Am 27.08.2018 um 15:33 schrieb clipka:
> @Ive: Well, I'll be! - This is an image that IC (1.0.12) fails to
> display properly.
Scratch that. The PNG uses alpha, with the colour channel set to pitch
black, while also carrying a bKGD chunk recommending black background.
Black on black - of course IC /correctly/ shows this as just a uniform
black slab if "use alpha" and "use background" are enabled.
I should have known better than to doubt IC ;)
> In jpg it's better....;-))))
> Albun
no it isn't
This is one of those case where png is the preferred file type :)
If I understand your question correctly, you're asking if anyone else
ever created pixel-art with POV-Ray, by using pixel-sized objects,
right? If so: yes, I have, a long time ago, before I learned about
processing.org.
I used POV-Ray because I knew the language and wanted to do some
procedural pixel-art. But Processing is very easy to learn and much more
suited for procedural pixel-art.
cu!
ZK
Le 18-08-27 à 09:20, Albun a écrit :
> "Albun" <nomail@nomail> wrote:
>> Well, i think that you can see image now
>> If yes, it's incredible to explain, so rewind to 1st message.
>> My english is a google traduction....
>> Albun
> Albun
46K as JPG, and 11.2K as PNG. PNG win by a factor of 4.5.
> Albun
What am I looking at?
Mike
Looks like an Autostereogram to me...
Squint. :D
> Squint. :D
Hurts. My old eyes can't any more. :-|
Bonjour,
ce sujet sur le forum.
Albun
I was never able to do it in my life.
Mike
clipka <ano### [at] anonymous org> wrote:
> Am 27.08.2018 um 14:12 schrieb Albun:
> display properly.
> @Album: What are we seeing there? Is this an animation of a sprite with
> about 400 (20x20) frames in one single PNG image?
> You still didn't tell us your native language. "traduction" hints at a
> romanic language, maybe French?
> I'm sure we have enough French-speaking people around here that it would
> be worth trying to ask your question again in French.
Hello/Hi
French is my birth language. If you ever need help... :D. There is an
international section in this forum in case of need anyway. I don't post often
but come from time to time on this forum.
Me neither.
dik
Rendered 1024 of 921600 pixels (0%)
