POV-Ray : Newsgroups : povray.binaries.images : Sea and garbage Server Time
21 Apr 2026 09:21:00 EDT (-0400)
  Sea and garbage (Message 21 to 30 of 31)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Sea and garbage
Date: 9 Sep 2014 16:05:52
Message: <540f5da0@news.povray.org>
> Hi Lionel,
> I take this as an improvement to your first approach. The can looks much better
> than the paper vessel in the first Scene. Modelling dirty water is a very hard
> job with POV and I think, that you are a little bit too dark at the moment. IMO
> you should find something between your first and your actual image for the water
> material. And the reflections on the green topped bottle are a bit too even. To
> much rectangeles there. Otherwise a very promising WIP.
> Best regards,
> Michael
Thank you Michael,
I leave the paper boat since I have not made a good model.
I know that some objects need more work, they are too clean.
About the water, it is hard to find the right colors.
But with time I think I can find the good hue.
Lionel
Do not judge my words, judge my actions.
http://www.avast.com
Date: 9 Sep 2014 16:08:02
Message: <540f5e22$1@news.povray.org>
> "Eeeks! Mom, I don't want to go swimming in that water - there's an ugly
> frog in there."
> I wonder how that poor animal managed to survive there. AFAIK frogs
> require quite an intact ecosystem. Then again, with those eyes it's
> probably a radioactive mutant anyway...
You're right! Everything is dead except the frog! Maybe the frog is
lost, how many times will she survive?
Lionel.
Date: 10 Sep 2014 03:43:22
Message: <5410011a$1@news.povray.org>
> frog in there."
"Come on Johnny! Mummy did swim in much worse than that! /This/ has been
cleaned. No germs at all and the frog is only mildly poisonous."
Date: 10 Sep 2014 03:46:18
Message: <541001ca$1@news.povray.org>
This is much, much better indeed. Beware the bottle in back which needs
some more modelling.
Somehow I find the fish scales not entirely convincing. Maybe reduce the
bump_size a bit (if it is a bump_map).
Date: 10 Sep 2014 12:33:57
Message: <54107d75$1@news.povray.org>
Thanks Thomas, these scene need some works again, and the bottle is one
of them.
  The texture of the fish is only povrayed, no image, but you are right,
the texture is not really good, also some works.
And work by work I can do something.
Lionel
Date: 11 Sep 2014 11:55:01
Message: <web.5411c565d4902d5285de7b680@news.povray.org>
The bottle at the upper left could be fixed by using smooth triangles.
Is it a crackle pattern?  Fish scales are regular.  A quilt pattern would
probably be far more convincing.
Date: 11 Sep 2014 14:25:00
Message: <web.5411e80ad4902d52d19b0ec40@news.povray.org>
FractRacer <lg.### [at] gmailcom> wrote:
> The second WIP, more than 20 hours of rendering.  Some work on the
> scene, I have miss the eyes of the frog...
> Lionel
 active.
This one is a lot better. There's something about the lighting that is a bit off
though.
Date: 11 Sep 2014 15:46:45
Message: <5411fc25$1@news.povray.org>
The model of the bottle, made with Wings3d, was not smooth, I have
arranged this today.
You are right, it is a crackle pattern, I like it since it seem like
some prehistorics scales. But I will go to try the quilt pattern. Thanks.
Lionel
Date: 11 Sep 2014 15:52:27
Message: <5411fd7b$1@news.povray.org>
> though.
Thank you, I use CIE_Skylight.inc for the light and I am not regular
with it. I made some tries... Maybe use a second light.
Who live will see.
Lionel
Date: 11 Sep 2014 15:59:41
Message: <5411ff2d$1@news.povray.org>
>> a bit off
>> though.
> Who live will see.
> Lionel
Outside scene, the only light should be the sun.
Use an area_light with an width about 1% of the distance. Start with
adaptive 0. Increase only if you need to.
Some radiosity may help. Recursion_level 1 should be OK.
