POV-Ray : Newsgroups : povray.binaries.images : Circumscribed sphere Server Time
29 Mar 2026 08:37:12 EDT (-0400)
  Circumscribed sphere (Message 11 to 12 of 12)
Subject: Re: Circumscribed sphere
Date: 8 Aug 2014 18:45:00
Message: <web.53e552383cb258895e7df57c0@news.povray.org>
OK,  Here's the rough draft.
I use a normal line for my trace function - a haven't implemented the plane yet
- I need to figure out a check for coincidence with the trace line.
It also doesn't calculate / plot the correct normal for triangle A-B-D, which is
weird (and p------ me off) because it uses the same F. Lohmueller macro as all
the other faces of the tetrahedron.   What.  The.  Heck.
#declare Corner_A_1 = <0, 4, -2>;
#declare Corner_A_2 = <4, 4, -2>;
#declare Corner_A_3 = <2, 8, -2>;
#declare H = 0.5;
//  Circumscribe a sphere around a triangle and a 4th "tetrahedral point"
determined by Height
 #macro Circumscribed_Sphere (Corner_1, Corner_2, Corner_3, Height)
  #local MacroName = "Circumscribed_Sphere"
  #if (verbose = true)
   #debug concat("macro '", MacroName, "' called with arguments: ")
   #debug concat("<", vstr(3, Corner_1, ", ", 0, 1), ">, <", vstr(3, Corner_2,
", ", 0, 1), ">, <", vstr(3, Corner_3, ", ", 0, 1), ">, ", str(Height, 3, 3), "
\n")
  #end // end verbose debugging output
  #local Markers = true; //  Display points and geometric construction lines
  #local SolidBlue    = texture {pigment {color rgb <0, 0, 1> } finish {ambient
0.6}};
  #local SolidRed     = texture {pigment {color rgb <1, 0, 0> } finish {ambient
0.6}};
  #local SolidYellow  = texture {pigment {color rgb <1, 1, 0> } finish {ambient
0.6}};
  #local SolidGreen  = texture {pigment {color rgb <0, 1, 0> } finish {ambient
0.6}};
  #local SolidGray  = texture {pigment {color rgb <0.5, 0.5, 0.5> } finish
{ambient 0.6}};
  #local Point_radius = 0.125;
  #local Line_radius  = 0.125/4;
  union{
   // POINT P / Middle
   #local Middle =  Triangle_M_out (Corner_1, Corner_2, Corner_3);
   #local Radius =  Triangle_R_out (Corner_1, Corner_2, Corner_3);
   #local Normal =  Triangle_Normal(Corner_1, Corner_2, Corner_3);
   #declare CC_Radius = vlength (Middle - Corner_1);
   #local PointD  =  vtransform (Middle, transform {translate Normal*Height});
   //  Tetrahedral faces
   #local Middle12D =  Triangle_M_out (Corner_1, Corner_2, PointD);
   #local Radius12D =  Triangle_R_out (Corner_1, Corner_2, PointD);
   #local Normal12D =  Triangle_Normal(Corner_1, Corner_2, PointD);
   #local Middle23D =  Triangle_M_out (PointD, Corner_2, Corner_3);
   #local Radius23D =  Triangle_R_out (PointD, Corner_2, Corner_3);
   #local Normal23D =  Triangle_Normal(PointD, Corner_2, Corner_3);
   #local Normal23DVector = vtransform (Middle23D, transform {translate
-Normal23D*10});
   #local Middle31D =  Triangle_M_out (Corner_1, PointD, Corner_3);
   #local Radius31D =  Triangle_R_out (Corner_1, PointD, Corner_3);
   #local Normal31D =  Triangle_Normal(Corner_1, PointD, Corner_3);
   #local Centerline  = vtransform (Middle, transform {translate -Normal*10});
   #local Centertrace = object {cylinder {PointD, Centerline, 0.01} }
   #declare CS_Center = trace (Centertrace, Middle23D, -Normal23D );
   #declare CS_Radius = vlength (PointD - CS_Center);
   #if (Markers = true)
    sphere {Corner_A_1, Point_radius    texture {SolidBlue} }
    object {LabelPoint (Corner_1, "A", 0.5)   texture {SolidRed}  }
    sphere {Corner_A_2, Point_radius    texture {SolidBlue} }
    object {LabelPoint (Corner_2, "B", 0.5)   texture {SolidRed}  }
    sphere {Corner_A_3, Point_radius    texture {SolidBlue} }
