It is fast. It only took 3s to render on my fx-8350 computer.
#declare height = 0.5;
#declare poly_n = 6;
#declare poly_r = 0.5;
#declare cycle_r = 0.13;
#declare an = 2*pi/poly_n;
#declare poly_thr = poly_r*cos(an/2);
#declare bound=max(cycle_r,poly_r);
#declare multi = 1000;
#declare poly_obj =
polynomial{
4,
xyz(0,2,2):multi*1,
xyz(2,0,1):multi*2*height,
xyz(1,0,2):multi*2*(poly_thr-cycle_r),
xyz(2,0,0):multi*(-pow(height, 2)),
xyz(0,0,2):multi*(-pow(cycle_r - poly_thr, 2)),
xyz(1,0,1):multi*2*height*(-2*poly_thr + cycle_r),
xyz(1,0,0):multi*2*pow(height,2)*poly_thr,
xyz(0,0,1):multi*2*height*poly_thr*(poly_thr - cycle_r),
xyz(0,0,0):multi*(-pow(poly_thr*height, 2))
sturm
#declare mockup2 =
difference{
cylinder{
<0,0,0.0>,<0,0,height>, bound
#for(i, 0, poly_n-1)
object{
poly_obj
inverse
rotate <0,0,degrees(an*i)>
plane{
<1,0,0>,-poly_thr
mockup2
On 05/08/2015 02:08 AM, And wrote:
> I was trying to make lofting shape. And here is the fruit.
Very good!
> Very good!
Thanks!
It is not low hanging fruit. :-)
If it is not a trade secret. How did you blend the hexagon into a circle?
Regards
> #declare poly_obj =
> polynomial{
> 4,
> xyz(0,2,2):multi*1,
> sturm
> #declare mockup2 =
> difference{
> cylinder{
> object{
> poly_obj
> inverse
> plane{
> <1,0,0>,-poly_thr
> #end
> mockup2
Wonderful toy!
It is possible to play year. :)
Substituting different figures, we receive different forms.
Download 'scene.jpg' (7 KB)
Preview of image 'scene.jpg'
> Regards
> Stephen
Thanks for your compliment!
Well, it is not a trade secret. And the idea is simple.
I represent it by isosurface then it will be clear:
#declare r = 0.3;
#declare h = 0.3;
#declare f_1 =
function(x,y){
max(x-0.1, y-0.1, -(x+0.1), -(y+0.1) )
#declare f_2 =
function(x,y){
sqrt(x*x+y*y) - r
#declare f_blend =
function(x,y,z){
(z/h)*f_1(x,y) + (1-z/h)*f_2(x,y)
isosurface {
function {f_blend(x,y,z)}
contained_by { box { <-0.5, -0.5, 0>, <0.5, 0.5, h> } }
accuracy 0.001
max_gradient 40
pigment{ color rgb<1,1.0,0.95>*1.1}
finish { phong 1}
Then it will blend it from f_1(x,y) to f_2(x,y)
from z=h to z=0
> > Regards
> > Stephen
> #declare r = 0.3;
> #declare h = 0.3;
> #declare f_1 =
> function(x,y){
> #declare f_2 =
> function(x,y){
> sqrt(x*x+y*y) - r
> #declare f_blend =
> function(x,y,z){
> isosurface {
> accuracy 0.001
> max_gradient 40
> texture {
> finish { phong 1}
Whether it is possible to make the universal scheme of transition from a curve
to the n-gons?
"LanuHum" <Lan### [at] yandexru> wrote:
> Wonderful toy!
Thank you. Your word made me happy all day long.
Sorry!
Example for my early post
Download 'polynom.jpg' (39 KB)
Preview of image 'polynom.jpg'
