POV-Ray : Newsgroups : povray.binaries.images : Re: Chipboard Texture Server Time
2 Jun 2024 15:00:17 EDT (-0400)
  Re: Chipboard Texture (Message 11 to 13 of 13)
Subject: Re: Chipboard Texture
Date: 31 Jan 2018 19:26:04
Message: <5a725e9c@news.povray.org>
> This one actually looks a lot like a pine-borer chewed plank, which is a great
> texture in its own right!  :)
> I was reluctant to post this question, because I was sure it was something
> trivial, but apparently it actually is a bit more challenging than it looks at
> first glance  :O
> I'd be happy with a "chipboard" since the dimensions of the chips would probably
> be suited to simulation by a crackle or other similar pattern.  OSB is "oriented
> strand board", so it's composed of larger strips of wood that are, as the name
> implies, oriented along one axis, thus giving it structural strength when used
> as intended.  Whatever they use for a binder sure seems to be fairly water
> resistant.
Come in two version : Cheap and waterproof.
Date: 2 Feb 2018 03:28:19
Message: <5a742123@news.povray.org>
Hi(gh)!
On 29.01.2018 17:43, Kontemplator wrote:
> In response to Bald Eagle's question ...
http://news.povray.org/povray.newusers/message/%3Cweb.5a6f217fe33edc0fc437ac910%40news.povray.org%3E/#%3Cweb.5a6f217fe3
> I don't know how your chipboards look like
Here is my version - from the, unfortunately, unfinished modeling of an
Eminent Solina P-240 electronic organ, back in 2007:
#declare Pressboard =
texture
   pigment
     granite
     color_map
       [0 rgb <0.95, 0.92, 0.76> ]
       [1 rgb <0.76, 0.59, 0.45> ]
     scale 0.01
     turbulence 2
   finish { brilliance 0.09 ambient 0.1 diffuse 1 }
Attached are also two views of the board, one from a distance and one
more close-up!
See you in Khyberspace!
Yadgar
Download '2007-12-28 eminent solina p-240, full view.jpg' (33 KB) Download '2007-12-28 eminent solina p-240, playtable pressboard base with opening for output plugs.jpg' (102 KB)
Preview of image '2007-12-28 eminent solina p-240, full view.jpg'
Preview of image '2007-12-28 eminent solina p-240, playtable pressboard base with opening for output plugs.jpg'
Date: 4 Feb 2018 15:55:00
Message: <web.5a777222eeb2419d5cafe28e0@news.povray.org>
I gave it another go, and I think the key is just getting a good wood texture
with the proper shading, not overly rotating it away from the plane of the
sheet, then using a crackle texture and stretching it.
Still needs work, but it's a lot better than my previous, abysmal efforts.
Download 'chipboard.png' (223 KB)
Preview of image 'chipboard.png'
