POV-Ray : Newsgroups : povray.binaries.images : CGSphere WIP: stacked convex lenses Server Time
20 Apr 2026 13:00:35 EDT (-0400)
  CGSphere WIP: stacked convex lenses (Message 18 to 27 of 27)
Subject: Re: CGSphere WIP: stacked convex lenses
Date: 14 Nov 2014 21:48:03
Message: <5466bee3$1@news.povray.org>
Am 14.11.2014 19:03, schrieb Le_Forgeron:
> Actually, for some option there is a difference between + and -
> (usually one form disable the option, and the other enable it, with some
> value).
> For instance +KC and -KC are opposite of each other.
> But +H and -H are happily setting both the height of the output.
> Now, if I could find a mnemonic to remember which one is enable and
> which one is disable... that would be a great year.
Uh... how about "+" adds something (turns it on), while "-" removes
something (turns it off)?
Not too difficult, is it ;-)
Date: 15 Nov 2014 03:20:09
Message: <54670cb9$1@news.povray.org>
>> value).
LOL. I must say that where on/off is concerned, I do not have much
problem with +/-. It is those cases where there is no such thing and
where you can either use + or - for the same result that I begin to feel
itchy. It confuses the issue and as one does not always remember which
of those bloody settings can or cannot be switched... ;-)
Date: 15 Nov 2014 13:10:00
Message: <web.5467967254566a48192ae5f10@news.povray.org>
I just make a habit of using + unless I want to turn something off.  That way
the question never comes up.
Date: 15 Nov 2014 19:07:17
Message: <5467eab5@news.povray.org>
Le 14-11-14 10:41, Raiford, Michael a écrit :
> On 11/14/2014 5:59 AM, Le_Forgeron wrote:
>> Le 14/11/2014 00:36, Cousin Ricky a écrit :
>>> Le_Forgeron <jgr### [at] freefr> wrote:
>>>> On 13/11/2014 21:21, Cousin Ricky wrote:
>>>>> My hardware is a Dell Inspiron 17R with Intel Core i7 (8 cores).
>>>> Isn't that 4 cores with HT ? (for povray, it would be worth 5 cores,
>>>> YMMV)
>>> I've seen "quad core" in literature not attached to this particular
>>> model, but
>>> in the POV-Ray statistics, there is a clear 8-to-1 ratio between CPU
>>> times and
>>> elapsed times.  Does this mean that there are 2 CPUs in each core?
>> Sort of... there is two full set of registers in each core, allowing to
>> run two code in parallel... as long as they do not need the same
>> resources from the core.
>> at 100% cpu like povray, yes there is a 8:1 ratio between cpu times and
>> wall-clock time. Yet, if the scheduler of the operating system is not
>> too bad, if you force povray to run on less threads (with -WT<number>
>> option), you can get some surprise like -WT8 is not twice faster that
>> -WT4.
>> With good schedulers, povray -WT4 would run one thread per core, leaving
>> the other set of registers idle or used by something else.
> Yep. Pretty much that. I've noticed that my work computer (core i3, dual
> core) isn't quite as fast as my desktop PC (a Core2 Quad), even though
> it appears to have 4 cores to applications.
> I forget exactly what hyperthreading does, but it does give a bit of a
> boost to multi-threaded applications.
hyperthreading implement virtual core(s) on a CPU by having two sets of
registers. You have 1 true core that looks like there are 2. It makes it
faster to switch between threads.
Date: 16 Nov 2014 03:17:13
Message: <54685d89$1@news.povray.org>
Me too in fact. I have noted that explanations given here however, often
use -. I guess it is laziness: no need to use the SHIFT key while typing :-D
Date: 16 Nov 2014 10:25:01
Message: <web.5468c16b54566a48192ae5f10@news.povray.org>
That's what the numeric keypad is for. :-)
Date: 16 Nov 2014 10:38:52
Message: <5468c50c$1@news.povray.org>
[bangs head against table top]
Date: 16 Nov 2014 17:25:00
Message: <web.546923c054566a48d19b0ec40@news.povray.org>
That requires moving my right hand all the way over to the keypad. No
self-respecting lazy person would do this.
Date: 18 Nov 2014 13:54:44
Message: <546b95f4$1@news.povray.org>
Type with one hand while keeping the other on the mouse. Then, it's just
a mather of hiting that big, double height, key with the thumb.
Date: 19 Nov 2014 14:30:00
Message: <web.546ceeb254566a48192ae5f10@news.povray.org>
> I must add that this was inspired by Richard Roseman's "Glass Panels":
Correction:  That should be "Rosenman."
