Use some codes to modify photos.
#declare p_modify1 =
pigment{
pigment_pattern{p_original}
pigment_map{
#for(i,0,255)
[i/255,
bumps
scale 1/input_wide_res
scale 4.8
rotate <0,0,20>
color_map{
[0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.1>]
[0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.9>]
Download 'photos1.jpg' (1852 KB)
Preview of image 'photos1.jpg'
Another test
pigment{
pigment_map{
#for(i,0,255)
[i/255,
bumps
scale 0.8
rotate <0,0,20>
color_map{
Download 'photo2.jpg' (732 KB)
Preview of image 'photo2.jpg'
VERY cool. I like both images. Thanks for the interesting code.
With some appropriate functions maybe-- to split the original color image into 3
functions-- you might be able to do all three *color* channels in a similar way,
for a painterly 'pointilism' effect.
It is a bit like your airbrush.
I ever split it into 3 functions. But re-composite them using this code the
result is weird.
I often using it to create two color image.
Download 'image_render_enviroment 19.png' (575 KB)
Preview of image 'image_render_enviroment 19.png'
This time using quilted
pigment{
pigment_map{
#for(i,0,255)
[i/255,
quilted control0 0.5 control1 1
scale 4.8
rotate <0,0,20>
color_map{
[0.2+0.6*(1-pow(i/255,1/3)) rgb<0.24, 0.167, 0.167>]
[0.2+0.6*(1-pow(i/255,1/3)) rgb<1,1,0.9>]
Download 'image_render_enviroment 18 quilted.png' (1761 KB)
Preview of image 'image_render_enviroment 18 quilted.png'
> Thomas
I'd like to see.
> result is weird.
I agree to Kenneth - very cool methods - and thanks for the code.
With 3 functions I got this nice image ("glasses" from Hall of Fame as input).
Norbert
Download 'pattern_blend_color.jpg' (629 KB)
Preview of image 'pattern_blend_color.jpg'
YES! Very impressive. You picked a good image to work with, too, nice color
values.
>> Thomas
> I'd like to see.
http://news.povray.org/povray.binaries.images/thread/%3C48295282%40news.povray.org%3E/
