![](/i/fill.gif) |
I slightly revised my file, then post here. In fact I'm not sure its scale is
right or not. I haven't seen snow in real life. It's a box with 3.2 meter side
lengths.
#version 3.7;
global_settings{
max_trace_level 3
assumed_gamma 1.0
adc_bailout 0.007
mm_per_unit 1000 //important for subsurface
radiosity{
pretrace_start 64/image_width
pretrace_end 4/image_width
count 60
nearest_count 6
error_bound 0.64
recursion_limit 8
low_error_factor 0.5
gray_threshold 0.0
brightness 1
subsurface{
samples 10, 10
radiosity off
default{
texture{
pigment {rgb<0.2,0.2,0.2>}
finish{ambient 0 diffuse 0}
//---------------------background------------------------
background{rgb <0,0,0>}
//-------------------settings--------------------------------
//--------------------light source-----------------------------
light_source {
<-4, -2.5, 4>*100
color rgb <1.0, 0.88, 0.76>*0.80
parallel
point_at <0.0, 0.0, 0.0>
rotate <0,0,-56>
sky_sphere{
pigment {rgb <0.35,0.55,1>*0.36}
//My render is z toward sky, xy horizon
camera{
location <8,4,4>
look_at <0, 0, 0>
right <-4/3,0,0>
sky <0,0,1>
angle 24
#declare material_snow =
material{
texture{
pigment{
rgb<0.93,0.93,0.93>
finish{
diffuse 1.0
subsurface{translucency rgb<1,1,1>*6}
//----------------ground------------------------
#declare t_soil1=
texture{
pigment{rgb<0.2,0.164,0.1>*0.9}
finish{ambient 0 diffuse 1}
plane{
<0,0,1>,0
texture{t_soil1}
//--------------------cloud----------------------
#include "functions.inc"
#declare f_test =
function(x,y,z) {
+0.20*sum(i, 0, 3, pow(abs(f_noise3d(x*pow(2, i)/0.3, y*pow(2, i)/0.3,
z*pow(2, i)/0.3)), 2.5)/pow(2.0, i) )
isosurface {
function {0.5 - f_test(x,y,z)*3.5*3.5*z*exp(-3.5*z) -
0.32*3.5*3.5*z*exp(-3.5*z)}
contained_by { box { <-1.0, -1.0, 0.0>, <1.0, 1.0, 1.0> } }
threshold 0.0
accuracy 0.001
max_gradient 2
//all_intersections
//open
material{
material_snow
scale <1.6, 1.6, 0.8>
translate<0,0,0>
#declare t_soil2=
texture{
pigment{
function{0.5 + 0.2* (0.5 - f_test(x,y,z)*3.5*3.5*z*exp(-3.5*z) -
0.32*3.5*3.5*z*exp(-3.5*z))}
color_map{
[0.0 rgb<0.2,0.164,0.1>*0.03]
[0.504 rgb<0.2,0.164,0.1>*0.03]
[0.533 rgb<0.2,0.164,0.1>*0.9]
[1.0 rgb<0.2,0.164,0.1>*0.9]
box{
<-1.601, -1.601, 0.0>, <1.601, 1.601, 0.20>
texture{t_soil2}
Download 'snow.png' (303 KB)
Preview of image 'snow.png'
![snow.png](/povray.binaries.images/attachment/%3Cweb.5a20e35f56f808c27e12b7e70%40news.povray.org%3E/snow.png?ttop=430894&toff=350&preview=1)
![](/i/fill.gif) |
