POV-Ray : Newsgroups : povray.binaries.images : How to avoid concentric rings with spot light on flat surface Server Time
28 Sep 2024 17:55:57 EDT (-0400)
  How to avoid concentric rings with spot light on flat surface (Message 11 to 14 of 14)
Subject: Re: How to avoid concentric rings with spot light on flat surface
Date: 7 Nov 2017 16:40:02
Message: <web.5a02282a3541f8acf6c3a3ce0@news.povray.org>
> As for not giving an advantage with JPEG, that's intentional: Dithering
> is high-frequency low-amplitude noise, which is exactly the type of
> signal JPEG compression tends to throw away. With POV-Ray's standard
> JPEG quality settings you wouldn't see a difference between an image
> that had dithering applied and an image that didn't. You'd need
> top-quality settings, at which image size probably wouldn't differ much
> from a PNG. Therefore, JPEG output currently doesn't support dithering
> at all (though I might change that).
Thanks for reminding me of this :) Another way of explaining this (which I'd
prefer) is that JPEG basically uses a Fourier transform, cuts at a specified
frequency (depending on the quality setting) and transforms back. Dithering
noise is of course high-frequency, causing it to be cut off. This is moreover
done separately for gray-scale and color information, as a stronger color
compression is usually not noticed by the human eye :) The latter fact causes
the chromatic noise.
I think implementing the dithering for JPEG would be labor lost. Having a
"guide" on how to achieve a good dithering using PNG output, and maybe info on
what the user needs to consider with MPEG to not restore the artifacts might be
much more useful.
> Please elaborate why you say the Bayer dithering "increases" the
> problem. In my own experiments I do still see concentric artifacts (*),
> but IMO they're less obvious than without dithering.
Somehow I couldn't reproduce this today, so please cancel what I said. I think
it was because I still had JPEG output enabled plus some pseudo-artifacts which
were only in my head ;)
>> Moreover, it ruins text rendering :(
>Dithering or mp4?
>How so?
I was using a quite high setting of antialiasing to get a sharp text (for title,
subtitles and such). It is created directly in POV-Ray. But with the dithering
there is of course a noticable noise at the edges of the latters, which is
moreover not constant from frame to frame. In consequence I think dithering can
generally not be used when rendering the text directly in POV-Ray. Am I wrong?
Date: 7 Nov 2017 19:29:43
Message: <5a024ff7$1@news.povray.org>
Am 07.11.2017 um 22:39 schrieb cbpypov:
Actually POV-Ray chooses to not use chroma subsampling in JPEG output.
Not really. When I implemented dithering support, I concocted a nice
little framework for it; enabling it for JPEG output would essentially
be a one-liner.
> Having a
> much more useful.
I guess the key to achieving well-dithered PNGs is to just enable
default dithering (`+th`). Ive might have a thing or two to add though.
As for MPEG, I have far too little experience to give any advice on it
at all; but I wouldn't be surprised if colour banding artifacts were
virtually inevitable there.
>> Dithering or mp4?
>> How so?
Are you sure you weren't seeing JPEG/MPEG artifacts?
POV-Ray's dithering noise is at a magnitude of 0.4% in output colour
space (presuming 8 bit per colour channel). /Especially/ in the vicinity
of high contrast edges this noise should be imperceptible by human vision.
Date: 8 Nov 2017 17:45:01
Message: <web.5a0387cc3541f8acf1ae67d70@news.povray.org>
Interesting! Why that?
> be a one-liner.
That reason is good enough ;)
Two things ... First, by accident I found out what I had experienced with the
Bayer dithering. (And it turned out it was _not_ in my head, but _real_.) See
the three images in the attachment, rendered without dithering and with the +th
and +thB4 methods. I am using the Gnome viewer (3.18.2), and if I have the
images full-screen (on a Fulll-HD display; but the images are only 1280x720!),
the dithered images look identical, while the undithered one looks worse.
However, if I change the window size of the viewer, causing the images to be
scaled internally (by whatever method), something interesting happens: the
undithered and the +th images do not change at all, while for the Bayer
dithering the concentric rings increase drastically at specific window sizes, --
even beyond the undithered images! It seems to be a characteristic of this
dithering when scaled. And the same has obviously happend when I played back an
MPEG rendered using the +thB4-images.
Second, I am quite sure that the artifacts on the text are from the dithering
(by POV-Ray)! I don't know your eye, but with my eyes I can see even the
slightest deviations at completely vertical/horizontal edges, as they occur with
text. I'd even say: if the dithering causes any real fluctuation at (straight)
text edges, it _will_ be noticable. Books are printed at 1200 DPI or even higher
for the same reasons. I cannot attach the video right now for because of the
size. If I have the time I'll post one, but you can believe me that the effect
is very real :) (It is absent if I render without dithering, ruling out the MPEG
artifacts).
Download 'movie_midq.zip' (1024 KB)
Date: 8 Nov 2017 18:59:37
Message: <5a039a69$1@news.povray.org>
Am 08.11.2017 um 23:40 schrieb cbpypov:
To allow for the highest quality possible. Note that even if you set
quality to 100%, chroma subsampling would cause loss of information.
That's indeed an unsurprising characteristic of pattern-based dithering
(such as Bayer dithering), and is related to the Moiree effect. (Plus,
even if the resiting application is smart enough to avoid Moiree-like
effects, it may also be dumb enough to simply re-introduce colour banding.)
It /can/ also happen with diffusion-based dithering (such as
Floyd-Steinberg), though it is less likely. For an algorithm to be
really safe from such issues it has to be based on random noise.
