POV-Ray : Newsgroups : povray.binaries.images : pattern blend Server Time
14 Mar 2026 06:00:24 EDT (-0400)
  pattern blend (Message 37 to 46 of 66)
Subject: Re: pattern blend
Date: 6 Mar 2018 02:42:25
Message: <5a9e4661@news.povray.org>
On 5-3-2018 21:51, Kenneth wrote:
>>> I shall make a small test scene. A way for me to remember stuff.
>> Like this. Left, image gamma is 1.0; right, image gamma is 2.2.
> Nice! And you picked a good pattern to show it off.
> The real *fun* begins when you take a height_field image (made elsewhere) and
> *combine* it with a procedural pigment or pattern-- both of which can be
> gamma-bent. It's a bit more complicated to code, but I was working up an example
> anyway, and will post in a new thread. (BTW, some other interesting effects can
> be gotten by making the gamma *less than* 1.0.)
Been there done that ;-)
Even better if you use the image and the pattern within functions and
combine those.
Date: 6 Mar 2018 02:48:13
Message: <5a9e47bd@news.povray.org>
On 5-3-2018 21:36, Kenneth wrote:
> "Norbert Kern" <nor### [at] t-onlinede> wrote:
>> Stephen <mca### [at] aolcom> wrote:
>>> Has anyone tried to produce a solarisation effect?
>> Hi,
>> with a simple approach I got this image - here is the code
> Brilliant! I actually didn't think it was possible.
*everything* is possible in POV-Ray! ;-)
Date: 6 Mar 2018 04:13:03
Message: <5a9e5b9f$1@news.povray.org>
Am 06.03.2018 um 00:02 schrieb Kenneth:
> "Kenneth" <kdw### [at] gmailcom> wrote:
>> (There's also a HF difference
>> between images SAVED at different gamma values, for the same reason-- 1.0 being
>> a linear slope, 2.2 being more of a curve.)
> Uh, I'm not so sure about that now. I made a test scene a couple of weeks ago
> that showed this. (Or so I thought.) Now, a newer test scene shows no
> difference-- producing the same 'linear' height_field slopes no matter what
> gamma the images are saved at (with either JPEG *or* PNG image files.) But then
> again, I'm using my older wonky Photoshop 5 to make and save the original
> images, which can't be completely trusted as far as gamma goes.  Hmm, a mystery.
By default, when using images in a height_field, POV-Ray presumes that
the image data is to be taken linearly no matter what gamma the file
claims to match, e.g. in an 8-bit image a data value of 240 will always
be interpreted as a height of 240/255, even if the file claims to be
saved for a display gamma of 2.2.
So if you just create an image in Photoshop and /assign/ a particular
gamma to it later, there will be no difference as the image data will
not change. You'd need to /convert/ the image from one gamma to another
to see an effect.
Date: 6 Mar 2018 11:30:04
Message: <web.5a9ec17a8351d7b0a47873e10@news.povray.org>
> > gamma the images are saved at...
> to see an effect.
Thanks. My older test scene was also more complicated-- using a HF-image gamma
*and* a pigment_map with a blend mode/blend gamma. That combination probably
confused the result for me.
Date: 7 Mar 2018 07:25:45
Message: <5a9fda49$1@news.povray.org>
Hi(gh)!
On 02.03.2018 16:27, And wrote:
> #declare p_modify1 =
> pigment{
>      pigment_pattern{p_original}
>      pigment_map{
>      #for(i,0,255)
>          [i/255,
>          bumps
>          scale 1/input_wide_res
>          scale 4.8
>          rotate <0,0,20>
>              color_map{
>              [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.1>]
>              [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.9>]
>      #end
Very interesting! May I use your p_modify versions for my video
experiments on YouTube
(https://www.youtube.com/channel/UCFgDHkMGDuOkiSnc6w6eUWg)? To those who
modificated it, I ask the same question...
See you in Khyberspace!
Yadgar
Date: 7 Mar 2018 07:40:08
Message: <5a9fdda8@news.povray.org>
I am working on some general changes of the code, which I shall post
later. You have my full permission, but And is the real owner/originator.
Date: 7 Mar 2018 09:15:01
Message: <web.5a9ff3c68351d7b0f57012f0@news.povray.org>
> Yadgar
of course
Norbert
Date: 8 Mar 2018 07:33:40
Message: <5aa12da4@news.povray.org>
On 5-3-2018 17:52, Stephen wrote:
> On 05/03/2018 16:50, Stephen wrote:
>> Oo! shiny. I like.
>> You are on a roll, Norbert. :-)
> It looks good as a negative, too (also).
Absolutely! This one is inversed.
Download 'nk_solarisation_invert.jpg' (287 KB)
Preview of image 'nk_solarisation_invert.jpg'
Date: 8 Mar 2018 07:46:04
Message: <5aa1308c$1@news.povray.org>
>>> Oo! shiny. I like.
Want to know where this is? Go to: 52 degrees 53 minutes 46.25 seconds
North, and 6 degrees 15 minutes 46.11 seconds East.
Date: 8 Mar 2018 08:02:42
Message: <5aa13472$1@news.povray.org>
>>> Oo! shiny. I like.
Me like. :-)
Regards