    object {LabelPoint (Corner_3, "C", 0.5)   texture {SolidRed}  }
    // circumcenter of triangle ABC
    sphere {Middle, Point_radius     texture {SolidBlue} }
    object {LabelPoint (Middle, "m", 0.5)    texture {SolidBlue} }
    //  Circumcircle of original triangle
    torus {  CC_Radius, Line_radius rotate x*90 translate Middle texture
{SolidBlue} no_shadow}
    // new tetrahedral point
    sphere {PointD, Point_radius texture {SolidGray} }
    object {LabelPoint (PointD, "D", 0.5) texture {SolidGray} translate
Normal*Height}
    object {Centertrace texture {SolidGreen} } // extended normal of original
triangle
    object {PointMarker (Middle12D, Line_radius) texture {SolidGray} }
    torus  {Radius12D, Line_radius Reorient_Trans(y, Normal12D) translate
Middle12D texture {SolidGray} }
    object {Distance_Marker(Middle12D, vtransform (Middle12D, transform
{translate -Normal12D*CS_Radius}), Line_radius) texture {SolidGreen}}
    object {PointMarker (Middle23D, Line_radius) texture {SolidGray} }
    torus  {Radius23D, Line_radius Reorient_Trans(y, Normal23D) translate
Middle23D texture {SolidGray} }
    object {Distance_Marker(Middle23D, Normal23DVector, 0.025) texture
{SolidGreen}}
    object {PointMarker (Middle31D, Line_radius) texture {SolidGray} }
    torus  {Radius31D, Line_radius Reorient_Trans(y, Normal31D) translate
Middle31D texture {SolidGray} }
    object {Distance_Marker(Middle31D, vtransform (Middle31D, transform
{translate -Normal31D*CS_Radius}), Line_radius) texture {SolidGreen}}
    object {Distance_Marker(Corner_1, Corner_2, Line_radius)  texture
{SolidBlue}}
    object {Distance_Marker(Corner_2, Corner_3, Line_radius)  texture
{SolidBlue}}
    object {Distance_Marker(Corner_3, Corner_1, Line_radius)  texture
{SolidBlue}}
    object {Distance_Marker(Corner_1, PointD, Line_radius)   texture
{SolidGray}}
    object {Distance_Marker(Corner_2, PointD, Line_radius)   texture
{SolidGray}}
    object {Distance_Marker(Corner_3, PointD, Line_radius)   texture
{SolidGray}}
    object {PointMarker (CS_Center, Line_radius) texture {SolidRed} }  //
Circumcenter of sphere
    object {LabelPoint (CS_Center, "Circumcenter", 0.5) texture {SolidGreen} }
   #end // end diagram markers
   sphere {CS_Center, CS_Radius}  //  THE ACTUAL SPHERE
  }  // end union
   #debug concat ("Sphere Circumcenter = <", vstr(3, CS_Center, ", ", 0, 1), ">
\n")
   #debug concat ("Sphere Circumradius = ", str (CS_Radius, 3, 1), "\n")
   #debug concat ("macro '", MacroName, "' finished. \n")
 #end  //  end of macro
Macro for PointMarkers:
//  Plot an x-y-z point marker.
 #macro PointMarker (Point, Radius)
  #local MacroName = "PointMarker"
   #debug concat("<", vstr(3, Point, ", ", 0, 1), ">, ", str(Radius, 3, 3), "
\n")
   #local MarkerHeight = 0.25;
   union {
   cylinder { <Point.x-MarkerHeight, Point.y, Point.z>, <Point.x+MarkerHeight,
Point.y, Point.z>, Radius}
   cylinder { <Point.x, Point.y-MarkerHeight, Point.z>, <Point.x,
Point.y+MarkerHeight, Point.z>, Radius}
   cylinder { <Point.x, Point.y, Point.z-MarkerHeight>, <Point.x, Point.y,
Point.z+MarkerHeight>, Radius}
   #debug concat("macro '", MacroName, "' finished. \n")
Date: 8 Aug 2014 23:15:00
Message: <web.53e5919e3cb258895e7df57c0@news.povray.org>
Strangely, when I switched to using a plane for my trace object, which has
NOTHING to do with the triangle normal, it "fixed itself".
Crazy.
I animated it and it looks quite nice for a first look at the WIP.
posted in povray.binaries.animations.
Questions, comments, an suggestions welcome.
Thanks so much for all the helpful input in getting this to work.
