irrelevant, only the sign
matters (or, more precisely, whether the parameter is positive; zero has
the same effect as a negative value).
`polarity 1` should have the same effect as flipping the signs of both
the function and the threshold.
If your isosurface is fully inside the `contained_by` shpe, then it is
perfectly normal that `polarity 1` will cause you to see only the
`contained_by` shape, because everything outside the `contained_by`
shape is always considered "outside" (*), while inside that shape the
"inside" and "outside" are now the other way round.
To just flip "inside" and "outside" (including the space outside the
`contained_by` shape, you should use the `inverse` keyword instead.
The `polarity` keyword is primarily intended to complement the
`potential` pattern feature, which would behave inconsistently between
blobs and isosurfaces unless positive polarity mode is used for the latter.
Date: 7 Jan 2019 06:54:11
Message: <5c333de3$1@news.povray.org>
>> the contained_by shape is close to the isosurface one, i.e. spheres,
>> Polarity on just renders the contained_by shape, whatever its
>> (positive) value.
OK, I guess I understand. I then wonder if the polarity use by Jr to
solve COMPATT's problem is correct. My uneducated guess would be 'no'. ;-)
Date: 7 Jan 2019 06:55:01
Message: <web.5c333d6246f01a8148892b50@news.povray.org>
hi,
> > Hmmm... right. Not what I expected. ...
so why is the parameter a float, when (just) a boolean would seem to be a better
fit?  future expansion?
regards, jr.
