POV-Ray : Newsgroups : povray.binaries.images : snow subsurface file Server Time
5 Jul 2024 17:44:02 EDT (-0400)
  snow subsurface file (Message 11 to 14 of 14)
Subject: Re: snow subsurface file
Date: 1 Dec 2017 07:14:55
Message: <5a2147bf$1@news.povray.org>
On 1-12-2017 12:20, Stephen wrote:
> On 01/12/2017 11:10, Sven Littkowski wrote:
>> On 01.12.2017 05:19, Stephen wrote:
>>> I guessed you did. I know the equivalent is used in some parts of
>>> Germany. It is the opposite of backhanded compliment.
>> True again. :-)
> I'm good, aren't I. ;-)
Not bad. ;-)
Date: 1 Dec 2017 07:56:32
Message: <5a215180$1@news.povray.org>
>>> True again. :-)
> Not bad. ;-)
Iffy
Regards
Date: 1 Dec 2017 07:58:05
Message: <5a2151dd$1@news.povray.org>
>>> True again. :-)
>> Regards
>>       Stephen
> You are a nice man.
Tehe, fooled another one. :-)
Regards
Date: 1 Dec 2017 22:06:04
Message: <5a22189c@news.povray.org>
> I slightly revised my file, then post here. In fact I'm not sure its scale is
> right or not. I haven't seen snow in real life. It's a box with 3.2 meter side
> lengths.
> #version 3.7;
> global_settings{
> max_trace_level 3
> assumed_gamma 1.0
> adc_bailout 0.007
> mm_per_unit 1000 //important for subsurface
> radiosity{
>   pretrace_start 64/image_width
>   pretrace_end   4/image_width
>   count 60
>   nearest_count 6
>   error_bound 0.64
>   recursion_limit 8
>   low_error_factor 0.5
>   gray_threshold 0.0
>   brightness 1
>      subsurface{
>          samples 10, 10
>          radiosity off
> default{
> texture{
>      pigment {rgb<0.2,0.2,0.2>}
>      finish{ambient 0 diffuse 0}
> //---------------------background------------------------
> background{rgb <0,0,0>}
> //-------------------settings--------------------------------
> //--------------------light source-----------------------------
> light_source {
> <-4, -2.5, 4>*100
> color rgb <1.0, 0.88, 0.76>*0.80
> parallel
> point_at <0.0, 0.0, 0.0>
> rotate <0,0,-56>
> sky_sphere{
>      pigment {rgb <0.35,0.55,1>*0.36}
> //My render is z toward sky, xy horizon
> camera{
> location <8,4,4>
> look_at <0, 0, 0>
> right <-4/3,0,0>
> sky <0,0,1>
> angle 24
> #declare material_snow =
> material{
>      texture{
>          pigment{
>          rgb<0.93,0.93,0.93>
>          finish{
>              diffuse 1.0
>              subsurface{translucency rgb<1,1,1>*6}
> //----------------ground------------------------
> #declare t_soil1=
> texture{
>      pigment{rgb<0.2,0.164,0.1>*0.9}
>      finish{ambient 0 diffuse 1}
> plane{
> <0,0,1>,0
> texture{t_soil1}
> //--------------------cloud----------------------
> #include "functions.inc"
> #declare f_test =
> function(x,y,z) {
>     +0.20*sum(i, 0, 3, pow(abs(f_noise3d(x*pow(2, i)/0.3, y*pow(2, i)/0.3,
> z*pow(2, i)/0.3)), 2.5)/pow(2.0, i) )
> isosurface {
>      function {0.5 - f_test(x,y,z)*3.5*3.5*z*exp(-3.5*z) -
> 0.32*3.5*3.5*z*exp(-3.5*z)}
>      contained_by { box { <-1.0, -1.0, 0.0>, <1.0, 1.0, 1.0> } }
> threshold 0.0
> accuracy 0.001
> max_gradient 2
> //all_intersections
> //open
>      material{
>      material_snow
>      scale <1.6, 1.6, 0.8>
>      translate<0,0,0>
> #declare t_soil2=
> texture{
>      pigment{
>          function{0.5 + 0.2* (0.5 - f_test(x,y,z)*3.5*3.5*z*exp(-3.5*z) -
> 0.32*3.5*3.5*z*exp(-3.5*z))}
>          color_map{
>              [0.0 rgb<0.2,0.164,0.1>*0.03]
>              [0.504 rgb<0.2,0.164,0.1>*0.03]
>              [0.533 rgb<0.2,0.164,0.1>*0.9]
>              [1.0 rgb<0.2,0.164,0.1>*0.9]
> box{
> <-1.601, -1.601, 0.0>, <1.601, 1.601, 0.20>
> texture{t_soil2}
Not bad. Some packed, partly melted snow.
I've seen some snow those last days :)
