POV-Ray : Newsgroups : povray.binaries.images : Re: Cloud Surface Server Time
2 Jun 2024 04:45:12 EDT (-0400)
  Re: Cloud Surface (Message 11 to 20 of 109)
Subject: Re: Cloud Surface
Date: 24 Nov 2017 23:10:00
Message: <web.5a18ec459a2a53c1a6394f050@news.povray.org>
subsurface material cloud:
Download 'interior_3f_scene 7_5 1h26m21s.png' (157 KB)
Preview of image 'interior_3f_scene 7_5 1h26m21s.png'
Date: 24 Nov 2017 23:20:01
Message: <web.5a18ef029a2a53c1a6394f050@news.povray.org>
diffuse version:
Download 'interior_3f_scene.png' (115 KB)
Preview of image 'interior_3f_scene.png'
Date: 25 Nov 2017 00:05:00
Message: <web.5a18f9519a2a53c1a6394f050@news.povray.org>
this one translucency rgb 6.0
Download 'interior_3f_scene 7_5 sss6 20m42s.png' (140 KB)
Preview of image 'interior_3f_scene 7_5 sss6 20m42s.png'
Date: 25 Nov 2017 02:05:01
Message: <web.5a1915f89a2a53c1a6394f050@news.povray.org>
I ever wrote a program that renders atmosphere and cloud. This image is what I
said in the following message:
http://news.povray.org/povray.general/message/%3Cweb.5a181ff99a2a53c1a6394f050%40news.povray.org%3E/#%3Cweb.5a181ff99a2
only single scattering is not enough to produce a physical based cloud. This
image is only single scattering:
Download 'color_image ??1 level1 res12.png' (450 KB)
Preview of image 'color_image ??1 level1 res12.png'
Date: 25 Nov 2017 02:15:01
Message: <web.5a1917549a2a53c1a6394f050@news.povray.org>
a2
It cannot show, upload again.
Download 'color_image test1 level1 res12.png' (450 KB)
Preview of image 'color_image test1 level1 res12.png'
Date: 25 Nov 2017 02:40:01
Message: <web.5a191dbf9a2a53c1a6394f050@news.povray.org>
99
> a2
Compare to 1 level scattering, this one a multiple scattering version
It calculate 1~16 level scattering
light transport in a cloud usually scatter - scatter -scatter ... over one
hundred times, I have taken a trick called reduced scattering coefficient, or 16
level scattering will not enough to produce this result.
Download 'color_image test1 level16 res24.png' (533 KB)
Preview of image 'color_image test1 level16 res24.png'
Date: 25 Nov 2017 03:32:36
Message: <5a192aa4$1@news.povray.org>
On 25-11-2017 0:51, clipka wrote:
> Am 25.11.2017 um 00:36 schrieb Sven Littkowski:
>> I am quite happy with the shape of the clouds, but there are some things
>> where I don't know how to change:
>> - that the tower disappears slowly below cloud surface (now it is white)
> Make sure to use scattering media with an extinction value of 1.0.
> Also, do use the newest version of POV-Ray, and do use the default media
> sampling method (2 I think). Media has seen several fixes of the
> underlying math, some of which could not be applied to the older
> sampling methods.
On the contrary and not to confuse the issue: use the version 3.7
defaults which are method 3 intervals 1. Samples can be adapted as
needed without serious render time loss.
Date: 25 Nov 2017 06:35:57
Message: <5a19559d$1@news.povray.org>
Am 25.11.2017 um 09:32 schrieb Thomas de Groot:
Thanks for correcting me on the default settings.
Those defaults are still valid for the newer versions with all the fancy
media fixes (late v3.7.1 development versions and v3.8).
Date: 25 Nov 2017 06:40:32
Message: <5a1956b0$1@news.povray.org>
Am 25.11.2017 um 05:06 schrieb And:
Hm... I didn't think of using an isosurface to give shape to the cloud.
Might actually work.
Make sure to use an ior of 1.0. That's more realistic, and might reduce
those bright blue band artifacts.
Date: 25 Nov 2017 07:55:01
Message: <web.5a1967d89a2a53c1a6394f050@news.povray.org>
Um, I didn't add ior, should 1.0 be a default?
