![](/i/fill.gif) |
Stephen <mca### [at] aol com> wrote:
> On 8/23/2015 5:39 AM, clipka wrote:
> >> You might want to try min_extent and max_extent to define the
> >> >contained_by box (can also be a sphere)
> > Unfortunately that won't help with this issue, as min_extent and
> > max_extent give you the extent of the object's bounding box (rather than
> > the object itself), which in case of parametrics is in turn simply based
> > on the contained_by object.
> Interesting
> > One possible solution would be to evaluate some sample points from the
> > function set (possibly using an adaptive algorithm), and create the
> > contained_by box based on the range of the results (with some additional
> > margin).
> This makes me think that Nekar's idea of creating a mesh is a starting
> point.
> If LanuHum could create and export a mesh of the object (declared but
> not called). PovRay could evaluate its bounding box and use those values
> as the parametrics contained by.
> Regards
> Stephen
This object was created by the Blender tool. If to use meshmaker, it is
necessary to specify the amount of bound boxing
![](/i/fill.gif) |
![](/i/fill.gif) |
> I wrote nonsense. :)
Brother! :)
> Consider it a joke! :)
Done ;)
Regards
![](/i/fill.gif) |
