POV-Ray : Newsgroups : povray.binaries.images : polygon to circle loft Server Time
18 Mar 2026 07:18:56 EDT (-0400)
  polygon to circle loft (Message 41 to 50 of 51)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: polygon to circle loft
Date: 14 May 2015 15:36:36
Message: <5554f944$1@news.povray.org>
On 05/14/2015 03:04 PM, Doctor John wrote:
> On 14/05/15 17:18, And wrote:
>> I have a question.
>> Can I upload more than one picture here?
> Yes. Proof attached
> John
I like that second one. The first, well, I'll opt not to comment...
And, I use Thunderbird as my interface to the povray news groups. With
Thunderbird or similar you can indeed upload more than one image as John
showed.
While I am too lazy to verify it at the moment, I seem to recall the web
interface to the news groups permits only one image per post. If true,
and you are using the web interface, perhaps this is why you cannot
attach more then one image.
Bill P.
Date: 14 May 2015 15:57:11
Message: <5554fe17$1@news.povray.org>
Am 14.05.2015 um 21:36 schrieb William F Pokorny:
>>> I have a question.
>> Yes. Proof attached
>> John
The first one is a well-known major work of an equally well-known
aspiring young artist who deserves utmost respect from all POVers. See
povray.off-topic for details.
Date: 14 May 2015 20:49:23
Message: <55554293$1@news.povray.org>
> I have a question.
 From any e-mail client: Yes
 From the web interface: No
Date: 14 May 2015 20:50:02
Message: <555542ba$1@news.povray.org>
>>>> I have a question.
>>> Yes. Proof attached
>>> John
Ah thanks, Christoph, for the pointer. I agree and my apologies. Proof I
am not tuned into current artistic trends.
Date: 15 May 2015 01:40:01
Message: <web.5555862b908ae4213f4ed4340@news.povray.org>
> >> I have a question.
> > Yes. Proof attached
> > John
> showed.
> Bill P.
> > I have a question.
No wonder I cannot attach more then one image.
Date: 15 May 2015 01:45:00
Message: <web.55558769908ae4213f4ed4340@news.povray.org>
"LanuHum" <Lan### [at] yandexru> wrote:
> "And" <49341109@ntnu.edu.tw> wrote:
> > Could you give me an example (code)?
> > I never saw it.
> #version 3.7;
> global_settings {
> background {rgbt<0.05, 0.05, 0.05, 0>}
> #declare Default_texture = pigment {rgb 0.8}
> #declare Material = texture {pigment {rgbt <0.8,0.8,0.8,0>}}
> #declare height = 0.5;
> #declare poly_n = 3;
> #declare poly_r = 0.5;
> #declare cycle_r = 0.13;
> #declare an = 2*pi/poly_n;
> #declare poly_thr = poly_r*cos(an/2);
> #declare bound=max(cycle_r,poly_r);
> #declare multi = 10;
> #declare poly_obj =
> polynomial{
> 4,
> xyz(0,2,2):multi*1,
> xyz(2,0,1):multi*2*height,
> xyz(1,0,2):multi*2*(poly_thr-cycle_r),
> xyz(2,0,0):multi*(-pow(height, 2)),
> xyz(0,0,2):multi*(-pow(cycle_r - poly_thr, 2)),
> xyz(1,0,1):multi*2*height*(-2*poly_thr + cycle_r),
> xyz(1,0,0):multi*2*pow(height,2)*poly_thr,
> xyz(0,0,1):multi*2*height*poly_thr*(poly_thr - cycle_r),
> xyz(0,0,0):multi*(-pow(poly_thr*height, 2))
> sturm
> #declare mockup2 =
> difference{
>     cylinder{
>     <0,0,0.0>,<0,0,height>, bound
>     #for(i, 0, poly_n-1)
>         object{
>         poly_obj
>         inverse
>         rotate <0,0,degrees(an*i)>
>         plane{
>         <1,0,0>,-poly_thr
>     #end
> texture {pigment {rgb 1}}
> scale 3
> rotate <0,90,90>
> mockup2
> light_source {
>     <4.08,5.9,5.1>
>     color rgb<1, 1, 1>
> camera {
>     location  <0, 0, 0>
>     look_at  <0, 0, -1>
>     right <-1.7777777777777777, 0, 0>
>     up <0, 1, 0>
>     angle  49.134343
>     rotate  <-27.098163, 46.688390, -0.903519>
>     translate <7.481132, 5.343666, 6.507640>
Oh, this section of code has some bugs, please use the file which I uploaded
later.
Date: 15 May 2015 02:15:01
Message: <web.55558e3e908ae4213f4ed4340@news.povray.org>
> > I have a question.
> Yes. Proof attached
> John
> Protect the Earth
> It was not given to you by your parents
> You hold it in trust for your children
Thanks.
Nice pictures.
Date: 15 May 2015 03:47:56
Message: <5555a4ac$1@news.povray.org>
>> I have a question.
> Yes. Proof attached
> John
Careful study undoubtedly shows that the second work is made by the same
artist as the first. Proof of that can be seen most clearly in the small
doodle under the arch of the house on the left, but also in the way the
top of the barrier posts are treated. While the first work has been
confidently dated to within the last few weeks, the second one poses a
bigger challenge. The subject for instance is unusual and has not been
found in any earlier work of this young artist who is best known for his
photo-realistic portraits. This is the first known cityscape theme in
his small but growing portfolio, although it has been established that
several works have been destroyed either accidentally, and sometimes
purposefully, by the artist himself or by his guardians. In that light,
the museum has started negotiations with the artist to at least preserve
as much as possible of his work for posterity.
Thomas, Deputy Head Curator of the POV Museum.
Date: 15 May 2015 06:02:57
Message: <5555c451$1@news.povray.org>
The Feegle says: No offence taken. I understand that new artistic
concepts can be challenging for all you oldies.
John (on behalf of the Feegle)
Protect the Earth
Date: 15 May 2015 12:20:00
Message: <web.55561c1e908ae4217a3e03fe0@news.povray.org>
> later.
Oh, sorry!
Thanks!
