POV-Ray : Newsgroups : povray.binaries.images : pattern blend Server Time
4 Apr 2026 19:05:57 EDT (-0400)
  pattern blend (Message 57 to 66 of 66)
Subject: Re: pattern blend
Date: 12 Mar 2018 09:23:11
Message: <5aa67f3f$1@news.povray.org>
On 2018-03-09 04:27 AM (+4), Stephen wrote:
> On 09/03/2018 07:42, Thomas de Groot wrote:
>> On 8-3-2018 20:14, Stephen wrote:
>>> On 08/03/2018 12:45, Thomas de Groot wrote:
>>>> Want to know where this is? Go to: 52 degrees 53 minutes 46.25
>>>> seconds North, and 6 degrees 15 minutes 46.11 seconds East.
>> I played safe as I was not sure if it would be displayed correctly.
>> Apparently unfounded fear. :-)
I find that special characters display correctly in the Web view only if
I post via the Web view, but Thunderbird displays them correctly
regardless of which software was use to post.
It appears that if the original article uses ISO 8879 Latin-1 encoding,
the Web software translates it to UTF-8, but then displays the
translated sequence as if it were still ISO 8879, effectively
translating it twice.
Numbers?  Who has the energy for number codes?  It's Compose * 0 on
/real/ operating systems.
Date: 12 Mar 2018 10:52:34
Message: <5aa69432$1@news.povray.org>
Am 12.03.2018 um 14:23 schrieb Cousin Ricky:
>>>> 52°  53' 46.25"N  6° 15' 46.11"E in google terms
>> Luckily I know that Ali + 248 is °
Who /needs/ number codes?
On /real keyboards/, it's simply Shift and the leftmost key in the
numeric row. :P
On /real keyboards/, you can even type stuff like 1 µm³ ("one cubic
micrometre") without memorizing anything fancy. It's all printed right
on the keyboard.
Oh, and although on /real keyboards/ the most common non-ASCII Latin
characters are of course äöüß and ÄÖÜẞ (*), there also isn't any need
for a Compose key to write ÁÉÍÓÚ, áéíóú, ÀÈÌÒÙ, àèìòù, ÂÊÎÔÛ
or âêîôû.
(Did you US folks know that we Germans have two more keys than you do?
Well, sort of - there's one additional physical key, and then our two
Alt keys actually do different things. Kind of like the Brits. Or the
French. Or the Spanish. Or the Portugese. Or virtually anyone except you
poor US sods with your pityful 101/104 keys :P)
(*Fun fact to know: As of a few months ago, the statement that the
German sharp s exists only in its lowercase form is officially no longer
true: The capital sharp S (which has been defined in Unicode since 2008)
has finally beed officially adopted into the German language; and at
least in Windows 10 using a /real keyboard/, it can be entered
surprisingly easy, albeit only 80% intuitive.)
Date: 12 Mar 2018 12:48:16
Message: <5aa6af50@news.povray.org>
A Pover who cares not for numbers!
What is the world coming to?
<aside>
How is the Island?
There was an article about the BVI, last week. It is still in a poor
state. Was thinking about you.
Regards
Date: 12 Mar 2018 17:49:14
Message: <5aa6f5da$1@news.povray.org>
> numeric row. :P
> on the keyboard.
ÂÊÎÔÛ or âêîôû.
Touché.
In my defense, I did not choose to be an American; the Danish sold my
island from under me 46 years before I was born.
Although, when I took an online test to see where I should move in the
extremely unlikely event that Donald Trump should become president, they
said Germany would be the best match for me.  Personally, I say make
Trump's immigration policy retroactive 2 generations and send /him/ back
to Germany.
Date: 12 Mar 2018 19:33:08
Message: <5aa70e34$1@news.povray.org>
Am 12.03.2018 um 22:49 schrieb Cousin Ricky:
> to Germany.
If you ever get your hands on a time machine, be careful - that plan
might backfire. According to German Wikipedia, during WW2 one of The
Don's uncles, John G. Trump, was instrumental in providing the US
military with the latest and greatest Radar equipment, and had also
contributed to the Manhattan Project (albeit involuntarily, by building
a high voltage generator in Philadelphia that was subsequently seized
for the project).
Also, by The Don's standards, there are two types of immigrants:
Norwegians and Bad Hombres. Back in 1885, Germans would certainly have
been considered the Norwegian type.
Date: 16 Mar 2018 23:35:00
Message: <web.5aac8b2f8351d7b0de6196580@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> Stephen <mca### [at] aolcom> wrote:
> > Has anyone tried to produce a solarisation effect?
