![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
here is minimal code for the famous burning ship fractal.
It renders fine as long as I don't include functions.inc (in another context I
need functions.inc).
Does anybody know the reason?
// using code from Tor Olav Kristensen / Slime Difference Small objects and
Glass Cube
http://news.povray.org/povray.general/message/%3C41493956%241%40news.povray.org%3E/#%3C41493956%241%40news.povray.org%3
E
// formula from Paul Nylander Fractals
http://bugman123.com/Fractals/index.html
#version 3.7;
global_settings {
assumed_gamma 2.2
//#include "functions.inc" // uncommenting this line will cause a crash
// (3.7.0.msvc10.win64 / 3.6.2.msvc9.win64)
location <0,0,-1>
look_at <0,0,0>
up y
sky -y
direction z*1.5
#declare IterFn =
function (N, Re, Im, Zr, Zi) {
select (
N > 300 | Zr*Zr+Zi*Zi > 4,
0,
IterFn (N+1, Re, Im, Zr*Zr-Zi*Zi+Re, 2*abs (Zr*Zi)+Im),
N/300
#declare BurningShip = function (Re, Im) {IterFn (0, Re, Im, Re, Im)}
plane {
-z, -2.5
function {BurningShip (x,y)}
color_map {
[0 rgb -1]
[0.01 rgb 1]
[1 rgb -1]
finish {ambient 1}
translate <1.745,0.0375,0>
scale 27
Norbert Kern
Download 'burning_ship_fn.jpg' (319 KB)
Preview of image 'burning_ship_fn.jpg'
![burning_ship_fn.jpg](/povray.binaries.images/attachment/%3Cweb.55e58a984a2649cbe2e8c9770%40news.povray.org%3E/burning_ship_fn.jpg?ttop=443824&toff=1200&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 01/09/2015 12:25, Norbert Kern wrote:
> Hi,
It seems it's nothing special about functions.inc, declaring *any*
function before your IterFn causes the crash.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
More specifically, a hard crash (a segmentation fault on my system).
POV-Ray version: 3.7.0.unofficial (g++ 4.8 @ x86_64-unknown-linux-gnu)
Operating system: openSUSE 13.2 (GNU/Linux)
CPU: Intel Core i7
I also confirm Scott's observation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> declaring *any* function before your IterFn causes the crash.
Thanks very much
Norbert
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 2015-09-01 07:25 AM (-4), Norbert Kern wrote:
> #declare IterFn =
> select (
> 0,
> N/300
Reducing the recursion level does not prevent the crash. I tried all
the way down to 1.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > #declare IterFn =
> > select (
> > 0,
> > N/300
> the way down to 1.
The reason for this, I believe, is that pic doesn't support recursive functions.
You can get away with exactly one, if -and only if- it is defined before
anything else in the file.
A.D.B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > > #declare IterFn =
> > > select (
> > > 0,
> > > N/300
> > the way down to 1.
pov* -- stupid ipod.
anyway... it causes your system to crash, or just causes povray to crash?
A.D.B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Regards,
> A.D.B.
Hi Anthony,
only povray. I condensed the problem in perhaps 100 steps by deleting nearly
everything including tests with 3.6 and on a second pc.
There were similar problems with other (typically recursive) functions in the
past, but here I was getting angry, because I like this special fractal very
much.
Norbert
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Thanks very much
You can get around the problem by unrolling the iteration into 300
different functions in an array:
#declare MAX_ITERATIONS = 300;
#declare Fns = array[MAX_ITERATIONS];
#declare Fns[MAX_ITERATIONS-1] = function (N, Re, Im, Zr, Zi) { 0 }
#local ITERATION = MAX_ITERATIONS-2;
#while(ITERATION>=0)
#declare Fns[ITERATION] =
select (
Zr*Zr+Zi*Zi > 4,
0,
Fns[ITERATION+1] (N+1, Re, Im, Zr*Zr-Zi*Zi+Re, 2*abs
(Zr*Zi)+Im),
ITERATION/300
#local ITERATION=ITERATION-1;
#declare BurningShip = function (Re, Im) {Fns[0] (0, Re, Im, Re, Im)}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> select (
> Zr*Zr+Zi*Zi > 4,
> 0,
> (Zr*Zi)+Im),
> ITERATION/300
> #end
wow, it works!
Thank you very much.
Norbert
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
