POV-Ray : Newsgroups : povray.binaries.images : Re: Cloud Surface Server Time
18 Mar 2026 00:46:23 EDT (-0400)
  Re: Cloud Surface (Message 20 to 29 of 109)
Subject: Re: Cloud Surface
Date: 25 Nov 2017 07:55:01
Message: <web.5a1967d89a2a53c1a6394f050@news.povray.org>
> Am 25.11.2017 um 05:06 schrieb And:
> > subsurface material cloud:
> Hm... I didn't think of using an isosurface to give shape to the cloud.
> Might actually work.
> Make sure to use an ior of 1.0. That's more realistic, and might reduce
> those bright blue band artifacts.
Um, I didn't add ior, should 1.0 be a default?
Date: 25 Nov 2017 09:59:19
Message: <5a198547@news.povray.org>
Am 25.11.2017 um 13:53 schrieb And:
Yes, if you don't specify an interior, or don't specify a refractive
index in the interior, it should default to 1.0 (or, more precisely, to
the same value as the atmosphere's refractive index, which currently
happens to be hard-coded to 1.0).
If the refractive index is at 1.0 already, then I haven't a clue where
the bright blue band artifacts might be coming from.
Date: 25 Nov 2017 14:22:40
Message: <5a19c300$1@news.povray.org>
Thank you, all these images are interesting. Especially
"interior_3f_scene 7_5 sss6 20m42s.png" looks like what I want.
Can you provide the source code for it? That would allow me to make some
test renders, to check out some more attributes of these clouds. Thank you.
http://www.avg.com
Date: 25 Nov 2017 14:24:00
Message: <5a19c350$1@news.povray.org>
On 24.11.2017 21:41, Alain wrote:
> If your media is not present enough, just increase it's density.
Thanks, will try.   :-)
http://www.avg.com
Date: 25 Nov 2017 14:24:35
Message: <5a19c373$1@news.povray.org>
On 25.11.2017 03:32, Thomas de Groot wrote:
> On the contrary and not to confuse the issue: use the version 3.7
> defaults which are method 3 intervals 1. Samples can be adapted as
> needed without serious render time loss.
Okay, thanks. Will try. :-)
http://www.avg.com
Date: 25 Nov 2017 14:31:26
Message: <5a19c50e$1@news.povray.org>
On 25.11.2017 06:35, clipka wrote:
> Those defaults are still valid for the newer versions with all the fancy
> media fixes (late v3.7.1 development versions and v3.8).
Can version 3.8 be downloaded already, even as beta?
http://www.avg.com
Date: 25 Nov 2017 15:55:00
Message: <web.5a19d86d9a2a53c15cafe28e0@news.povray.org>
Wow - that's not a cloud - that's a beautiful piece of snow/ice!
Thanks for posting that - it look great!  :)
Date: 25 Nov 2017 16:17:28
Message: <5a19dde8@news.povray.org>
UPDATE
See the three attached images.
The first image shows, how the scene is right now.
The second (photoshopped) image shows, how I want it.
The third image shows the horizon features (not colors) I want.
The ground fog should not reach so high. It should reach up to short
above the clouds (Y=1.0)  only and then be faded away at height Y=2.0.
Also, the clouds seem to have a brighter edge at the horizon. Thus I
wonder, if a media item can take that away and create an "atmospheric
layer" as seen on image 3 in pink (between the blue sky and the lilac
clouds).
See below the current scene code. Please feel free to make changes, to
demonstrate to me how to get those features. Big thanks.