> Hi,
> with a simple approach I got this image - here is the code
Hi Norbert
Your post inspired me to try to achieve image solarisation with the
new user defined pattern in v3.8:
http://wiki.povray.org/content/Reference:User_Defined_Pattern
BTW: Nice tricks to scale the camera vectors by the image dimensions
and to make a V-function with the max function !
Here's the results from my experiment:
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Tor Olav Kristensen
// http://subcube.com
// Solarizing an image
#version 3.8;
// For this image made by Gilles Tran:
// http://hof.povray.org/images/glasses.jpg
#declare GuessedGamma = 2.2;
global_settings { assumed_gamma GuessedGamma }
// Render with same image dimensions as the original image for best
// result. Anti-aliasing can be used. E.g.: +w1024 +h768 +a0.1 +FJ
#declare PigmentFn =
    function {
            image_map {
                jpeg "glasses.jpg"  // 1024 x 768 pixels
                gamma GuessedGamma
                interpolate 2
// Frequency = 0.5 and Inverted = true
// - will give original image (approximately)
#declare Frequency = 1.0; // Try 0.5, 1.0, 1.5, 2.0, ...
#declare Inverted = false;
#declare Fn = function(x) { Frequency*mod(x, 1/Frequency) }
#declare VeeFn = function(x) { 2*max(Fn(x), 1 - Fn(x)) - 1 }
#declare InvertedVeeFn = function(x) { 1 - VeeFn(x) };
#if (Inverted)
    #declare SolarizeFn = InvertedVeeFn ;
#else
    #declare SolarizeFn = VeeFn;
#end // if
box {
    <0, 0, 0>, <1, 1, 1>
            user_defined {
                function { SolarizeFn(PigmentFn(x, y, z).red  ) },
                function { SolarizeFn(PigmentFn(x, y, z).green) },
                function { SolarizeFn(PigmentFn(x, y, z).blue ) }
        finish {
            diffuse 0
            emission color rgb <1, 1, 1>
    translate -<1, 1, 0>/2
    scale <image_width, image_height, 1>
    orthographic
    right image_width*x
    up image_height*y
Download 'solarized glasses.jpg' (77 KB)
Preview of image 'solarized glasses.jpg'
Date: 17 Mar 2018 00:30:00
Message: <web.5aac991a8351d7b0de6196580@news.povray.org>
I just did some layer arithmetic in Gimp with the original image in the bottom
layer and my rendered image in the top layer - and found that Norbert is
probably right: It's best to not use any anti-aliasing for this.
Tor Olav
http://subcube.com
Date: 17 Mar 2018 10:30:01
Message: <web.5aad26338351d7b09cfcc7a00@news.povray.org>
> Hi Norbert
Hi Tor,
very well done.
I've to look more in user defined pattern - definitively.
Norbert
Date: 3 Apr 2018 12:20:01
Message: <web.5ac3a9038351d7b05bf3e3600@news.povray.org>
> > Hi Norbert
> Hi Tor,
> very well done.
Thank you Norbert
For those of you that hasn't started to experiment with v3.8 yet,
here is some code that can be used with v3.7 to achieve the same:
#version 3.7;
// result. E.g.: +w1024 +h768 +FJ
    function {
            image_map {
                gamma GuessedGamma
                interpolate 2
#declare Fn = function(x) { Frequency*mod(x, 1/Frequency) };
#declare VeeFn = function(x) { 2*max(Fn(x), 1 - Fn(x)) - 1 };
#if (Inverted)
#else
#end // if
#declare PigmentR =
        color_map {
            [ 0 color red   0 ]
            [ 1 color red   3 ]
#declare PigmentG =
        color_map {
            [ 0 color green 0 ]
            [ 1 color green 3 ]
#declare PigmentB =
        color_map {
            [ 0 color blue  0 ]
            [ 1 color blue  3 ]
box {
            average
            pigment_map {
                [ PigmentR ]
                [ PigmentG ]
                [ PigmentB ]
        finish {
            diffuse 0
    orthographic
    right image_width*x
    up image_height*y
Date: 4 Oct 2021 11:55:00
Message: <web.615b22ba8351d7b09cd6027caa81652d@news.povray.org>
> > Very interesting! May I use your p_modify versions for my video
> > experiments on YouTube
> > (https://www.youtube.com/channel/UCFgDHkMGDuOkiSnc6w6eUWg)? To those who
> > modificated it, I ask the same question...
> I am working on some general changes of the code, which I shall post
> later. You have my full permission, but And is the real owner/originator.
> Thomas
I'm sorry, actually, I saw this method on a website. here:
http://runevision.com/3d/povgoodies/
: Pattern Control Trick
Once I decide to use it. I will find out how it composite. I'm not worried about
the copyright because I think it is just a composite of two original function
provided by POV-Ray.
