POV-Ray : Newsgroups : povray.binaries.images : problem with beta-five Server Time
18 Nov 2025 22:07:53 EST (-0500)
  problem with beta-five (Message 1 to 9 of 9)
Subject: problem with beta-five
Date: 27 Mar 2017 11:00:00
Message: <web.58d927359666063919380bcb0@news.povray.org>
consider the following;
#version 3.7; //
camera
{   perspective
    location  -30*z //
    look_at z //
    right x* image_width/ image_height //
    angle 55 //
light_source { <100, 100, -100> rgb <1, 1, 1> } //
#declare leength= 20; //
#declare weedth= 20; //
#declare bagel=box
{   <-leength/2, -weedth/2, -.005*leength>,
     <leength/2, weedth/2, .005*leength>
    pigment{ // -----------------------------------------------
        pavement number_of_sides 3 number_of_tiles 4 pattern 3
         exterior 0 interior 0  form 0
        color_map{
            [ 0.00 color rgb<0.55, 0.25, 0.25> ]
            [ 0.60 color rgb<0.25, 0.25, 0.25> ]
            [ 0.90 color rgb<0.00, 0.00, 0.00> ]
            [ 1.00 color rgb 1 ]
        scale 01.425 //
        rotate x*90 //
object{ bagel } //
Download 'bagels.jpg' (174 KB)
Preview of image 'bagels.jpg'
Subject: Re: problem with beta-five
Date: 27 Mar 2017 12:00:16
Message: <58d93710$1@news.povray.org>
Am 27.03.2017 um 16:52 schrieb green:
Tracking this on GitHub as issue #260 ("Pavement pattern broken")
Date: 27 Mar 2017 14:50:45
Message: <58d95f05$1@news.povray.org>
Am 27.03.2017 um 18:00 schrieb clipka:
Will be fixed in next beta.
Date: 27 Mar 2017 18:50:00
Message: <web.58d99606373a0c61883fb31c0@news.povray.org>
> #version 3.7; //
 [snip]
This is off-topic, but I thought that to run a 3.7.1 alpha or beta version
correctly (i.e., so that it does not invoke its 'backwards compatibility' with a
previous version's features), the  #version statement should be   #version 3.71
 and not just 3.7   Am I right or wrong about that? I always assumed it to be
so.
(By the way, the incorrect tiling pattern shows up either way.)
Date: 28 Mar 2017 09:35:04
Message: <58da6688@news.povray.org>
Am 28.03.2017 um 00:45 schrieb Kenneth:
>> #version 3.7; //
>  [snip]
> so.
You are perfectly right in that `#version 3.7` (which is shorthand for
`#version 3.70`, which in turn is interpreted as "this scene was
designed for version 3.7.0") will cause some 3.7.1-specific behaviour to
be disabled in order to maintain compatibility with the behaviour of 3.7.0.
However, most added features work perfectly fine even when the scene
says `#version 3.70`. (Which I concede isn't ideal, because it makes it
possible for people to write scenes that use 3.7.1 features but claim to
be "designed for version 3.7.0", leading to confusion if someone ever
tries to actually render such a scene with 3.7.0.)
Date: 28 Mar 2017 23:08:40
Message: <58db2538$1@news.povray.org>
>>> #version 3.7; //
>>  [snip]
>> so.
The lack of a second dot in `#version 3.70` is kind of confusing.
Mike
Date: 28 Mar 2017 23:16:32
Message: <58db2710$1@news.povray.org>
> Mike
Whoever decided to use a float to store the version number had the wrong
idea, IMO.
Mike
Date: 29 Mar 2017 01:14:17
Message: <58db42a9$1@news.povray.org>
> idea, IMO.
    That works very well for TeX.
Date: 29 Mar 2017 12:39:23
Message: <58dbe33b$1@news.povray.org>
Am 29.03.2017 um 05:17 schrieb Mike Horvath:
> idea, IMO.
I hear you.
It does have its benefits though: It allows for constructs like
    #declare temp_version = version;
    #version 3.5;
    #version temp_version;
or
    #if (version >= 3.71)
without having to add special language constructs to the parser for
assigning and comparing version numbers.
