Am 23.09.2015 um 09:17 schrieb Thomas de Groot:
> On 18-9-2015 17:07, clipka wrote:
>> Unless using an area_light with area_illumination on, fade_distance
>> should typically be roughly equal to the hypothetical radius of whatever
>> light source you are trying to simulate. So for instance, to simulate a
>> classic frosted E27 incandescent light bulb, and presuming you're using
>> a scale of 1m per POV-Ray unit for your scene, a fade_distance of 0.03
>> would be about the right value.
> Could you elaborate a bit on (the use of) /area_illumination/ please? I
> have tried to look up info in the docs but there is nothing
> comprehensive there (or is there?). Thanks!
Normally, using an area_light only affects brightness attenuation due to
occlusion - in other words, soft shadows. For all other purposes - most
notably the angle of incidence to compute highlights and diffuse
brightness (but also the distance to compute distance-based falloff) -
the light source still behaves like a spotlight.
Consider you want to simulate a fluorescent light tube mounted close to
a wall. If you do this with an array of, say, 1000 tiny point light
sources, the illumination of the wall will be computed correctly, giving
you a long patch of diffuse light and (if the wall is somewhat shiny) a
distinctively line-shaped highlight.
If you try the same feat with a 1x1000 area_light, even if you don't use
the "adaptive" keyword you'll find that both the patch of diffuse light
as well as the highlight will /not/ have the expected linear shape, and
instead look like you had only one bright point light source at the center.
Using "area_illumination" forces POV-Ray to do the diffuse and
highlights computations for each "lightlet" separately, to give you the
proper illumination effect.
(I don't know off the top of my head whether area_illumination also
affects distance-based falloff; I guess so, but I'm not sure.)
Excellent! Thanks indeed.