#version 3.7;
global_settings
 assumed_gamma 1.0
#default
 finish { ambient 0.0 diffuse 0.0 }
#include "textures.inc"
#include "glass.inc"
#include "metals.inc"
#include "golds.inc"
camera
 /*ultra_wide_angle*/ angle 20
 location  < -35.0 , 11.0 ,-00.0 >
 look_at   < 0.0 , 5.0 , 0.0 >
// sun -------------------------------------------------------------------
light_source { < 250, 100, -250 > color < 1.0,  0.62353,  0.46667 > *7 }
// sky
sky_sphere
 pigment
  gradient < 0, 1, 0 >
  color_map
   [ 0.0 color rgb < 1.00000,  0.62353,  0.46667 > ] // Pink
   [ 0.4 color rgb < 0.64706,  0.30588,  0.59608 > ] // Purple
   [ 0.6 color rgb < 0.64706,  0.30588,  0.59608 > ] // Purple
   [ 1.0 color rgb < 1.00000,  0.62353,  0.46667 > ] // Pink
  scale 2
// ground -----------------------------------------------------------------
//---------------------------------<<< settings of squared plane dimensions
plane
 < 0, 1, 0 >, 0
 texture { pigment { color rgb < 0.24706,  0.38431,  0.058824 > *1.0 }
 finish { ambient 0.0 diffuse 0.0 } }
 rotate< 0, 0, 0 >
//------------------------------------------------ end of squared plane XZ
//---------------------------- objects in scene ----------------------------
cylinder
 < 0.0, -0.5, 0.0 > < 0.0, 1.0, 0.0 > 10.0
 pigment{ rgbt < 0.20784,  0.19216,  0.25098, 1.0 > }
 hollow
 interior
  media
   emission < 0.9, 0.9, 1.0 > *0.15
   absorption < 0.0, 0.0, 0.5 >
   scattering
    3, < 1.0, 1.0, 1.0 >
    extinction  2.0
   density
    gradient < 1.0, 0.25, 0.5 >  // controls the cloud formation
    turbulence 0.5
    frequency 5
    color_map
     [ 0.0 rgb 0.0 ]//border
     [ 0.5 rgb 0.1 ]
     [ 1.0 rgb 1.0 ]//center
    } // end color_map
   } // end of density
  } // end of media ----
 } // end of interior
 translate < 0.0, 1.0, 0.0 >
 scale < 5.0, 1.5, 5.0 >
fog
 fog_type   2
 distance   3
 color rgb < 0.20784,  0.192160,  0.2509800 > *0.8 // Purple
 color rgb < 0.7451,  0.50196,  0.42745 > *0.8 // Pink
 fog_offset 0.1
 fog_alt    1.25
 turbulence 1.8
fog
 fog_type   1
 distance   7.0
 color rgb < 0.43529,  0.39216,  0.52549 > *0.8 // Pink
 fog_offset 6.0
 fog_alt    8.0
cylinder
 < 0.0, 0.0, 0.0 > < 0.0, 8.0, 0.0 > 0.25
 texture { T01 }
 texture { T_Copper_1A }
sphere
 texture { T01 }
// Planet
sphere
 < 80.0, -2.0, 13.0 > 7.0
 texture { T01 }
difference
 cylinder { < 0.0, -0.00001, 0.0 > < 0.0, 0.00001, 0.0 > 13.0 }
 cylinder { < 0.0, -0.00002, 0.0 > < 0.0, 0.00002, 0.0 > 10.0 }
 texture { T01 }
 finish { ambient 0.85 }
 rotate < 20.0, 0.0, 4.0 >
 translate < 80.0, -2.0, 13.0 >
http://www.avg.com
Download 'sl - cloud cities.jpg' (187 KB) Download 'sl - cloud cities 2.jpg' (84 KB) Download 'cloud city.jpg' (50 KB)
Preview of image 'sl - cloud cities.jpg'
Preview of image 'sl - cloud cities 2.jpg'
Preview of image 'cloud city.jpg'
Date: 25 Nov 2017 16:19:57
Message: <5a19de7d$1@news.povray.org>
Yes, it is really very beautiful. Now image a small amount of
translucency...
http://www.avg.com
Date: 25 Nov 2017 16:20:42
Message: <5a19deaa$1@news.povray.org>
Yes, it is really very beautiful. Now imagine a small amount of
translucency...
http://www.avg.com
